Old 10-07-2011, 04:12 PM   #1
fateo66
Member#: 130997
Default My latest build: RSVX goodness inside
I figured that it's about time to show my latest build. Margarite and I bought this car fully stock with 200k last Christmas with the intention to leave it fully stock and use it as a back up daily. Well that didn't happen... It all started with the crappy drum brakes in the rear. They just didn't seam to stop the car safely so that HAD to be changed, and the rest went down hill from there The car, for being a higher millage unit, was in pretty good mechanical shape and had no rusty bolts to drive us crazy. The motor swap was the only troubling part because I refused to cut out the upper or lower radiator supports. All and all, that part only took about 2 weeks to wire and fab.
Here is the Mod list.
Power:
3.3L SVX
CAI
1 5/8" primary (extremely restrictive) to 2.5" cat-back exhaust
lightweight underdrive cranks and alternator pulleys
Drivetrain:
2.5" one piece driveshaft
Clutch rear LSD modded to have 80 ft/lbs of breakaway pre-load
Nissan 4/2 pot brakes with 315mm / 295mm rotors
Hawk HP+ brake pads
1" 4 port master cylinder
2" wider track for the front
3" wider track for the rear
Caster adding STI front lower control arms
Poly front control arm bushings
Perrin race PSRS
Spherical adjustable trailing arms
Spherical adjustable rear lateral links
Poly rear hub bushings
Solid endlinks
24mm front swaybar
22mm rear sway bar
WRX steering rack
DMS gold coilovers w/ Tein spherical plates
B&M quicksilver slap shifter
Camber bolts front and rear
4eat auto transmission running full line pressure, full manual, and a fully locked center diff.
2" aluminum radiator
JDM lightweight front bumper beam
Bracing:
Rear subframe lockdown
Solid rear diff carrier
Solid motor mounts
Solid front strut tower brace
Adjustable rear strut tower brace
Grimmspeed master cylinder brace
Interior/ Exterior
Sparco sprint V seats
Sparco steering wheel
Seibon Carbon ricer hood
Carbon S202 replica wing
Wheels:
17x8 16lb BBS wheels
225 Kumho Victor Racer R compound tires
Last Friday Margarite, a few friends, and I went out to High Plains race way to have some fun. The car doesn't have the top end to pull it threw the straight aways but the car ate it up in the corners. :twisted:
fateo66 is offline   Reply With Quote
Old 10-07-2011, 04:26 PM   #2
O.C.D.
Member#: 19640
2003 WRX Sedan
No pics?
O.C.D. is offline   Reply With Quote
Old 10-07-2011, 04:38 PM   #3
fateo66
Member#: 130997
There's like 9 of them.
But they are hosted on myspace so that could be why you cant see them
Old 10-08-2011, 09:35 PM   #4
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Explain the radiator/core support setup please. It looks like you made the center of the upper rad support a bolt in. I have thought about doing the same but am very interested in what you did.
Geronimo!
geronimo81 is offline   Reply With Quote
Old 10-08-2011, 10:02 PM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I'm curious about the radiator setup as well.
One heckuva build for a car that was going to stay completely stock. I know how that works, though, having been down that path myself.
Old 10-12-2011, 04:23 PM   #6
fateo66
Member#: 130997
I did not want to cut out the upper or lower radiator mounts/frame so I mounted the radiator at an angle threw the opening. The upper aluminum bracket you see there is just to hold the radiator in place and at the appropriate angle.
My Bugeye Build: 2.35L CKxx Built Motor Discussion 277 04-21-2011 04:12 PM
My supercharger build: 97' Legacy *actually happening* anothernord Normally Aspirated with bolt-on Forced Induction Powertrain 101 08-25-2010 06:38 PM
The latest Zatoichi movie... good? j y Off-Topic 4 06-12-2004 05:30 AM
Next question about my computer build: WHich case anad power supply Eric SS Off-Topic 28 08-07-2003 06:49 PM
My latest mods and all about Uncle Ben's Good stuff :) sherifx Mid West Subaru Owners Club Forum -- MWSOC 11 02-03-2002 02:03 AM
