Old 12-06-2011, 11:10 PM   #51
tomtom84
Member#: 167794
08 STI 6266 e85 DD
91 miata and 71 porsche
awesome build!
tomtom84 is offline   Reply With Quote
Old 12-10-2011, 08:54 PM   #52
RonW
Member#: 103663
1968 Porsche 912
STi v8 Spec-C conversion
Pulled the motor and installed the KEP flywheel and stage 2 Sach PP/clutch. Nice quality although I thought it would have included a clutch centering tool. Luckily I had a trans I had torn apart for the gears and just used the main shaft lol.
IC plumbed. Planning on a Turbosmart Plumb back BOV and that will go between turbo and IC. got some 2.5" tubing to start down pipe. gonna have to be a short muffle though
RonW is offline   Reply With Quote
Old 12-14-2011, 03:12 PM   #53
ambrynmc
Member#: 301122
Hey RonW,
That engine looks incredible!!
You sure you don't want a special gift under the Christmas tree this year? Like a reverse R/P...special group-buy price....http://www.shoptalkforums.com/viewto...?f=19&t=138159
Your forum needs you... Just kidding!
ambrynmc is offline   Reply With Quote
Old 12-14-2011, 06:13 PM   #54
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Originally Posted by RonW View Post
bump for the questions please
Question #1: I'm running the stock fuel rails and need a way to go from that to -6 AN fitting. I was thinking of some type of manifold to route the runner fuel line to then output to AN fitting. Anything out there already or recommendations?
I don't know if you've found an answer already, but Turbosmart offers adapters for Subaru fuel rails to -AN. See here. I don't see any details on what size -AN it uses, but I imagine if you give them a call they can tell you. I've seen similar generic bits on ebay, but again they don't say what size threads they convert to. It looks pretty small, but it might be -6AN.
Pat Olsen
Old 12-14-2011, 06:20 PM   #55
RonW
Member#: 103663
1968 Porsche 912
ambrynmc
fancy seeing you here too trying to keep both treads up to date. I'd love to participate in the group by for the gears but not in the budget currently. good luck getting 4 more.
Pat
Awesome, I'll give Marty a call tomorrow and see what he has. I am currently set up to use the stock FPR but I have an Aeroquip unit I used the last time and would like to reuse if possible.
Ron
Old 12-28-2011, 07:15 PM   #56
RonW
Member#: 103663
1968 Porsche 912
just a little update:
Brian Keene, aka iWire, came up to help me with my stripped down harness. he worked his magic on the harness to clean up/shorten/lengthen/omit/add/massage/...well you get the picture. came out nice
but before, we popped it in and connected the absolute basics to prime it then fired her up. sounds rough but only the basics to run (no WBO2, no MAF, no alt, no nothing) and she fired up on the first try!
no on to EVERYTHING else. feels good at least to know she runs
Old 12-28-2011, 08:38 PM   #57
Keenah
Member#: 133754
1998 RSTi
All blue, all blue baby
woohoo!
Keenah is offline   Reply With Quote
Old 12-29-2011, 02:03 PM   #58
moss
Member#: 10197
why hello... I was just thinking about doing something like this today!
moss is offline   Reply With Quote
Old 12-29-2011, 06:04 PM   #59
RonW
Member#: 103663
1968 Porsche 912
moss, you should do it. its actually been pretty straight forward ... so far. the radiator is still vexing me. with in front of the rear wheels at a diagonal or in front for the front wheels which would be best for cool air and better weight distribution but running the lines is gonna be a pita. what are you gonna put it in?
Old 12-29-2011, 08:14 PM   #60
moss
Member#: 10197
Sadly I don't have the money or garage space to take on this type of endeavor quite yet.
If I did, I'd probably look into an EJ255/257 or whatever could be sourced at a decent price. Are there any 6spds that could mate up to the EJ257? I guess kcpaz might know that one.
Old 12-29-2011, 08:42 PM   #61
RonW
Member#: 103663
1968 Porsche 912
if its a 911/912 you are planning on putting it in, i don't think the 6sp would fit btw. but never say never, can't or won't...
Old 12-30-2011, 05:36 PM   #62
JdmRacingMotors
NASIOC Storefront Vendor
Member#: 193311
Hey Ron!! How is it going sir?! Wow you have done an amazing job! Cant wait to see the car run!!! How is the engine going?
Happy New Year sir!!
Wali
JdmRacingMotors is offline   Reply With Quote
Old 12-30-2011, 07:37 PM   #63
wtyree
Member#: 29879
2002 WRX Wagon
subscribed
wtyree is offline   Reply With Quote
Old 12-30-2011, 08:34 PM   #64
RonW
Member#: 103663
1968 Porsche 912
Wali, hey man, thanks for stopping by to check on my progress. I can't wait either
harness all wrapped up and back in the car. had a friend tig on the BOV flange so thats all finalized. i have to do a little research where the vacuum lines from the stock boost controller goes. in know one goes to the waste gate (not sure which one) and the other goes somewhere on the intake manifold. if i find pics later i'll post them up and perhaps someone can help me out.
Old 01-01-2012, 04:34 PM   #65
KingKoopa
Member#: 189066
2015 wrx
white
pretty sick.
KingKoopa is offline   Reply With Quote
Old 01-01-2012, 06:57 PM   #66
RonW
Member#: 103663
1968 Porsche 912
mounted all the electrical so that is mostly finalized. i'll remove the mdf board and use it as a template for an aluminum one or have it covered with black vinyl. not sure which yet. i was gonna try to hide it all but i like the ease of access and i kinda like seeing it all, kind of like seeing the inside of a watch work. well see.
connected all the items that needed vacuum (BOV and boost controller) which sealed all those leaks, plumbed -8AN lines to vent the heads and crank case to my catch can and dumped the oil from the initial start up and put in some Brad Penn and a new OEM Subaru oil filter and crush washer. Buttoned her up for a second start up and to see if it evened out the idle and throttle response. Much better. OEM stock wbo2 ordered which btw is a Denso 234-9011 (wrx 4 wire 02-05.)
EDIT:this Denso will not read correctly. the oem unit is 22641 AA191
Old 01-01-2012, 06:59 PM   #67
kirbykirb
Member#: 183596
2005 WRX/9-2x
Obsedian Black Pearl
This is the thread I wanted, I love you op! I was going to buy a 912E/912 and then swap in a EJ20/EJ22 N/A maybe EJ25.
But 4cyl N/A engine. Maybe EJ205 since WRX engines are so available
kirbykirb is offline   Reply With Quote
Old 01-03-2012, 12:38 PM   #68
hiwaitaminute
Member#: 305459
06 Sti
Hi,great work
Can anyone point me in the direction of someone that can fab an adapter plate to matt a RWD Trans to a ej257,,i will send the bell housing
hiwaitaminute is offline   Reply With Quote
Old 01-03-2012, 08:37 PM   #69
RonW
Member#: 103663
1968 Porsche 912
Originally Posted by hiwaitaminute View Post
Hi,great work
contact kennedyenginc.com and see what they have to offer.
Old 01-03-2012, 08:43 PM   #70
FCP Import
Member#: 305489
91 skyline GTR
champ white
Wow great build you have going.
FCP Import is offline   Reply With Quote
Old 01-04-2012, 03:26 PM   #71
hiwaitaminute
Member#: 305459
06 Sti
Perfect,thx
Old 01-05-2012, 09:41 AM   #72
h2oridr
Member#: 151936
2003 wrx
Awesome build, that thing sounds great! What are the plans for the rest of the car? Suspension, wheels, etc.
I like the idea of the scoops before the rear wheels for the small radiators, function and style. Without seeing the car in person but...
h2oridr is offline   Reply With Quote
Old 01-05-2012, 10:08 AM   #73
RonW
Member#: 103663
1968 Porsche 912
well, I've mostly gone thru the car already with swapping the '68 front suspension out for a newer '82 SC with bigger brakes and lighter aluminum crossmember. while i was up there, i install all polybronze bushings for the A arms and Bilstein Sport struts. the rear too base stiff shocks adjustable swing arms but still the original smaller disc brakes. I'm toying with the idea of making jig off of the early steel short wheel base trailing arms and cutting a modern aluminum trailing arms to fit. this would allow bolting on later larger OEM brakes or after market brakes.
i'll have to change the tranny at some point, not a matter if if but when. the 901 just wasn't designed to put 300hp to the ground. likely will be a suby 5 speed tranny converted to RWD and reverse ring/pinion and custom flanges.
as far as wheels, the Porsche Fuchs 15" are light and strong and period correct but i have a set of 16" Fuchs that I'll have powered coated and slicks for the track. I am not going to cut and install flares so unfortunately I'm stuck with 205/15/50 or 205/16/50 all the way around.
as far as cooling up front, I'm still waffling but i thing I've nailed down how I'm going to do it. i found an old thread on a Porsche forum where our fabrication master JCPAZ (see the Boxter with Suby conversion here on this forum) installed a EZ33 into a SC. I liked how he removed the gas tank exposing the stock opening in the front trunk floor and used that for the radiator venting and only had to cut a relatively small opening in the front to bring air in.
then did a custom tank behind it
Old 01-06-2012, 09:57 AM   #74
h2oridr
Member#: 151936
2003 wrx
That radiator setup looks like the way to go, very nice and clean. When running the piping for the coolant to the rear would you use hose all the way or run tubing through the cabin? Either hide it or paint it to match the interior and make it flow with the interior.
I like the period correct look. Love the car
Old 01-06-2012, 11:16 AM   #75
PerformanceAutoSolutions
Member#: 853
2011 STI Sedan
Satin White Pearl
that is great....
PerformanceAutoSolutions is offline   Reply With Quote
- 2005 STi - 352whp / 400 wtq - 18G on Meth - worksti Proven Power Bragging 68 06-04-2010 12:28 AM
FS:CT - 2005 sti doors, interior, 2005 wrx seats Ctracer911 Complete Car Part-Out 16 06-20-2009 07:42 PM
NJ - 2005 STI - Metalic gray, HKS exhaust, Not abused or raced, MINT - $20500 rustyvegas Private Vehicle 'For Sale' Classifieds 17 09-24-2008 11:15 AM
FS - 2005 STi - White/Gold - SLC ibis RMIC Private Classifieds 5 04-13-2006 12:39 PM
FS - 2005 STi - gauging interest UncleMeat Mid West Subaru Owners Club Forum -- MWSOC 12 09-04-2005 12:52 PM
