Old 01-15-2013, 11:46 PM   #126
RonW
Member#: 103663
1968 Porsche 912
STi v8 Spec-C conversion
Originally Posted by Hondaslayer View Post
Ron,
Just an FYI the wire and winding from the level sensor are very specific. The amount of winds and length of the wire determine the internal resistance and therefore the level. (not sure if that makes sense) There is a very good write up on thesamba about it. IIRC the thread is "revive your fuel sender for $3" (or something very similar)
Take a moment and read up on it. IIRC the sensor should still read good at full, but may not be so accurate as the level drops.
Edit: I'll add the link in a sec.
Here ya go!
http://www.thesamba.com/vw/forum/vie...ve+fuel+sender
thanks man. ya, i knew it would be off but not by much since i only took a little of its vertical travel out. mine is kind a different than what was pictured / described in the link but concept similar. i usually take copious photos but just kinda forgot anyway, i found this photo on pelican that kind a depicts my unit
and this
"the copper wire is the one supplying power from the copper tab pin at the plug end. The two silver wires are actually one looped thru the bottom - but one bit is wired to one of the contacts at the bottom. When the float bottoms out on the pins it bridges across the two contacts and makes the circuit to your fuel light. Other than that, as the float sides up and down the resistor (silver) wires it has a couple of sprung legs each side which keep in contact to provide the circuit thru the resistor wires. "
just for thoroughness, i may just pull the sender just to take a quick photo and take ohm measurements at the top and bottom of its travel as well as see what the gauge displays if i turn it one way with the float at one end and then flip it upside down to see how it reads then.
ron
RonW is offline   Reply With Quote
Old 01-17-2013, 05:46 PM   #127
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
1998 Forester, lifted.
Right on,
The sender in the thread I linked is for the post 74 VAG products. Prior to that they used a style just like yours. I figured it would be a good resource if ya needed it
Old 01-17-2013, 05:51 PM   #128
RonW
Member#: 103663
1968 Porsche 912
Right on,
super appreciate it, thanks
Old 01-18-2013, 02:36 PM   #129
icanfly
Member#: 176929
2005 STI Powered Dub
Carbon Black
Default fun times.
Ron,
I thought I would step in and say nice build. I, like RSI am doing something a little different using similar parts (including some of his older parts!). I am doing a fully built 901 trans into an 05 usd sti into the back of a full caged bug chassis with a non-bug body. Doing so using a Kennedy kit, sti pedals and dash cluster, full harness and other misc sti parts. I am using fully converted 911/944 suspension setup and brakes.
You've done a great job with your build. Thanks for sharing it with us.
How's your trans holding up?
Also - I noticed you using your mac for logging of some kind, can you talk about your software / hardware solution?
jmd
icanfly is offline   Reply With Quote
Old 01-19-2013, 06:32 PM   #130
RonW
Member#: 103663
1968 Porsche 912
Originally Posted by icanfly View Post
Ron,
jmd
thanks man, much appreciated. your projects sounds fun! ax'ing beast?
using my macbook pro to dual boot to windows 7 via bootcamp. I have a tactrix plugged into the obd2 port and use ECU flash for d/o and flashing roms to ecu and use romraider for datalogging and manipulating the rom.
regarding the 901 5 speed holding up...im holding my breath and taking it easy of 1st. i have a 2nd 901 in the garage but a 4 speed, which should hold up better, just pop the ZD 5th into the 4sp for freeway cruising.
the 901 is fine but i just dont want to have to worry about it so i decided to go a different route cuz i wanted better gearing, LSD and smoother shifting without the cost i'd have into a 901.
Its a 2010 WRX 5 speed TY758 which only had 28k miles on it and it looks it too
912 goes into phase 2
5-speed from 2010 WRX with only 28k miles and clean as a whistle
i'll slowly modify it for reverse r/p and LSD then after the summer events, yank my 901 5 speed, adapter plate, conversion flywheel and stage 2 pressure plate and clutch and put it all up for sale. 4 speed will go up for sale asap.
i'll document the process here as well
Old 01-20-2013, 11:11 PM   #131
RonW
Member#: 103663
1968 Porsche 912
playing with some ducting from the opening in front. i think it was doing a fair bit or recirculating. never messed with dzus fasteners but thought it would be perfect for this. i'll do the same to direct the outflow as well then some testing, any excuse for testing is a good one.
Old 01-21-2013, 10:04 AM   #132
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Originally Posted by RonW View Post
bailed on cutting down the oem tank, it just was getting too hard. found a great shape and decent volume tank from fuel safe. made a bracket and mounted with new vent and feed lines. enough room to sufficiently vent. few more things before then next ax and track day.
Put something soft on the edge there to keep a hole from rubbing through those lines.
Old 01-21-2013, 10:38 AM   #133
RonW
Member#: 103663
1968 Porsche 912
good call, will do. thanks. its still in proto phase, i think i may do a hard line in and around that area to reduce the profile of the hose under that part of the car.
Old 01-21-2013, 04:13 PM   #134
RustyHinge
Member#: 299742
2007 STI Limited#382
07 WRB STI sold 9/28/12
Very cool build Ron! I'd keep the body the way it is and not put holes into it or cut it up. Just my .02 cents.
Subscribed
RustyHinge is offline   Reply With Quote
Old 01-21-2013, 05:30 PM   #135
RonW
Member#: 103663
1968 Porsche 912
Question for all you suby experts. I'm toying with different methods of connecting the tranny to the outer drive flange. so far all will include a trip to the machine shop for millling and/or welding.
1) bolt conversion Porsche 930 flanges (mates subaru put shaft to 930 cv). then run 930 cv, 930 axle, 930 outer cv. then had a shop cut the 912 outer flange off the drive flange and weld on 930 flange to it. I am confident I could go this route but some extra expensive i'd rather avoid if i dont have to.
2) use subary CV, subaru axle and have the end splined for the 912 CV. - not sure if the 912 cv is up to the abuse it will see
3) use subary cv, subaru axle and have splined for 930 cv and do the drive flange as in #1 above - but this had 2 items being milled/welded
4) see if the guys who make the 930 adapter flanges make one for the 912 but although the cheapest (if he'll do it) be the weakest.
ideas please?
Old 01-21-2013, 06:07 PM   #136
Turn in Concepts
Member#: 93646
Many Track Records
Also, on that vent on the fuel cell please vent it to outside the underhood anywhere. I'm worried about fumes and those relays under there.
On the tranny and axles - are you using the Subaru tranny? If so I think I may just have JUST the solution for you based upon the exo-car we have here made by Speed inc.
Old 01-21-2013, 06:11 PM   #137
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
Ron,
Hate to keep directing you to "the other site" But there are a few people on thesamba that have done the reverse R&P on buses and beetles, might be worth a read. Check the Bay window forum, that is where most of the swaps are done.
Old 01-21-2013, 07:14 PM   #138
RonW
Member#: 103663
1968 Porsche 912
Hondaslayer
-I'll check it out thanks.
Turninconcepts,
-yes, vent under car out from trunk area.
-I am running a 901 transaxle at the moment but will be using the above TY758 5 speed from a 2010 WRX.
-I've seen a few solutions but not for the 912 yet. The bug conversion and 914 conversions have used conversion flanges (bug) or conversion axles (914 - suby inner cv and stock 914 outer cv). the issue with the 912 conversion is i think the 68 cv's are a different bolt pattern at the flange and may have a different spline count than the 914's.
Old 01-22-2013, 09:55 AM   #139
RonW
Member#: 103663
1968 Porsche 912
found some 930 coversion stub axles from the dune buggy guys that may be a good base to send to the machine shop and see if they can make it work for the 912. looks very similar. it would be too easy for it to just bolt right up so i wont even wish for it.
here is the stock 912 on the Left
Old 01-22-2013, 10:33 AM   #140
D-Rodman
Member#: 110078
05 saabaru artc gr
02 wrx wag wrb ej207
Epic, so glad I stumbled over to this side of the site, so cool!!!!
D-Rodman is offline   Reply With Quote
Old 01-23-2013, 02:06 AM   #141
RSti_Spyder
Member#: 120907
1979 Super Beetle
Convertible STI
I am using the stub at the top. I do have some 930 stubs if you need measurements or pictures...
RSti_Spyder is offline   Reply With Quote
Old 01-23-2013, 11:35 AM   #142
RonW
Member#: 103663
1968 Porsche 912
That would be great! need shaft diameter, spline count, overall length of shaft, length of shaft from flange to start of splines, length of shaft from flange to the end of the splines.
then once i have a set of early 911/912 stub shafts, i can compare and see if these can be the base for machining.
thanks
Old 01-23-2013, 03:47 PM   #143
icanfly
Member#: 176929
Carbon Black
Default transmission stuffs.
Ron,
Be sure to check these guys out if you've not already done so: http://www.subarugears.com/
My car is designed and built to be a powerful daily driver / seldom track toy / transcon rally car...
And really it's the summer car to offset my S4 DD / Winter Car...
How are you finding your speed sensor working out for you? I am trying to figure out that part of my build at the moment. In addition to adapting the STI power steering rack. hopefully I'll have that part done Monday. I just have to find someone to make custom power steering lines... anyone have any leads on something like that?
Here is what she is powered by and a sneak of what she looks like:
Also - can you tell me what you are getting up to with your Hydro-throwout bearing setup and how you liked it?
If you starting to part out your 901 related parts, would you be interested in selling that hydro-throwout setup?
Also, would you sell the front mount for the 901?
Let me know.
Last edited by icanfly; 01-25-2013 at 02:27 PM. Reason: adding a shot of my project...
Old 01-24-2013, 11:10 PM   #144
RonW
Member#: 103663
1968 Porsche 912
icanfly,
projects look fun. is it front engine? are you doing a reverse ring in pinion for the 901? hard to tell from the photo. or is it mid or rear engine.
regarding my current tranny set up with the 901, the speed sensor is working flawlessly. i will be selling all my adapter plates/adapter flywheel/pp/clutch. hadnt really thought about the front mount yet, its got a Wevo semi solid bushing conversion. i am using the stock cable clutch release btw, no hydrolic.
>>>>>>>i know Todd at subarugears, talking to Todd actually at the moment about a possible group buy for r/p, 930 conversion flanges and a few other bits. if you or anyone one else is interested, let me know.<<<<<<<
Old 01-25-2013, 02:31 PM   #145
icanfly
Member#: 176929
Carbon Black
I am in the same configuration you are - rear engine, stock location for the 901. Front mounted radiator and fuel cell. I have a lower profile hood line than yours and am having to have a custom fuel cell fabbed up at the moment. Have you had any cooling related issues with your radiator setup?
I was looking at another 901 build that had done a hydro throw-out using a Saab bearing and custom slave - I thought that was you but it's not. Disregard.
Edit: Build thread for said bearing setup
thanks and keep updating the build, it's motivation for me to get my ***** together on my own project!
drive safe.
Old 01-25-2013, 02:54 PM   #146
touge_terror
Member#: 333655
how did you figure out the bolt hole location for the adapter plate? did you use the paint transfer method?
touge_terror is offline   Reply With Quote
Old 01-25-2013, 03:01 PM   #147
Wagz87subi
Member#: 343320
Anyone think its possible to put a wrx 2.0 liter turbo motor in a 91 Toyota truck??? Or possibly the 2.5 wrx motor as well
Wagz87subi is offline   Reply With Quote
Old 01-25-2013, 05:56 PM   #148
icanfly
Member#: 176929
Carbon Black
Default It's best to search first...
Wag,
Might be better to do a search about this rather than to ask this question in someone's unrelated build thread.
Have a peak here to gain some insights related to your inquiry.
kind regards.
Old 01-25-2013, 10:24 PM   #149
RonW
Member#: 103663
1968 Porsche 912
Adapter plate was purchased from Out front motorsports .com
Old 01-26-2013, 12:06 AM   #150
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
Nice to see this thing running! Amazing.
scby rex is offline   Reply With Quote
- 2005 STi - 352whp / 400 wtq - 18G on Meth - worksti Proven Power Bragging 68 06-04-2010 12:28 AM
FS:CT - 2005 sti doors, interior, 2005 wrx seats Ctracer911 Complete Car Part-Out 16 06-20-2009 07:42 PM
NJ - 2005 STI - Metalic gray, HKS exhaust, Not abused or raced, MINT - $20500 rustyvegas Private Vehicle 'For Sale' Classifieds 17 09-24-2008 11:15 AM
FS - 2005 STi - White/Gold - SLC ibis RMIC Private Classifieds 5 04-13-2006 12:39 PM
FS - 2005 STi - gauging interest UncleMeat Mid West Subaru Owners Club Forum -- MWSOC 12 09-04-2005 12:52 PM
