Southern California Impreza Club
Go Back   NASIOC > NASIOC Chapters > Southern California Impreza Club Forum -- SCIC
Old 06-18-2015, 04:46 PM   #1
Josh909
Member#: 167725
2004 WRX
Default Readiness monitors after reflash AP2
Long story short, my car was in the body shop when registration was due. I paid the fees but still needed a smog to get tags. I had a check engine light for tgv deletes and a bad O2. I fixed th O2, put on a new blouch 1.5xtr and took it to get tuned. Well I flashed for the tune of course and the 90 mile drive home wasn't enough to get the readiness monitors to reset. How long does this take, in everyone else's experience? Oh this is also an accessport reflash
Josh909 is offline   Reply With Quote
Old 06-19-2015, 02:17 PM   #2
Josh909
Member#: 167725
2004 WRX
Anyone? Someone has to have some idea here
Old 06-27-2015, 03:16 PM   #3
STidub
Member#: 142031
2005 CGM STi
I was in a similar situation with readiness monitors not set and the tech told me to try to drive at about 35 mph (can't remember if this is exactly the speed or if it was rpm's but I think the main idea is to keep the engine at a constant rpm/speed) for as long as possible without stopping and that they should reset after maybe 20 to 30 minutes. I found a street in an industrial neighborhood where I could drive that speed for maybe a mile without hitting any stoplights and just went back and forth on it. I did it for 30 minutes then went back to the shop and he hooked up my car and it was still no good. I did it again for maybe another 30 minutes and checked but still a no go. Then after the third time of driving for another 30 minutes everything had reset. Pain in the rear.
STidub is offline   Reply With Quote
Old 06-30-2015, 08:41 AM   #4
file_id
Member#: 28197
2003 WRX w/ VF34
here you go. http://techinfo.subaru.com/proxy/652...72-0458832.pdf If you need to specifically find out what is causing your car to not pass I have a bluedriver obd2 diagnostic tool which I used to tell me when the car was ok to be smogged in realtime. I'd be happy to read it for you if you're ever in the LAX area.
file_id is offline   Reply With Quote
