Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 10-08-2011, 02:49 PM   #1
Freemoneey
Member#: 270308
2004 WRX Wagon
Default Can you look at my Stage 2 AP logs.
Hey,
I am trying to figure out why my car is not running the target boost designed for the Cobb OTS stage 2 Beta v310 maps.
My performance mods for my 04 WRX Wagon are:
Invidia Catless downpipe
Invidia uppipe
JNA Performance "ebay" catback. (love it btw, not too loud)
And of course Cobb AP
My first pull on 3rd gear is from cells 2 to 57.
The second pull on 3rd gear is from cells 65 to 12.
The pulls were done on highway on ramps about 3-5 minutes apart.
I have narrowed down the spreadsheet to just include the 3 gear pulls, let me know if the entire log can be of any help.
The google docs is here:
https://docs.google.com/spreadsheet/...VBUnc&hl=en_US
I am running the AP Manager version 2.0.1.5 and the latest firmware 1.6.4.0-1960
Any information/knowledge is welcomed and will be appreciated.
Last edited by Freemoneey; 10-08-2011 at 11:23 PM. Reason: Corrected url, after setting view access to Public.
Freemoneey is offline   Reply With Quote
Old 10-08-2011, 03:07 PM   #2
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Originally Posted by Freemoneey
Hey,
Invidia uppipe
https://docs.google.com/spreadsheet/...hl=en_US#gid=0
You have to set the permissions to public in order for us to see the log....
2Fast4U1DAY is offline   Reply With Quote
Old 10-08-2011, 11:27 PM   #3
Freemoneey
Member#: 270308
2004 WRX Wagon
Edited my post after changing the document settings to Public View.
Old 10-08-2011, 11:55 PM   #4
mxturboracer86
Member#: 82398
2008 STi
555 Motorsports
there's quite a bit going on in there that needs to be addressed, along with that to hit the target boost you will need to tighten the wastegate arm its too loose. I would first recommend a proper tune over an OTS map, then you will have not only a safer car, but really see the benefits from the car.
PM me, I can help you out if needed
mxturboracer86 is offline   Reply With Quote
Old 10-09-2011, 10:40 AM   #5
Cobb Tuning
Member#: 4803
Originally Posted by Freemoneey View Post
Hey,
Invidia uppipe
Your DAM has dropped, which is not good. However, it does not appear that you are actually running one of the beta maps. Where did you get the map and did you reflash the map (as opposed to running it as real-time)?
Here is the link to the 02-05 WRX beta maps:
http://forums.nasioc.com/forums/show....php?t=2233868
Bill
Old 10-09-2011, 01:36 PM   #6
Freemoneey
Member#: 270308
2004 WRX Wagon
Bill
Bill,
I used the stage 2 beta maps from that link you provided. I did reflashed the car instead of just running the realtime map. ( i used the connectors under the dash of my 04 WRX)
The current map Iam running is titled Stage2 93 v310 BetavB.
The map Iam using is listed in red here, https://docs.google.com/leaf?id=0B8S...5MmFl&hl=en_US
About the DAM, what can affect the DAM to not be at 16.
Will tighteting the wastegate arm help my situation? Or should I try to run map Stage2 v310 93 HWG first instead?
Ever since I installed the Stage 2 parts and installed the Stage 2v300 93 map on Sept-4-2011, i have noticed that I have not met the recommended boost target since.
Prior to Sept 4, the week before I was at Stage 1 v300 93, and I noticed the same thing.
Old 10-09-2011, 02:05 PM   #7
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Bill,
Knock during WOT runs will make the DAM drop. DAM is the ecu's rough knock correction. If it sees repeated knock, or a severe knock event, it will lower DAM to take a given precentage of timing out of the timing advance tables, to try and prevent knock, and to save the engine. Simply put, DAM is a measure of how "happy" the engine and ECU are.
Old 10-09-2011, 05:03 PM   #8
Cobb Tuning
Member#: 4803
Bill,
It looks like we may have made a mistake and uploaded the old map for that particular map rather than the beta map. I'm going to get with the calibrator on Monday and see what is going on and I'll let you know. Until we can confirm, I would not run the current beta map (just in case).
Bill
Old 10-09-2011, 06:21 PM   #9
Freemoneey
Member#: 270308
2004 WRX Wagon
Bill
Bill
Bill,
I will reflash to the non-Beta map today. Thanks for the info.
Old 10-11-2011, 10:16 AM   #10
Cobb Tuning
Member#: 4803
Bill,
We got the bug fixed in the beta maps. It impacted all the 04 beta maps. We've updated the beta threads as well. I would go ahead and delete all the old beta map(s) on your computer (just be sure) and then download the stage 2 map for your car again:
Sorry for the inconvenience!
Bill
Old 10-12-2011, 01:13 AM   #11
Freemoneey
Member#: 270308
2004 WRX Wagon
Bill
Bill,
Got the new maps downloaded to my AP tonight, will flash the car tomorrow.
Will report back the lags later on.
Can you look at my log? this is my first AP Bugeye115 AccessPort 0 09-13-2011 06:41 PM
Can someone look at my log???? wrx904 AccessPort 2 07-28-2011 09:03 PM
Quick look at a Stage 2 GTR w Accessport.. Cobb Tuning Proven Power Bragging 67 02-13-2009 12:41 PM
Could you look at my CLB, CLfuel Stg 2 log? 03WRXMA Engine Management & Tuning 0 03-12-2004 09:23 PM
ESP ticket update, any police/lawyers out there, can you look at this evidence photo? Sean General Forum Archive 8 08-22-2000 04:01 PM
