#1 |
Member#: 285620
SCIC
Vehicle:05 STi BlaCk |
hey soo i finally got a version 1 AP because im running stage 2 but not tuned. I attempted to install the AP and while it was initializing for the first time/loading the map it said communication error (i think due to me nudging the connection)...it stopped at 45% and said error. now my car wont start. also when i plug the green tester pins in and turn ignition to "on", the check engine light stays solid and does not flash as it did before nor do the fans come on. PLEASE HELP, my car is parked in front of my friends house in Lake Elsinore and Im from orange county and its my daily driver so any quick help would be greatly appreciated!!!
#2 |
Member#: 79643
NESIC
Vehicle:04 EJ207 Swapped Mikey tuned 271whp/287wtq |
Did you reload the map? If it stopped at 45% it won't work. You have to complete the process. That is, if you didn't fry the ecu
#3 | |
Member#: 252195
RMIC
Vehicle:07 WFC #900 @ 451awhp-404awtq |
#4 |
Member#: 285620
SCIC
yeah, thats what i think happened... anyone know where i can get a new ecu on the cheap?
#5 | |
Member#: 252195
RMIC
#6 |
NASIOC Manufacturer
Member#: 4803
Unfortunately, the AP v1 is quite old and does not have any ECU recovery process (as the AP v2 does). Of course, if you interrupt the flashing process, there is always the possibility of causing the ECU to be non-functional, which can happen with any flashing device/software, regardless of the company. The only thing to try at this point would be to disconnect the neg. terminal of the battery for a few minutes, reconnect, and then try to flash again. If that doesn't work, you can give us a call - we may be able to recover your ECU (a service we offer). The 05+ STi has immobilizer, so if you buy an ECU (rather than recovering your current one), you'll have to get it re-programmed for the immobilizer by the dealer.
Bill |
#7 | |
Member#: 82398
Vehicle:2013 SXL 555 Motorsports |
#8 | |
Member#: 285620
SCIC
#9 | |
Member#: 250152
Vehicle:2006 WRX Limited OBP |
#10 |
Member#: 82398
Pm me, I can give you some instructions and help you out.
#11 | |
NASIOC Manufacturer
Member#: 4803
Bill |
#12 |
Member#: 285620
SCIC
damn u guys were helpful, talked to cobb, ill be sending my ecu back tonight and upgrading to the ver 2! i feel like its my birthday
thanks |
#13 |
Member#: 285620
SCIC
Mxturbo is a genius! Got my car running again!
#14 |
Member#: 82398
#15 |
NASIOC Manufacturer
Member#: 4803
#16 |
Member#: 82398
#17 |
NASIOC Manufacturer
Member#: 4803
#18 | |
NASIOC Manufacturer
Member#: 4803
Sincerely, Bill |
| Thread Tools | |
| Display Modes | |
| Car wont start. Help needed Quick. | Yakshii | Factory 2.0L Turbo Powertrain | 9 | 09-07-2009 11:54 PM |
| Car Wont Start...HELP!!!!!!!!!!!!!! | dnstor | Newbies & FAQs | 19 | 11-26-2007 05:17 AM |
| car wont start help | mdd1986 | Factory 2.5L Turbo Powertrain | 0 | 01-17-2007 12:56 PM |
| Car wont start!! help!!!!!!!!!!!!!!!! | SplatZ400 | Mid Atlantic Impreza Club -- MAIC | 18 | 07-23-2006 02:25 PM |
| Electrical/Battery Problem? Car Wont Start Help! | illmattic016 | Factory 2.0L Turbo Powertrain | 11 | 07-21-2006 05:34 AM |
