Welcome to the North American Subaru Impreza Owners Club Saturday August 2, 2014
Old 10-09-2011, 06:38 PM   #1
STINY11
Member#: 285661
2011 STI
Dark Grey Metallic
Default 2011 STi Footwell Illumination
Footwell Illumination kits are standard on STi's for 2011 (per their website and brochures at least) but I'm curious if other people have the same issue I'm having.
Mine has the red illumination kit, but it is only on when I unlock the car and the dome light is on, and it stays on until I insert the key and turn it, then the lights all fade off pretty quickly.
I was told by one of the mechanics at the subaru dealership that when they install a kit on a WRX or an Impreza that the lights are tied directly to whether the exterior lights are on or not. He didn't know if the STi was supposed to do the same or if it was different so I'm asking ya'll.
Let me know if you have an STi and your illumination kit does the same thing that mine does or if it works when the exterior lights are on.
Also, I'm only interested in knowing if other 2011 STi's have the same issue, because it seems to be only an STi thing, not a WRX or Impreza issue from what I can tell.
STINY11 is offline   Reply With Quote
Old 10-09-2011, 10:19 PM   #2
jay7660
Member#: 212992
2011 STI Sedan
The floor lights only come on when you open the door, then they fade when you start the car. Thats what i've noticed on mine. Sounds about right what you say.
jay7660 is offline   Reply With Quote
Old 10-09-2011, 10:45 PM   #3
furiouswrx
Member#: 283048
2011 WRX Ltd Hatch
I have the red footwell illumination on my 2011 WRX and it stays on when the exterior lights are on. Puzzles me why Subaru didn't do the STIs the same way.
furiouswrx is offline   Reply With Quote
Old 10-09-2011, 11:27 PM   #4
jay7660
Member#: 212992
2011 STI Sedan
It might be how there connected on the WRX. Does the WRX have the center console illumination also? That light does stay on after the key is turned.
Old 10-10-2011, 02:44 AM   #5
jman3113
Member#: 297333
i recently got the illumination kit on my 2011 wrx. it turns on when you turn on the headlights.
jman3113 is offline   Reply With Quote
Old 10-10-2011, 10:54 AM   #6
2011OBPWRX
Member#: 296791
2011 wrx
Yes, center light always stays on in the 2011 wrx.
2011OBPWRX is offline   Reply With Quote
Old 10-10-2011, 11:05 AM   #7
VinSVT
Member#: 77637
The illumination kit I installed in my 2011 WRX tied into the center console light.... which is why it stays on with the headlights.
I'd bet the STI lights don't tie into the center console at all.
VinSVT is offline   Reply With Quote
Old 10-10-2011, 11:07 AM   #8
STINY11
Member#: 285661
2011 STI
Dark Grey Metallic
So, when they say that the STi comes with the footwell illumination kit, what they really mean is that it comes with something that almost functions like the footwell illumination kit...
Anyone with an STi figure out how to make the lights stay on with the headlights too?
Also, if you have one on the WRX, do the lights turn on when you unlock the car and fade out when you turn the key if the headlights are off? And do they turn on when you turn off the car, and also when you open the door?
Old 10-10-2011, 01:47 PM   #9
VinSVT
Member#: 77637
This thread has a couple people with STi's asking similar questions.
http://forums.nasioc.com/forums/show....php?t=2246374
On my 11' WRX the lights only come on with the headlights.
Old 01-01-2012, 05:36 PM   #10
STINY11
Member#: 285661
2011 STI
Dark Grey Metallic
To close this thread up:
I ended up buying and Installing the Footwell Illumination Kit yesterday. With the STi you have to either drill a new hole for the driver side lights to be installed, or move the original courtesy light.
My solution was to just pop out the original light (which was shining through the hole used to mount the driver side illumination kit), then install the illumination kit where it's supposed to go, and apply the extra adhesive that comes in the kit (it's supposed to be used if you have a Forester I think) to the original courtesy light and mount it on top of the kit light so that it's visible above but to the side of the kit light.
This allowed me to avoid drilling and I didn't need to go buy any extra parts for fancy mounting methods. I don't think you can really even tell that it wasn't professionally installed, as it's not visible unless you put your head up under the dash. Here's what it looks like with both on at once.
The standard courtesy lights are more of an orange-ish color while the Red LED Footwell Illumination Kit is definitely much more red. So, when the door is opened, the courtesy lights turn on (orange-ish but definitely on the red side), and when I close the door, they stay on until the key is inserted and turned. The courtesy lights then dim to off. When I turn on the headlights, the RED footwell lights turn on. If you have the headlights on and the door open, both lights are on. I have them mounted so close to each other on the driver side that you can't even tell it's not just one light...it just gets brighter with both on. On the passenger side, they're a little more separated and you can kind of see a little bit of orange to the side of the red, but I think it still looks very good.
I would definitely do this if you have an STi and you want your footwell lights to work whenever you have your headlights on.
Footwell Illumination install 2011 WRX Overland04 Interior & Exterior Modification 168 07-10-2014 07:41 PM
How do you install the Footwell Illumination Kit (H201SSC000) in the '09 FXT/WRX/STI? GodWhomIsMike Interior & Exterior Modification 226 06-08-2014 04:19 PM
Blue Footwell Illumination Kit in a 2011 WRX? GodWhomIsMike Interior & Exterior Modification 42 10-01-2011 11:28 AM
Subaru Footwell Illumination kit $30 Shipped TEK112 Interior/Dressup/Audio & Security 7 01-05-2010 09:43 AM
footwell illumination wiring question exrage Interior & Exterior Modification 9 09-28-2009 06:44 PM
