Old 08-05-2002, 04:00 PM   #26
kenshiro
Member#: 15917
2002 teh FastAR rex
Black like my soul
16psi in hot weather is different than 16psi in cold weather. In hot weather you want a higher boost pressure to compensate for the oxygen being less dense.
kenshiro is offline   Reply With Quote
Old 08-05-2002, 06:53 PM   #27
Steven Saunders
Member#: 563
2002 Subaru WRX
WR Blue Pearl
OK,
Which EBC will let you put in the boost you want (preferably in PSI) and it will go there, with out adjusting to that point. One that has a couple or more different "presets" (i.e. day/night) and will, if any do, make that boost level in EVERY gear. I don't know id that is possible or not, still learning.
Steven Saunders is offline   Reply With Quote
Old 08-05-2002, 08:44 PM   #28
Steven Saunders
Member#: 563
2002 Subaru WRX
WR Blue Pearl
bump
Old 08-06-2002, 12:11 AM   #29
BamBooI
Member#: 10945
2006 Evolution IX
Originally posted by Steven Saunders
OK,
APEXI AVCR will for sure. I don't know about the blitz sbc id though. It might.
BamBooI is offline   Reply With Quote
Old 08-06-2002, 09:03 AM   #30
Steven Saunders
Member#: 563
2002 Subaru WRX
WR Blue Pearl
anyone else have any suggestions? Has any body used the AVCR?
Old 08-06-2002, 10:22 AM   #31
Kha0S
Member#: 8808
2011 WRX (DGM 5D)
2002 WRX/2003 SVTF
Bleed-type MBCs are more sensitive to variable temperature and humidity than ball-spring type. The boostmonkey is essentially a bleed-type MBC, but you can adjust it from in-cabin. I often adjust my boostmonkey once or twice a day to maintain consistent boost (daytime temps of 85-90F, high humidity, drier nights at 75F), but since it's in my center console, it's no big deal.
EBCs use a closed-loop feedback control to manage boost, so they're not weather-sensitive.
/Andrew
Kha0S is offline   Reply With Quote
Old 08-06-2002, 10:36 AM   #32
kenshiro
Member#: 15917
2002 teh FastAR rex
Black like my soul
I have the AVC-R. It's awesome. It holds perfect boost levels for me. Last month Sport Compact did a review of electronic boost controllers, try to find that issue and you can read about them. Or I guess you can just search on i-club.
Old 08-06-2002, 06:23 PM   #33
Steven Saunders
Member#: 563
2002 Subaru WRX
WR Blue Pearl
kenshiro,
I heard that the AVCR is very hard to tune, is this right, if so how is it so hard?? I have a subscription to SCC and can't find it in the August issue. Do you know what issue it is in.
Thanks
Steve
Old 08-06-2002, 06:58 PM   #34
jlogan9
Member#: 15511
wow, this great thread...lots of good info
Keep it up, I am learning
jlogan9 is offline   Reply With Quote
Old 08-06-2002, 08:24 PM   #35
amelnikov
Member#: 9827
2002 WRX Wgn 292whp
Alex Performance
I read it and I think it's a big add and not a good review. They got the biggest spikes with ball and spring MBC, granted a very crudly put togheter MBC but nontheless. Of all MBC's ball and spring type have the least amount of spike. On my granger valve based mbc I have at most .5 psi spike and that's with long lines going to it.
Alex...
amelnikov is offline   Reply With Quote
Old 08-07-2002, 07:36 AM   #36
Steven Saunders
Member#: 563
2002 Subaru WRX
WR Blue Pearl
bump..Kenshiro, anyone else have any suggestions or comments?
how much will HP will my fuel lines support cbourbs Factory 2.5L Turbo Powertrain 5 06-13-2007 02:15 PM
How Much Has Subaru Changed The Impreza? legacyandy Newbies & FAQs 3 06-24-2004 11:12 PM
how much are oil change washers? SinhCredible General Community 5 01-05-2004 12:14 PM
How Much will the OEM kit change my ground clearance? mackdaddykuhn Interior & Exterior Modification 4 08-16-2002 11:35 PM
how much will thunder hill be? WRXwannbe Bay Area Impreza Club Forum -- BAIC 2 09-12-2000 05:57 PM
Message Board Statistics All times are GMT -4. The time now is 09:25 AM.
