10-10-2011, 05:25 PM | #1 |
Member#: 243616
Vehicle:2010 WRX 336/384 2006 STI 627/484 2015 BRZ |
A Fatal Ode - 2010 WRX GH DGM
2010 Subaru Impreza WRX (GH) DGM COBB Tuned - 336whp/384tq @ 20psi (e85) & 279whp/319tq @ 19.5psi (91oct) - Mustang Dyno ---POWER/ENGINE--- Cobb SF intake w/box Cobb XLE BPV Cobb AP AVO turbo inlet Process West TMIC ^wrapped in DEI gold reflective adhesive Grimmspeed EBCS Grimmspeed pnp uel headers thermal coated Grimmspeed high flow crosspipe thermal coated Grimmspeed uppipe w/ 44m ewg flange thermal coated Grimmspeed TGV delete thermal coated Grimmspeed vf52 IWG brace Grimmspeed turbo heat shield thermal coated ^inside wrapped in DEI gold reflective adhesive Tial 44mm EWG Invidia race TBE (catless) ^DP wrapped in DEI titanium wrap Crawford AOS Walbro 255 Koyo Rad ID 1000's Phenolic spacers 3mm KS Tech air pump delete PTP turbo blanket ---SUSPENSION/CHASSIS/DRIVETRAIN--- Whiteline 24 adjustable front sway bar Whiteline 22 adjustable rear sway bar Whiteline ALK Whiteline balljoints Whiteline tie rods Whiteline rear support braces Whiteline lower chassis H brace Whiteline rear adjustable lateral toe arms Cusco rear adjustable lateral links Cusco rear adjustable trailing arms Cusco rear strut tower brace Cusco front strut tower brace BC BR coilovers (8k/8k) Kartboy endlinks Kartboy f/r shifter bushings Exedy OEM stage 1 clutch ---BRAKING--- DOT4 Ate super blue brake fluid ST-40 355mm fronts ST-22 345mm rears Stop-Tech stainless steel braided brake lines Stop-Tech street pads ---INTERIOR--- Defi Red Racer boost gauge 52 Prosport Premium wideband air/fuel ratio gauge 52 Prosport Premium oil pressure gauge 52 Cobb AP Subaru all-weather floor mats SMY dual cluster Valentine One ---EXTERIOR--- Rally Armor UR mudflaps H3LLA supertones(2)/red Rota DPT matte bronze 18x8.5+48 wheels Dunlop Star Specs 255/35/18 ...some stickers that add about 15~ awhp Window Tint 15% front & top windshield / 5% rear Sports grille Get Primitive front and rear skid plates PREVIOUS DYNO VID stock pull was 92oct
10-10-2011, 05:27 PM | #2 |
Member#: 243616
---to be installed--------------- defi rr oil temp gauge grimmspeed brake bracket ---maybe someday after or within the above/future plans-------------- more bushings and bracing? seats/harness? hid kit? new front bumper? -_- higher quality coilovers? winter wheels/tires? track wheels/tires? engine build etc? just buy an STi...? or a different car? etc. Last edited by A Fatal Ode; 09-16-2012 at 11:09 AM. |
10-10-2011, 06:28 PM | #3 |
Member#: 275280
Vehicle:2007 WRX TR Crystal Gray Metallic |
It's clean man. Keep it, STi's usually run higher in the insurance area anyhow. I'd say red out the tails and leave the exterior as is. She's sexy, keep doin' what you're doin'!
10-18-2011, 03:44 PM | #4 |
Member#: 276165
Vehicle:2013 BMW 328i Sport Black |
OOOoo Das nice. Glad to see someone tracking the newer WRX (non STi) gives me an idea of what to do for mine should I decided to head out for a day.
10-18-2011, 04:02 PM | #5 |
Member#: 293973
Very nice.
10-18-2011, 04:51 PM | #6 |
Member#: 243616
thank you thank you. last track day of the season is in two weeks and then i'll look into getting these parts off my floor and to my car... plus maybe a couple more.
looked at a 2011 LR STi sedan today.. oh god.. fap fap fap...X_x |
10-18-2011, 06:40 PM | #7 |
Member#: 298273
BAIC
Vehicle:2003 MSP Laser Blue |
Yeah bro car looks super clean, all I would do is put on some red overlays on the taillights. Mad props yo
11-19-2011, 01:33 AM | #8 |
Member#: 243616
what i've done, kinda in order ------
---modz- (inish order on installation) Invidia TBE race catless K&N drop-in###removed### Whiteline 24 adj front sway Whiteline 22 adj rear sway Whiteline rear support braces Kartboy endlinks Defi red racer boost gauge Rally armor mudflaps Stop-Tech SS lines 15%/5% tint Supertones Super Blue Brake Fluid Rota DPT 18x8.5+48 matte bronze Conti DW 245/35/18###removed### SMY dual cluster Prosport 52" premium oil pressure gauge Prosport 52" wideband premium air fuel ratio kit Hawk HPS f/r brake pads###removed### Process West TMIC Whiteline ALK Whiteline RCK (ball joints & tie rods) BC BR 8k/8k coilovers COBB AP COBB SF intake/box COBB XLE BPV subaru all-water floor mats. COBB Tuned - May 24th, 2011 @ 274/292 17.5psi/91oct V1 SPT battery tie down PTP (subaru) turbo blanket Crawford AOS Whiteline lower chassis H brace Sports grille Hawk HP+ f/r Walbro 255 Avo turbo inlet Grimmspeed pnp uel headers thermal coated Grimmspeed high flow crosspipe thermal coated Grimmspeed uppipe w/ 44m ewg flange thermal coated Grimmspeed ebcs Koyo rad Tial 44mm ewg Grimmspeed vf iwg brace DW 1000's###removed### ID 1000's Phenolic spacers 3mm KS Tech air pump delete Grimmspeed tgv delete thermal coated Grimmspeed turbo heat shield thermal coated COBB Tuned - December 22nd, 2011 @ 279/319 19.5psi/91oct & 336/384 20psi/e85 Bridgestone Blizzaks 225/45/17 on the stock wheels 17x7+55 Kartboy F/R shifter bushings Dunlop Direzza Sport Z1 Star Spec 255/35/18 -- fenders rolled Last edited by A Fatal Ode; 04-28-2012 at 12:03 PM. |
12-18-2011, 02:40 PM | #9 |
Member#: 304293
Always looks good John she was tough to work on, but glad we got all the parts on and got it done in time for Cobb shall i post pics off all the parts laying on the floor during the install of everything? lol!
12-31-2011, 03:44 AM | #10 |
Member#: 243616
Updated! new tune and stuff
01-05-2012, 10:14 PM | #11 |
Member#: 243616
edited
01-06-2012, 01:14 AM | #12 |
Member#: 305991
digging the rims
01-07-2012, 12:44 AM | #13 |
Member#: 117487
slow
01-07-2012, 08:08 AM | #14 |
Member#: 243616
all it needs to be able to do is get the milk home before it spoils!
02-06-2012, 05:44 PM | #15 |
Member#: 243616
soo ... uh... what next? anything other than building a block and upgrading the turbo w/ supporting mods? i really just wish my brakes could be as good as they are now without having to use loud track pads that eat my rotors.
02-06-2012, 07:31 PM | #16 |
Member#: 99072
Vehicle:2010 Forester XT |
Looking good as always!
02-06-2012, 07:52 PM | #17 |
Member#: 243616
thanks cary! i spent about an hour at bob moore today talking with a sales man about a 2012 STi.
02-25-2012, 07:58 PM | #18 |
Member#: 243616
whomp. get'n ready for track season. i <3 corners
03-18-2012, 03:17 PM | #19 |
Member#: 115303
SWIC
Vehicle:2012 STI Hatchback DGM |
well so far you've put a lot of money into your car. if you sell it and but an STI your going to be taking a pretty big hit on your car probably. Than you'll be modding the STI which will be more of a cost.
If money is not a problem and you don't care about taking the hit...i would go with the STI...otherwise stick with your WRX |
07-15-2012, 01:31 PM | #20 |
Member#: 243616
hmm... 20g xt-r, dom 1.5xt-r, green HTA, or more.. like a dom2.5, 3, or a "small" rotated set up.... maybe just keep the '52 and save for whatever...
this has been the battle for the last 6 months or so while reading experiences and overlapping charts.. i don't want to buy too small and be disappointed or buy too big and not enjoy driving it daily anymore. basically and ideally, i'd like to keep the save torque and hp curve and just have the lines keep going up and top out accordingly on the right. like if you looked at my 4 dyno plots, continue that trend up. the BLACK line is not a real plot... but that's kinda what i'm dreaming of. smoother lines of course. and suuureee, i'd be happy with more low end or more in general =P soo.. is that possible? i'm still on the fence of just selling it and starting over but that'd be a financial stretch/stress even though in 3 years i'd probably be ok.... a lot can change in that amount of time though. seats... i've been considering some nice bride low max's, but have been saving up for a potential build/swap/etc track wheels/tires... want.. bad.. but again, saving for the above. blah blah blah. cool story. Last edited by A Fatal Ode; 07-15-2012 at 01:48 PM. |
09-16-2012, 11:05 AM | #21 |
Member#: 243616
slow lap start, bit of an off around 6min or so... few hot laps around 7.... pass a few cars... miss a miata spin out...
09-18-2012, 10:17 PM | #22 |
Member#: 206257
Vehicle:2009 WRX 5-door White |
Where's that track?
Is that noise under acceleration BPV flutter/chatter? |
09-19-2012, 12:05 PM | #23 |
Member#: 167103
Vehicle:2007 STi URBAN GREY METALLIC |
09-20-2012, 05:30 PM | #24 |
Member#: 243616
Amp Wiring - 2010 WRX | mpggomd | Car Audio, Video & Security | 38 | 08-11-2011 10:02 PM |
FS : SOLD: Like New - COBB AccessPORT - 2010 WRX | MREUS | Engine/Power/Exhaust | 11 | 11-24-2010 11:27 PM |
FS : 2010 WRX Hatch DGM | InsideOut104 | SCIC Private Classifieds | 12 | 11-11-2010 01:40 AM |
2010 wrx GH rim options. | A Fatal Ode | Tire & Wheel | 2 | 08-27-2010 08:09 PM |
2008 - 2010 WRX lip options | 04ts | Interior & Exterior Modification | 2 | 10-19-2009 12:46 AM |
