Welcome to the North American Subaru Impreza Owners Club Wednesday June 3, 2015
Old 01-12-2011, 11:11 AM   #1
dman918
Member#: 11202
2009 Infiniti G37X
Prev: 2006 STi with stuff
Default BaysonR V-Limited Lip - Are you guys painting it?
I just got my lip from baysonr and it's just sitting in the box, ready to be mounted. However, I was wondering if you guys are painting it black or just leaving it be. I want it to replicate the real v-limited look.
Thanks!
dman918 is offline   Reply With Quote
Old 01-12-2011, 11:29 AM   #2
Donzo
Member#: 95337
2012 Jeep Overland
I scuffed, primed and sprayed it gloss black myself. My car is black though. I like the way it looks. It's really whatever your preference is. It doesn't look bad either way.
Donzo is offline   Reply With Quote
Old 01-12-2011, 11:34 AM   #3
YourMother'sLover
Member#: 76565
CLXX Stricta Parata
Neci!
I kept mine the way it was. It matches my raw PU spiler and the other trim on the car. Granted, this is on my DD LGT and not the show WRX.
YourMother'sLover is offline   Reply With Quote
Old 01-12-2011, 01:40 PM   #4
FCmaniac
Member#: 142029
2013 Forester
2008 350z, 1991 Miata BRG
I left it raw and glad I did since I scrape it often.
FCmaniac is offline   Reply With Quote
Old 01-12-2011, 09:17 PM   #5
DoneRightScooby
Member#: 220836
2004 VF-39 wrx
^^^^ i agree i scape mine all the time i think it gives my car character.
DoneRightScooby is offline   Reply With Quote
Old 01-12-2011, 09:25 PM   #6
JavaBot
Member#: 156723
05 srp foresterX
rip 2.0i/2.5rs
Use, primer if you can... I'm spoiled too cuz my car is black but that way when you scrape you can just reshoot it easily. Will also be more protective and flexible than paint would. Just my .02!
JavaBot is offline   Reply With Quote
Old 01-12-2011, 09:27 PM   #7
dman918
Member#: 11202
2009 Infiniti G37X
Do we need to drill holes in the bumper? It came with a combination of pop-its and screws. My bumper doesn't have screw holes on the bottom. Haven't looked to see if they all line up with pop-it spots.
Old 01-12-2011, 09:33 PM   #8
JavaBot
Member#: 156723
05 srp foresterX
rip 2.0i/2.5rs
It should line up, but I would recommend using a few self tapping screws in the voids of the predrilled. It will make it rock solid and part of your bumper... just be careful not to rip it all off depending where/how you drive!
Old 01-13-2011, 09:07 AM   #9
dman918
Member#: 11202
2009 Infiniti G37X
The problem is that the lip has both popits and screw holes. My bumper does not have screw holes. Do I have a lip for a wrx and not STi?
Old 01-14-2011, 10:11 PM   #10
wrxkid157
Member#: 201046
2004 WRX
box 2 car no need for paint youll be pissed after you paint it and spend hard work on it then it scraped as you drive out of your drive way!
wrxkid157 is offline   Reply With Quote
Old 03-06-2011, 05:39 PM   #11
WhatTurboLag?
Member#: 243992
2006 WRX TR
what color is this lip when it comes from them? is "raw" just a flat black or will i need to paint it flat black myself?
WhatTurboLag? is offline   Reply With Quote
Old 03-06-2011, 05:44 PM   #12
JavaBot
Member#: 156723
05 srp foresterX
rip 2.0i/2.5rs
It will be your usual poly black, that will fade over time from uv exposure. Since it will arrive off the car, I'd hit it with a layer of flat black primer after a scuff/clean and you're starting fresh and bright until your first scrapes and second coat
Old 03-06-2011, 10:38 PM   #13
ThreeEleven
Member#: 157894
2007 WRB WRX
EJ257
Painted mine and it started chipping because I most likely am a ****ty painter/used ****ty spray paint. Had it painted black professionally and it looks so much better. Shortly after I had it painted though, I rolled over high snow and it got ripped off.
Mine looked really faded and almost grey from Subimods.com, so I needed to paint it.
ThreeEleven is offline   Reply With Quote
Old 03-07-2011, 06:29 AM   #14
FCmaniac
Member#: 142029
2013 Forester
I'm only lowered on RCE blacks which are probably the mildest drop you can get and I still scrape this lip pretty often. It's not worth painting IMO unless you're at stock ride height. It takes too many hits. The raw look isn't that bad.
Old 03-07-2011, 07:12 AM   #15
hi-flo
Member#: 220008
2004 WRB STi
1996 Camry
i don't have one yet but i plan on leaving it as is. does it come with the mounting hardware when you order it new from baysonR?
hi-flo is offline   Reply With Quote
Old 03-07-2011, 09:08 AM   #16
ThreeEleven
Member#: 157894
2007 WRB WRX
EJ257
It will come with about 16 screws and predrilled holes in the lip for them. The holes for the pop clips line up just fine, too, so use those as well.
Old 03-07-2011, 09:50 AM   #17
KauvSTi
Member#: 235128
W211 E55
I had a a lot of scraps and I just washed it and sprayed pasti-dip on it and it gave it a nice flat color!
KauvSTi is offline   Reply With Quote
Old 03-07-2011, 10:11 AM   #18
Kupkake
Member#: 213288
2007 SWP VF39 WRX
Sti Mikey Tuned
raw. Scrapes to much to care.
Kupkake is offline   Reply With Quote
Old 03-07-2011, 12:03 PM   #19
05slprWRX
Member#: 243742
2005 WRX323whp290wtq
bremboed,meth addict.SOLD
Sand it all up nice and hit it with some bumber coating its more flexible paint. Have that on mine and I'm on kw 3s front lip is lower then a 12oz soda can I don't hit to often just take thinks at angles you will be fine. And iVE hit mine a few times in the last year and it still looks great bumper coating FTW
05slprWRX is offline   Reply With Quote
Old 03-07-2011, 06:33 PM   #20
cybertrax
Member#: 205063
07 STi , 06 Evo MR
I ended up painting mine just for the heck of it.
cybertrax is offline   Reply With Quote
Old 03-07-2011, 06:35 PM   #21
seth_alan
Member#: 271264
07 STy
I had my paint guy paint it flat black for me....the paint is coming off now a few months later oh well it was free anyway.
seth_alan is offline   Reply With Quote
Old 03-07-2011, 06:45 PM   #22
soundbomber
Member#: 230136
Paint matched is the only way to go!
soundbomber is offline   Reply With Quote
Old 03-07-2011, 07:02 PM   #23
05slprWRX
Member#: 243742
Only if the car is black. Otherwise paint match is not the way to go sorry
Old 03-07-2011, 07:14 PM   #24
FlaT FouR
Member#: 185798
2006 WRX Ltd.
SGM
Use duplicolor bumper paint. It's designed to be flexible so it doesnt crack or peel when the lip is twisted or bent. It's got a nice flat black/gray color to it too. Certainly looks better than unpainted.
I painted mine myself using it and even with a mediocre spray job with only 2 coats of paint, it still hasnt cracked or bent. I bottom out all the time (unfortunately). Use a spray adherence promoter before the bumper paint for good measure.
FlaT FouR is offline   Reply With Quote
Old 03-07-2011, 07:31 PM   #25
05slprWRX
Member#: 243742
Yep just like I said bumper coating
Pics of Limited lip on 06-07 painted WRB singsifu Interior & Exterior Modification 2 11-15-2008 04:05 PM
I have been gone since April, How are you guys. Been busy boarding/ check it out THORIS Off-Topic 92 08-08-2008 01:57 PM
so does frye's have HL2 in stock or are you guys downloading it? Big_Hitter Texas Impreza Club Forum -- TXIC 24 11-18-2004 04:36 PM
Toluene.. where are you guys getting it for a good price? Big Turkey Texas Impreza Club Forum -- TXIC 16 05-25-2004 10:10 PM
What EGT's are you guys with Stage 0 are seeing?? WRBLUEWAGON Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 05-28-2002 02:09 PM
