Old 10-10-2011, 09:15 PM   #1
pillarguy17
Member#: 103392
Default 05 STi 5x114 knuckle to 04 wrx wagon axle? (front)
So here is an idea...
I want the 5x114 STi hubs, knuckles, bearings on the front of my 04 wagon 5 MT because they are more robust (less bearing issues). Planning for lots of track time in the wagon.
Assuming I have the 5x114 STi knuckles, bearings, hubs, will they mate to 04 wrx axles, or do I need to get 05 STi axles?
Will I need tone ring adapters? If I omit, will I be out abs?
I am only planning on upgrading the fronts, my wheels are dual drilled 5x100 and 5x114, 17x8, so I can still rotate tires.
I know I will need 05 STi suspension and brakes, that is fine, since I have not bought coilovers or bbk yet.
Thanks,
pillarguy17 is offline   Reply With Quote
Old 10-10-2011, 09:24 PM   #2
Wintershredder
Member#: 160089
2008 M5/330xi/328xi
Black/Black/White
Your axles wont work. Also, STi axles wont work with your 5 speed either(IIRC). It may work with the early 04 STi axles, however you would need tone ring spacers.
Wintershredder is offline   Reply With Quote
Old 10-14-2011, 10:00 AM   #3
pillarguy17
Member#: 103392
hmm, I have heard differently from someone else - 181stLeader - that it would work
any other input from anyone ?
Old 01-09-2012, 02:35 PM   #4
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
It will work front axles are ths sams just ths tone ring is in the wrong place you would need to get the 6 gun adapter, i think you could also just get 05-07sti axles
seanathanq83 is offline   Reply With Quote
Old 01-10-2012, 08:00 PM   #5
onefasazn
Member#: 45574
2003 NB2 E-Street
2004 GGA - Prodrive
LIC Motorsports also makes the tone rings. Little easier to get ahold of them too.
onefasazn is offline   Reply With Quote
Old 01-16-2012, 12:22 AM   #6
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
dont answer a question you know nothing about.
yup but Id use VV LIC as 6gun pretty much went down the doodoo hole.
op yes youll need to either use modded knuckles for you wrx struts or change to 05+ sti struts/ coilovers. brakes all mount the same but rotors would need redrilled to 114.3. Id also change to the 6mt front axles as they are rated for 400+ whp and have a WAY better cv. Find what your trans has , studs or plugins and get the same for axles or swap sundials to the newer style plugins. I think there are some 04s out there with stub style 5mts.
scby rex is offline   Reply With Quote
Old 01-19-2012, 06:45 PM   #7
svusoccer9
Member#: 111988
2006 WRX STi
Did you buy double drilled wheels? Or have them drilled?
svusoccer9 is offline   Reply With Quote
Fitment - 05 STi Perrin PSRS on 04 WRX Wagon relliMmoT Brakes, Steering & Suspension 2 02-14-2010 10:44 PM
05 STi wheel fitment on 04 WRX Wagon R&C_rallySS Tire & Wheel 5 09-27-2008 06:44 PM
STI rear sway bar fitment to 04 wrx wagon? tedski Brakes, Steering & Suspension 0 11-03-2004 04:26 PM
04 STi springs on a 04 WRX wagon? Unabomber Brakes, Steering & Suspension 4 04-12-2004 08:59 PM
04 STI Skirts on a 04 WRX Wagon pawwrx Interior & Exterior Modification 2 09-19-2003 02:44 PM
