Welcome to the North American Subaru Impreza Owners Club Thursday January 29, 2015
Old 10-11-2011, 10:21 PM   #1
Turbocrazy1
Member#: 297489
Default ver 3/4 into an 02 wrx
As the title says, anyone try to swap a ver3/4sti drivetrain into a 02 wrx? dose anyone have any info on wrx axles fitting the sti diff and gearbox, an are there any major differences in sensors things i should be aware of? I know a TGV delete will be mandatory with the sti manifold, and the plan would be to use all the wrx ecu bits. in another thread it was mentioned that the crank sensor and wheel would need to be swapped, but as for hard parts is it doable?
Also, before I get flamed outa here, Im fairly seasoned with swaps, but new to Subarus, and the reason for these questions is the fact I can get a 02 wrx cheap with a blown trans. I figure an STI block and gearbox are stout enough to hold up to my abuse and plans which include a goal of 370hp-400hp a 20g turbo and supporting mods...
Also, I feel the motor is going to be complicated with swapping all the sensors over and such, but im more concerned the trans, diff, and axles fitting.
Any imput is appreciated.
Thanks for the time guys
Turbocrazy1 is offline   Reply With Quote
Old 10-12-2011, 12:45 PM   #2
kheff46
Member#: 66739
2002 WRX wagon
V3-4 are the same as WRX axles(or forester/leggy)and tranny is also. R160=R160. the V3-4 are stronger and shorter FD which is nice for quickness. its a straight bolt on affair. you could also source another WRX tranny(stock or built) and save time swapping the diff, driveshaft, etc.
--keith
kheff46 is offline   Reply With Quote
Old 10-12-2011, 01:10 PM   #3
Turbocrazy1
Member#: 297489
Hey man, thanks for the replyi appreciate it. I thought that was the case, but didn't wanna blow money on something that won't work. As for rebuilds... they're all expensive, for 2k I can have an sti block, larger turbo, and a gear case that's assembled in a normal fassion as opposed to the wrx's clamshell design.... that was my thinking.... I could be totally wrong but even the m factory gears are almost 3k... and those seem to be the minimum for my needs... againg through the search bar I found that some think the shafts flex appart under load which causes the stripped gears, so I thought the ra sti swap would be my best and cheapest bet.
As for the motor? All the electronics should swap over right? (Asside from the IM)
Thanks Adam
Old 10-15-2011, 02:00 PM   #4
kheff46
Member#: 66739
2002 WRX wagon
elec. on the tranny? like switches, etc? iirc everything will swap over
--keith
Is it possible to swap an 04 STi console into an 02 WRX? adrive43 Interior & Exterior Modification 21 07-17-2009 05:36 PM
Installing an 08 Sti fuel pump into an 02 WRX Vlad Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-26-2009 09:55 PM
Ver 7 swap to an 02 WRX supersuby483 Subaru Conversions 3 01-18-2007 04:15 PM
will an 05 sti ebrake fit into an 02 wrx? blueandgold Interior & Exterior Modification 3 10-07-2006 03:51 PM
JDM VER. 3/4 INTO 2.5GT Legacy FastBlackLegacy Subaru Conversions 5 06-04-2005 01:27 PM
