Old 10-12-2011, 12:50 AM   #1
Kitty93
Member#: 260210
Default Speedo cable swap
Does a speedo cable from an 02 wrx and up fit a 93 JDM wrx?
Thanks!
Kitty93 is offline   Reply With Quote
Old 10-12-2011, 02:53 AM   #2
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
there is no speedo cable on an 02 WRX. for JDM imprezas, v4 and up were electronic speed sensors (no cable).
elislider is offline   Reply With Quote
Old 10-12-2011, 09:26 AM   #3
suberdave
Member#: 101865
88 GL-10 STi
but if it will better answer your question.
yes they will fit. if you pull the cable out the VSS will screw right in like wise, if you pull the VSS you can screw a cable in.
i am currently running a 1987 cable into a 2003 JDM Speed. and before that i had ti running into a 96 JDM 5 spee. and it works just fine.
-=Suberdave=-
www.suberdave.com
suberdave is offline   Reply With Quote
Old 10-12-2011, 10:49 AM   #4
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
Yup like suberdave said it will screw rite in. I was running a 06 Impreza-i manual trans in a 91 Legacy SS.
dangerousatom is offline   Reply With Quote
Old 10-22-2011, 09:15 PM   #5
Kitty93
Member#: 260210
Hate to sound like a noob but what is a VSS? And how do I remove it.
Old 10-22-2011, 10:00 PM   #6
Dominator
Member#: 156712
1991 Legacy SS
Pearl White
VSS = Vehicle Speed Sensor. It depends on what vehicle you are taking it out of. In the older cars, there is a VSS built into the speedometer gauge that the cable attaches to.
To answer your original question, probably not. I think the older one uses a cable where the newer ones are done by electric sensors.
Dominator is offline   Reply With Quote
longer speedo cable? AsphaltsCry Transmission (AT/MT) & Driveline 6 11-06-2011 09:08 PM
96 legacy 5mt>95 impreza speedo cable help bobturismo Transmission (AT/MT) & Driveline 10 01-06-2004 10:47 PM
Anyone using the speedo cable on their WRX swap? Aspen Subaru Conversions 1 10-08-2003 10:39 PM
Speedo cable part #? Legacy imprezza ciper Legacy Forum 1 06-17-2002 06:40 PM
pelz help speedo cable problem iceman Technical Forum Archive 0 07-06-2000 07:43 PM
