Old 10-12-2011, 11:12 PM   #1
tansui
Member#: 254072
2013 WRX Sedan
Default 3rd gear pull log question
I flashed to stage 1 a few days ago and right off the bat WOW what a difference! after about 50 miles of normal driving and no WOT. I did a 3rd gear WOT pull. (log found just below)
1st WOT pull log
https://docs.google.com/spreadsheet/...hl=en_US#gid=0
I thought it looked good (not really a qualified opinion) but i did notice some "fine knock learn" between 3300 and 4200 rpm. Not sure if this should be a concern I asked on forums if this was a normal thing, and have yet to hear a response. I turn now to NASIOC any ideas here?
Also worth noting is that I made a few runs since then and they seem to show progressively increasing "fine knock learn" and that I'm moving farther and farther away from target boost (16.5psi)
Here are the subsequent logs in order all 3rd gear pulls with Cobb stage 1 map.
2nd WOT pull log
https://docs.google.com/spreadsheet/...poaXc&hl=en_US
3rd WOT pull log
4th WOT pull log
https://docs.google.com/spreadsheet/...RCYkE&hl=en_US
Any help would be greatly appreciated
tansui is offline   Reply With Quote
Old 10-13-2011, 09:32 AM   #2
Cobb Tuning
Member#: 4803
Are you running the 93 octane map?
Bill
Old 10-13-2011, 11:28 AM   #3
tansui
Member#: 254072
2013 WRX Sedan
Yes I am, Shell 93 octane on the Stage 1 93 MTv300 map
Old 10-13-2011, 12:32 PM   #4
Cobb Tuning
Member#: 4803
You have some fairly consistent fine knock learning at high load, but it is only a single count and begins to learn back to zero. Sometimes you get this specific correction on these cars that doesn't respond to timing changes. I would try reflashing the 91 octane map (while still running 93 octane) and see if it improves. If not, I wouldn't worry about it.
Bill
Stage 2 STI 07 log E-Tuned 3rd gear pull Defmxtones AccessPort 2 06-17-2009 02:40 PM
Stage 2 STI 07 log E-Tuned 3rd gear pull Defmxtones Open Source Reflashes 17 06-03-2009 10:14 AM
2nd and 3rd gear pull log economy AP map vf30 boost too high ? bozz AccessPort 4 04-30-2008 03:02 PM
Did a few 3rd gear pulls on my 03 WRX if you guys want to see :) *LOGS druxboyz Commercial ECU Reflashes 11 01-14-2007 09:39 PM
3rd gear pull *csv file using mps utec logger prometheum UTEC 2 05-22-2006 02:08 PM
