Old 10-13-2011, 12:50 PM   #1
Alistairh
Member#: 268286
2011 STi
Dark Grey
Default Going WTA from FMIC.
I've got a highly modified 2011 STi w/ meth injection using Cobb.
Going to be ditching my FMIC for a WTA. If all goes as planned, I should be going from ~4 Feet of intake plumbing to about 6 inches.
I imagine for optimal performance, I'll need to get it retuned yet again, but will the car be able to compensate for the changes I've made after the MAF?
Alistairh is offline   Reply With Quote
Old 10-14-2011, 07:13 AM   #2
Cobb Tuning
Member#: 4803
Primarily you might have to look at boost control. Also some tunes mess with tip-in enrichment to try to combat the rich dip seen with FMIC that you would not have with a TMIC. As long as the intake remains the same as what the map was tuned for, you should not have an issue with fueling otherwise.
Bill
Old 10-18-2011, 08:15 AM   #3
Mansour14
Member#: 279796
2004 Wrx
Meth is really risky mate. One miss-spray and there goes ur motor.
Mansour14 is offline   Reply With Quote
Old 10-18-2011, 12:39 PM   #4
Alistairh
Member#: 268286
2011 STi
Dark Grey
water/meth? with a 60/40 mix?
Old 10-18-2011, 01:04 PM   #5
slaytalera
Member#: 163816
1999 Legacy Outback
You will absolutely need a tune with that much tubing gone, your gonna have quite a bit less lag so the fueling will need to be adjusted
slaytalera is offline   Reply With Quote
Going from fmic to tmic what you guys think gtasti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 32 12-27-2009 12:40 PM
FS: Go fast goodies! FMIC, Pinks, VF39, Walbro, Upipe! Matth3w Engine/Power/Exhaust 64 03-13-2007 08:22 AM
what to do with WI when going with a FMIC? Beeker Water/Methanol Injection, Nitrous & Intercooler Cooling 11 08-07-2005 12:11 PM
Spotted Savka Going west from NYC from Tunnel WRBLUEWAGON Tri-State Area Forum 26 01-23-2003 02:39 PM
Heitzler is going, going gone from CART! Onederer Motorsports 7 12-06-2001 07:49 PM
