Old 10-13-2011, 10:02 PM   #1
wrx_traut
Member#: 187960
2011 WRB STI 4dr
96 WRX
Default blown ej20
So I’m looking at buying a Impreza with a ej20 swap from a legacy. He says the engine blew up, it runs but barely. Anything I should know about these engines? Are they worth rebuilding or would it just be easier to do another swap. Just looking for a somewhat reliable car I can rally-x and ice race with.
wrx_traut is offline   Reply With Quote
Old 10-15-2011, 02:04 AM   #2
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
no don't do it.
You have neither the time or the "know-how" to waste yourself on this.
walk-away.
DHRDAN is offline   Reply With Quote
Old 10-17-2011, 08:53 PM   #3
wrx_traut
Member#: 187960
2011 WRB STI 4dr
96 WRX
eh.
I'm think im gona buy it. First time I looked at it the battery was dead, so I went to take a second look at it and brought a jumper. It started right up. Idled fine just smoked a bit. I dont think it is actually blown. I'll buy it, take a shot in the dark. I guess a compression test will tell all.
Old 10-17-2011, 09:40 PM   #4
vica153
Member#: 76586
2006 9-2x Aero
If it still runs without nasty noises, then it's probably fixable.
If you can get a good deal on it and its just a backup/fun car, then I'd say go for it.
Rebuilding an engine is more about having the money, space, time, and tools than having the "know how". It's 2011. The ej20 rebuild has been done more than a few times. Any "know how" can be found with a quick search on the internet. If not then learn the hard way, thats the fun part.
vica153 is offline   Reply With Quote
Old 10-18-2011, 01:25 AM   #5
suberdave
Member#: 101865
88 GL-10 STi
and if you dont want to rebuild it... PM me ill make you a good deal on an EJ20 Short block...
-=Suberdave=-
www.suberdave.com
suberdave is offline   Reply With Quote
Old 10-19-2011, 10:26 PM   #6
wrx_traut
Member#: 187960
2011 WRB STI 4dr
96 WRX
I'll let you know, thanks.
I bought it for $900. It’s a 98 with a rs front end swap. I haven't had any time to dig into it yet, but from what I see the car is a complete cobble job. Never rebuilt an EJ before just a few dirt bikes, so this will be a good learning experience. If it turns out to be a complete mess I will swap what I can into my 95 and part out the rest.
Old 11-14-2011, 10:23 PM   #7
wrx_traut
Member#: 187960
2011 WRB STI 4dr
96 WRX
Yep, has a dead cylinder. I did a compression test a few weeks ago. 170,150,160, and 0. Now when I get some time this winter I will tear it apart and see what kind of damage is done to the cylinder. Hopefully its rebuildilble.
If the block is junk, I think I might just turbo the 1.8. Have to do some more research first to see if it is feasible. Has anyone done a ej18 - ej20g hybrid? Swap the heads, and everything else to the 1.8 block?
Old 11-15-2011, 12:20 AM   #8
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
You can't use EJ20G heads on an EJ18 the biggest diameter of the combustion chamber in the head is 90 mm and the bore of the block is 87.9 mm.
Marnix is offline   Reply With Quote
Old 11-17-2011, 09:49 PM   #9
wrx_traut
Member#: 187960
2011 WRB STI 4dr
96 WRX
Hmmm, I see people putting EJ22t heads on the EJ18. What makes those work with that block?
Old 11-18-2011, 05:55 AM   #10
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
They don't (work well), the bore sizes also don't match.
Old 11-18-2011, 02:18 PM   #11
Dominator
Member#: 156712
1991 Legacy SS
Pearl White
Sorry to hear about your motor, but that's whey you got it cheap. Anyway, about the turbo 1.8, check out Joejoe's thread. It's probably the most well documented ej18t build out there. Here is a link.
http://www.rs25.com/forums/f7/t81773-project-ej18t.html
Dominator is offline   Reply With Quote
Old 01-21-2012, 06:53 PM   #12
wrx_traut
Member#: 187960
2011 WRB STI 4dr
96 WRX
I finally got around to tearing this thing apart.
Also found the oil squirter in the bottom of the oil pan.
Good news is the cylinder is not damaged.
Old 01-23-2012, 08:37 PM   #13
klys
Member#: 225974
2012 Impreza WRX
Plasma Blue Pearl
I rebuilt mine when a conrod bearing to crank disentegrated... I've got my crankshaft chromed and polished, and all the other surface ground ... finally got under sized acl bearings ... and new oem rings
for now, I need to install the oil pan, oil feed... and heads. and I should be ready to reinstall it in a 2004 WRX
btw it's a ej205 that I'm rebuilding..
hopefully everything will work fine.
it was pretty straight forward to do, so if you got the tools.. and patience and the shop manual, you shouldn't have any problems.
make sure that you replace you piston or pistons with proper sized pistons. I don't know for your EJ20 but in my case it had A and B pistons which is due to the tolerance size of piston to cylinder
if you need help or insights let me know
klys is offline   Reply With Quote
Old 01-28-2012, 10:21 AM   #14
wrx_traut
Member#: 187960
2011 WRB STI 4dr
96 WRX
It will be my first rebuild but I should be able to get it done. I think I am going to throw in a set of Wisecos and I am debating whether to use the stock rods or get some eagles. I don’t want to go crazy on the build because I don’t think I will ever need it. But then I always go back to, well since I have it apart I might as well.
Old 01-28-2012, 11:03 AM   #15
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Then at least get New Age STI rods (USDM EJ257 work fine). Stock rods are crap. They usually let go before the pistons do but it seems you had a fuelling issue there.
Old 01-28-2012, 11:47 AM   #16
wrx_traut
Member#: 187960
2011 WRB STI 4dr
96 WRX
I thought about those too. I think it was a multiple of things that caused it to blow a hole through the piston. 1. Cylinder 4 fuel issue. 2. Oil squirter fell out, not cooling the piston. 3. Manual boost controller. 4. Low coolant, Overheated.
wtb - blown ej20 drunkguy Private 'Wanted' Classifieds 3 04-19-2004 02:22 AM
blown ej20 for sale, more. DubuRX South West Impreza Club Forum -- SWIC 9 02-01-2004 04:48 PM
WTB Scrap or Blown EJ20 For a Display Quick Time Private 'Wanted' Classifieds 0 01-08-2004 01:04 PM
Blown EJ20 USDM WRX Longblock kaos200 Private 'Wanted' Classifieds 5 11-22-2003 10:24 PM
anyone know where a blown EJ20 might be? Bankheist Texas Impreza Club Forum -- TXIC 25 04-03-2002 03:58 PM
