Old 10-14-2011, 12:59 AM   #1
lDeez lNutz
Member#: 94339
2005 STi
Question 2005 sti @ Stage 1 (requesting feedback on datalogs)
2005 sti
completely stock other than AP v2
flashed to ACN91 map running on 91 octane CA gas
Below datalogs were done in 3rd gear (even though the log shows 2 here and there for some reason)
Datalog 1
Datalog 2
I seem to be overboosting a bit at just under 17psi (should probably try LWG map next), but other than that i'm more concerned about the -4.2 fine knock learn i'm seeing at WOT. i've read this is high enough to be a concern, but could also be due to the fact that i might have some excess engine noise for some reason, maybe something is loose inside my bay like a heatshield?
would appreciate some feedback as i've only had this for about a week now, still learning about this and i've done some searching around already.
car pulls REALLY strong right now
thanks
lDeez lNutz is offline   Reply With Quote
Old 10-14-2011, 07:03 AM   #2
Cobb Tuning
Member#: 4803
Hi there. I'm unable to view the files. Can you change the permissions to public?
Bill
Old 10-14-2011, 05:47 PM   #3
lDeez lNutz
Member#: 94339
2005 STi
Bill
oops. try now. thanks.
Old 10-14-2011, 06:08 PM   #4
Dj Xtz
Member#: 183720
2003 Impreza WRX
Sonic Yellow w/DGM 2-tone
Try reseting the ECU and datalogging again to see if it goes away. Also check the DAM as a parameter to datalog on your AP datalog list that way we could see if the ECU is happy or not .
Miguel
Dj Xtz is offline   Reply With Quote
Old 10-15-2011, 08:28 AM   #5
Cobb Tuning
Member#: 4803
I would reset the AP log list - you are missing some key parameters in the log. The -4.2 fine knock learning at high load is concerning. It could be something rattling in the engine bay (loose uppipe heatshield, loose turbo heatshield, for example), but you would generally see the extreme corrections elsewhere. Don't reset the ECU just yet and do some general driving and see if the extreme corrections show up there as well. The other thing you want to check after a good amount of driving (without resetting the ECU or changing maps) is your A/F Learning 1 A, B, C, D values. These should generally be within +/- 8% or so. Otherwise, you could have an issue that is impacting fueling. You might also be dealing with some crappy gas. If you know of a brand in your area that other enthusiasts have had luck with, I would switch stations.
Bill
Question on 2005 STi Stage 2 Slowness? Senfinger Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 04-07-2010 11:51 AM
2005 STI Stage 2 Utec & TurboXS TB Exhst what next? oosoceroo UTEC 2 03-22-2008 05:50 AM
2005 STi Stage II Silver 4 Sale etirums Private Vehicle 'For Sale' Classifieds 4 11-04-2007 01:33 AM
2005 Sti, Stage 2, dyno numbers whiteguyblacksti Proven Power Bragging 9 07-01-2006 10:22 AM
2005 STi Stage 2 protune by Jorge **video & scan** Carizme Proven Power Bragging 6 05-15-2006 02:46 PM
