Welcome to the North American Subaru Impreza Owners Club Tuesday June 30, 2015
Old 10-14-2011, 04:01 PM   #1
sleepingpeople
Member#: 293458
2002 wrx
obp
Default question about map/tune
hey guys i have a cobb V1 accessport on my 02 wrx wagon stage II. I am running the 91 map, but most of the gas around me is 92, so i notice im running a little rich. If i do the 93 map though i would be set a bit funky too im guessing . What is the proper map i should be using as a 400$ tune isnt quite in the budget rn.
sleepingpeople is offline   Reply With Quote
Old 10-14-2011, 04:54 PM   #2
jayman4312
Member#: 228784
2004 wrx
black, stage 2+
use the 91 map. alittle rich is a lot better than a little lean. a little lean can mean detonation, which means new engine. But i would start saving for a custom tune, but then again I also have no idea what your mods to the car are so....
jayman4312 is offline   Reply With Quote
Old 10-14-2011, 09:15 PM   #3
sleepingpeople
Member#: 293458
2002 wrx
obp
• Rebuilt front brake calipers (Raybestos)
• Rotors (F – Centric Premium, R – Napa Premium)
• Brake Pads (Stop Tech Street Performance (D721 F, D770 R))
• Rear Subframe Bushings (Kartboy)
• Radiator (Mishimoto)
• Radiator Hoses
• Thermostat (Gates Racing)
• A/C Tensioner and belt
• Up Pipe (Perrin)
• Intercooler Hoses (Mishimoto)
• 02 Sedan Rear Sway Bar
• Shifter Busings (Perrin)
• Shift Knob (Killer B)
• COBB Accessport V1
• TBE Exhaust (HKS/Custom Mid/SPT Axle back)
• Hella SuperTones
Old 10-15-2011, 12:11 AM   #4
philly15
Member#: 223137
14' super ultimate
race car project
In the map notes it says you can run 91 or 92 with the 91 map and 93 or 94 with the 93 map just so ya know
philly15 is offline   Reply With Quote
Old 10-15-2011, 03:28 AM   #5
sleepingpeople
Member#: 293458
2002 wrx
obp
perfect thank you i appreciate the info!
question about maps raider1v1 AccessPort 8 08-22-2007 11:51 AM
noob utec question about map "0" imprezaBlue Engine Management & Tuning 17 01-20-2006 05:25 PM
UTEC gurus! Question about MAP sensor + UTEC's FCD x99percent Engine Management & Tuning 7 12-16-2004 03:49 PM
Question about maps and removing engine codes dawoniyi Engine Management & Tuning 2 12-10-2004 12:32 AM
Question about MAP sensors and the 2.5L SOHC subysouth Normally Aspirated Powertrain 12 11-07-2003 07:01 PM
