Welcome to the North American Subaru Impreza Owners Club Thursday January 29, 2015
Old 10-15-2011, 11:41 AM   #1
_nut_
Member#: 259980
2011 WRX Ltd Sedan
Default iPhone 4s BT pairing issue
Since none of the other threads tackle this... I thought I would bring it up. Has anyone else had issues pairing their 4S to the 2011+'s? I had/have a brick of a 3GS now that never had any issues. Just got the new iPhone yesterday...and it doesn't even see the bluetooth in the car. Anyone heard/seen similar - or am I being a total douche and missing some huge step that I forgot / dont see in the manual?
Thanks, and flame on if you feel like flaming.
_nut_ is offline   Reply With Quote
Old 10-15-2011, 01:07 PM   #2
emazz104
Member#: 281811
04 WRX
World Rally Blue
I head it was something with the iPhone firmware, I thought there was a thread about somebody have problems with an iPhone 4, but obviously your firmware would be up to date, and Apple should release a new firmware soon, but if that doesn't fix it, I believe I remember reading that the dealer has to flash it.
emazz104 is offline   Reply With Quote
Old 10-15-2011, 07:26 PM   #3
SawksFan562
Member#: 292352
2011 Impreza WRX
I'm glad somebody else brought this up. I've been pairing and deleting my phone over and over again. I had no issues at all with the updated iOS on my iPhone 4. It must be the new 4s.
SawksFan562 is offline   Reply With Quote
Old 10-15-2011, 09:24 PM   #4
VinSVT
Member#: 77637
iPhone 4s is the FIRST phone ever to use BT 4.0.
Most phones currently use BT 2.1 or 2.2.
iPhone 4 = Bluetooth 2.1 + EDR wireless technology.
iPhone 4s = Bluetooth 4.0 wireless technology.
http://www.apple.com/iphone/iphone-4/specs.html
http://www.apple.com/iphone/specs.html
Something is going to need an update before it works.
VinSVT is offline   Reply With Quote
Old 10-15-2011, 11:09 PM   #5
willoc
Member#: 63485
2011 WRX (retired)
2015 WRX LTD, ice silver
My 4S is synching with no issues - however it is not automatically connecting every time I start the car - still working on this issue will update soon...
willoc is offline   Reply With Quote
Old 10-16-2011, 01:09 PM   #6
criz
Member#: 56497
2008 WRX STi
My 4S suddenly started to cycle between detached and attached last night after working flawlessly since I got it on Friday.
This is using the iPod interface for the 08 standard head unit...
going to restore the software and see what happens
criz is offline   Reply With Quote
Old 10-16-2011, 02:30 PM   #7
gunkadoodah
Member#: 250879
2012 STI
I'm having the same issue with the 4S and my 2011 WRX. Won't reconnect when I start the car. The initial pairing doesn't seem too bad, but placing a phone call is pretty bad. At first the other end won't be able to hear me, then it just stops working altogether.
I checked the Apple forums, and there seems to be no solution thus far.
gunkadoodah is offline   Reply With Quote
Old 10-16-2011, 05:52 PM   #8
willoc
Member#: 63485
2011 WRX (retired)
Hey gunkadoodah, you are close enough to 1 Infinite Loop, go camp out at their front door and get an answer tomorrow Actually my wife works for Apple here in Austin, TX she might be able to get a word in with the engineers...stay tuned...I'm sure it's going to be fixed in a future iOS 5 update.
Old 10-16-2011, 06:35 PM   #9
sizemic1
Member#: 270669
2011 WRX Sedan
Stg 2 Phatbotti e-tuned
For some having BT issues, the car is likely looking for your old phone as your primary BT device. Make sure you removed all references to your old phone in your stereo before attempting to pair the new phone. Otherwise, you'll have to manually pair it everytime you turn on the car. I have no idea if this is a similar issue with BT v.4 or not.
On a side note, iOS 5 on a standard iPhone 4 now displays Artist, Album, and Track info when using BT-A. Kinda neat.
sizemic1 is offline   Reply With Quote
Old 10-16-2011, 06:53 PM   #10
CJ.R6.SD
Member#: 288282
2011 WRX Hatch
WAY COOL!
I just finished updating my iPhone 4 to iOS5 and after I saw this I had to run out and see it for myself.
CJ.R6.SD is offline   Reply With Quote
Old 10-17-2011, 10:47 AM   #11
iRonin
Member#: 267774
2010 WRX
Electric Boogaloo Blue
Bluetooth SIG updates are standardized backwards compatible. He won't get the perks of a 4.0 BT sys (lower power consumption, etc.), but he won't lose the perks of a 2, 2.1, 3.0 system because he's on 4.
iRonin is offline   Reply With Quote
Old 10-17-2011, 10:47 AM   #12
iRonin
Member#: 267774
2010 WRX
Originally Posted by CJ.R6.SD View Post
WAY COOL!
Wish it would transmit Pandora info... I'm thinking a Pandora update could fix this though.
Old 10-17-2011, 01:33 PM   #13
jose2011wrx
Member#: 280059
Same problem here, need to pair it manually each time..
Rdio now transmits the artist info
jose2011wrx is offline   Reply With Quote
Old 10-17-2011, 01:41 PM   #14
my name is joe
Member#: 171412
most technologies should be backwards compatible.. i'm sure theres a way around it
my name is joe is offline   Reply With Quote
Old 10-17-2011, 01:44 PM   #15
jose2011wrx
Member#: 280059
I've just reset all my network settings on my phone, so I'll give it a try and update once i can get to my car
Old 10-17-2011, 01:48 PM   #16
not2fast
Member#: 230574
2013 MB C300
3.5L
No issues on my 4S with BT
Connects automatically, shows track info etc...
not2fast is offline   Reply With Quote
Old 10-17-2011, 03:32 PM   #17
gunkadoodah
Member#: 250879
2012 STI
Good to see that not2fast has it hooking up with no issues. not2fast, did you do anything specific, or it just worked?
@sizemic: the only reference i could remove was the "delete memory" function in the BT menu. nothing else. i did that many times, but still many problems with the connection.
Old 10-17-2011, 04:19 PM   #18
not2fast
Member#: 230574
2013 MB C300
3.5L
nothing special..
just went through the setup verbally.
I do have an idea though...do you have a case on your phone?
If you do, try without it for the pairing.
Old 10-17-2011, 04:47 PM   #19
jonklein611
Member#: 117776
2011 WRX Limited 5dr
WR Blue Pearl
Are you pairing with the BT Audio side or the Phone side?
jonklein611 is offline   Reply With Quote
Old 10-17-2011, 04:57 PM   #20
not2fast
Member#: 230574
2013 MB C300
3.5L
When you do phone it does both
Old 10-17-2011, 05:05 PM   #21
jonklein611
Member#: 117776
WR Blue Pearl
Yes, but I've seen people try to do just the audio side. Which is why I ask.
Old 10-17-2011, 05:56 PM   #22
gunkadoodah
Member#: 250879
2012 STI
For the initial pairing process, I select the CAR_M_MEDIA from my iPhone and punch in the access key. Once it's paired, I tried both ways, but it only works if I go from the BT Audio side. On top of that, I must connect within ~10 seconds of turning on the car, otherwise the BT Audio menu says "Unavailable" or something like that.
So it just doesn't work...
Old 10-17-2011, 07:10 PM   #23
not2fast
Member#: 230574
2013 MB C300
3.5L
To be honest I did not know you could do it that way.
Old 10-17-2011, 09:22 PM   #24
HO4TW
Member#: 298121
2011 Forester
I have found that if my wifi is on, on my iphone 4 (Verizon) i have issues with Bluetooth my solution turn off wifi unless I need it!
HO4TW is offline   Reply With Quote
Old 10-17-2011, 09:59 PM   #25
jonklein611
Member#: 117776
WR Blue Pearl
Yeah it's meant for Bluetooth enabled MP3 players and whatnot.
For those having pairing issues, do you leave Bluetooth on all the time or just when you get in the car?
I leave mine on and it takes around 10-15 seconds for it to auto connect.
2011 WRX: iPhone plays music when BT is paired...disable? 0BlueSTi4 Car Audio, Video & Security 35 01-30-2012 10:11 PM
New STi iphone/BT issue TenPSI Car Audio, Video & Security 12 10-23-2011 08:52 PM
Rumors DON'T Get Any HOTTER This! Will The iPhone 5 And 4s Obsolete SYNC And ALL Othe AVANTI R5 Non-Subaru News & Rumors 46 10-08-2011 05:01 AM
a question about iphone 4s Meat Supply Off-Topic 7 12-28-2010 10:29 PM
