#1 |
Member#: 170475
Vehicle:1995 GF8 WRX Wagon GC8 STi RA ver. II |
Car: 1995 JDM WRX wagon
Issue: Randomly won't start. Background: Occasionally won't start. If I sit there and crank it for a while it will sometimes start up and once started it will run fine. I did a search but the threads I cam up with were constant no start issues, and usually after something was changed. The only thing I changed were the plugs (to OEM NGK's) and this issue predated the spark plugs.
#2 |
Member#: 253937
W. Canada
Vehicle:1995 WRX White |
So to start a car you need air, fuel and spark. Spark includes coil packs! As well as a battery and starter motor I guess.
Maybe you're injectors suck or your fuel pump doesn't deliver. Have you tried turning your key to prime the pump first before starting your car every single time (can you hear the fuel flowing)? You need to start coming up with a consistent method for starting your car and then from there, think about if the engine is hot or cold, maybe that makes a difference. Then it will be easier to start troubleshooting. |
#3 |
Member#: 204358
SCIC
Vehicle:01 2.5RS W/ EJ257 Black |
100 bucks says you have wiring problems... whomever did your conversion is to blame.
wiring problems. could be some random ground, could be some random relay... hell it could be a fuse. |
#4 |
Member#: 148743
Vehicle:02 WRX & 99 RSTI Sedona |
Wiring....I would look at cam/crank position sensor.
#5 | ||
Member#: 170475
But then why would it work fine once running if the timing is off. |
#6 |
Member#: 258224
VIC
Vehicle:1995 Impreza WRX STI 2009 Honda Ruckus |
My car did the same thing. Would randomly not want to start, then wait 5, 10 minutes or w/e and it would start right up. Ended up being a bad crank position sensor
#7 | |
Member#: 257043
VIC
Vehicle:1993 JDM WRX Wagon Black |
This definetely sounds like fuel to me. I would be looking to test fuel pressure and then perhaps replace the FPR. Also does it start easier with a tank of fuel system cleaner? You may be experiencing a double whammy of clogged injectors and insuffecient fuel pressure. I would replace the fuel filter, check fuel pressure with an inline fuel pressure guage then look into a new FPR and as a last resort a new fuel pump. Alot of guys jump straight to a new fuel pump or a walbro 255lph. The new pump is fine and it may improve starting but its really just moving a greater volume of fuel to compensate for insuffecient fuel pressure. I doesnt fix the actual problem and is sometimes a waste of a perfectly good pump. |
#8 |
Member#: 159682
NESIC
Vehicle:1995 WRX |
Nah, the check valve in the old pump is probably bad. It lets the fuel in the lines bleed back to the tank. That's why it starts if you prime it a few times by turning the key on and off before cranking.
#9 |
Member#: 133923
NWIC
Vehicle:03 Legacy GT wagon I love goooollllllllddddd |
who let DAN back in here
the guy has a legit car, he's in Canadathings to check have been stated already. coilpacks (look for cracks), fuel filter, crank/cam sensor, and check your grounds on the strut tower to make sure they are clean (take them off, sand a bit, put back). |
#10 | |
Member#: 257043
VIC
I was also doing the multi-priming startup until I replaced my fpr. Regardless its good to check for proper fuel pressure. Once you have good fuel pressure its handy to run injector cleaner through. In a turbocharged engine air is assumed. Once you are sure that fuel isnt an issue you want to look at spark. Spark isnt something that would be effected by multipriming the fuel pump. Thats going to be a fuel pressure issue either caused by the pump or the fpr. Best to test with an inline fuel pressure guage at the very least to determine if after replacing a part that your issue is actually fixed. New parts are shiny but if the old part isnt broken your issue isnt fixed. |
#11 |
Member#: 170475
Strange but my GC8 sedan seems to be having trouble starting too. Even when I prime for 5 sec, it will start and then die out. I need to crank it twice to get it to start every time. These are low mileage cars too, the GF8 has 22K miles and the GC8 has 4K miles. Come to think of it the GC I had a couple years ago used to need to be started twice as well.
There must be a very common issue and solution to this problem. |
#12 | |
Member#: 257043
VIC
#13 |
Member#: 170475
OK so it is not the fuel filter, I replaced that and it seemed to work fine for a week. Then I drove to A&W ate a burger and then the damn thing wouldn't start. I had to walk home.
I got a drive back the next day and it started up fine. I should replace the Fuel Pressure Regulator next? What North American FPR will replace the stock EJ20G? |
#14 |
Member#: 257043
VIC
For me it was so big a pita to find an oem fpr that i got an aftermarket fpr. So first make sure fuel pressure is the issue. Get a fuel pressure guage hooked up so you can see what your starting fuel pressure is and what fuel pressure you are getting when it fails to start.
#15 | |
Member#: 123362
Vehicle:'93 Crapcan, '98L Sold, '04 STi - Sold |
#16 |
Member#: 170475
| Thread Tools | |
| Display Modes | |
| Idling/No start Issue. ECM Bad? | BonesXMahones | Electrical & Lighting | 7 | 03-13-2012 01:19 PM |
| No start issue, out of ideas | 05_LGT_AT | Factory 2.5L Turbo Powertrain | 3 | 09-09-2011 11:13 PM |
| 96 Legacy with odd no start issue. | quattroNoNo | Legacy Forum | 5 | 04-27-2011 12:46 PM |
| Boost issue on JDM 95 2.0 | Not All There | Pre-2002 Factory Turbo Powertrain | 4 | 03-07-2011 09:51 PM |
| 02 WRX AEM with no start issue. Please Help! | 0225wrx | Other Engine Management | 10 | 01-14-2011 09:00 AM |
