Welcome to the North American Subaru Impreza Owners Club Tuesday April 21, 2015
Old 10-15-2011, 08:15 PM   #1
rideAC1
Member#: 210441
2002 Tarmac SpecC RA
Default CEL P0118...how to fix?
Yes, I've searched this website and the internet for the answer but haven't been successful yet.
So I just got done putting my intake manifold back on my 2002 WRX after removing the TGV's and doing a couple other little things, and once it got started up it is throwing the P0118 coolant temp circuit high input CEL. I've searched all afternoon for a fix but nothing serious came up. I refilled my coolant after the intake mani and everything was put back on. Is it possible to have an air bubble in the coolant system to cause this code? I've checked the connection to the sensor which from searching I believe to be one of the 3 small connections just behind the water pump and alternator onto the block. I unplugged and plugged them back in and rechecked the code with my Accessport and the 0118 is still coming up. Also, my water temp gauge (oem) is flatlined...which I'm sure is related to the sensor or wire being disconnected.
Is the location I mentioned correct as to the location of this water temp sensor? Is there another connection to this sensor to check some place else?
I drove the car around for like 5 min to see if the coolant could be "stirred up" from getting it warmed up and moving, but no luck.
rideAC1 is offline   Reply With Quote
Old 10-15-2011, 08:36 PM   #2
Wile
Member#: 84876
Something similar happened to my Brother-in-law.
Can't remember what he did.
I'll call him.
Wile is offline   Reply With Quote
Old 10-15-2011, 09:44 PM   #3
toconn
Member#: 166656
2002 WRX Wagon
Have you reset the ECU again after any of these attempted fixes?
toconn is offline   Reply With Quote
Old 10-15-2011, 10:27 PM   #4
rideAC1
Member#: 210441
Yes. The CEL still occurs after a ECU reset.
The cooling fans run constantly too with this CEL.
No fun.
Old 10-16-2011, 02:13 AM   #5
PlasticFoamMan
Member#: 197764
2002 Nissan Frontier
buh bye WRX :(
http://www.rs25.com/forums/f72/t1368...input-ect.html
This may help. Sounds like it may have been disconnected or now a loose connection as you put everything back together (gc fwiw but I'm sure things haven't changed much).
PlasticFoamMan is offline   Reply With Quote
Old 10-16-2011, 09:18 AM   #6
CosmoTheCat
Member#: 3409
1998 Ram 2500
Green.
I'm pretty sure it's not in the block, but rather in the coolant crossover pipe between the block and intake manifold. Look for a brown connector iirc.
CosmoTheCat is offline   Reply With Quote
Old 10-16-2011, 04:23 PM   #7
rlloft84
Member#: 280236
09 WRX Wagon
Gunmetal
The p0118 is coolant temp. Sensor signal high. Sometimes its low coolant... in my experience it usually a sensor.
rlloft84 is offline   Reply With Quote
Old 10-16-2011, 04:25 PM   #8
rlloft84
Member#: 280236
09 WRX Wagon
Gunmetal
..Sry..or connection
Old 10-16-2011, 05:48 PM   #9
rideAC1
Member#: 210441
Thanks everyone for the help. It was the connection of the wire harness to the sensor on the crossover pipe...I simply didn't connect it when I put the intake manifold back on. It's a super pain to get to and not noticeable to realize it was even disconnected; I had to take off the sensor, wires, and hoses that are between the water pump and the alternator in order to even attempt to see the coolant sensor...and it's a nice little spot to try and get your hand in there to put the triangular plug back on.
Old 10-16-2011, 06:58 PM   #10
CosmoTheCat
Member#: 3409
1998 Ram 2500
Green.
Yup, that's a bugger of a sensor to forget once you get it all put back together.
CEL Blinking... how to fix it aferrari88 Newbies & FAQs 11 11-23-2008 05:03 PM
weird cels not sure how to fix. stiffler Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-11-2006 06:46 AM
How to fix Cel P0038 r8c3w1tm3 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 12-13-2005 10:11 PM
I am stumped! HELP! How to fix this CEL? Dougeefresh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-24-2003 07:18 PM
How to fix this CEL code? juztin180 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-22-2002 10:35 PM
