Old 10-16-2011, 06:11 PM   #1
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Default 2008+ HID Retrofit Aiming Instructions/How-to?
I went through the tacomaworld group deal for the "The Retrofit Source" RetroQuik HID setup. They are in and installed and working, but I can't find a good how-to for aiming a retrofit kit, particularly since the TRS kit makes you completely abandon the OEM aim settings.
I found this how-to:
http://www.bikes-n-spikes.org/sti/hla/hla.html
Is that the best guide for aiming a retrofit?
Edit: Also found this on daniel stern:
http://www.danielsternlighting.com/tech/aim/aim.html
phenryiv1 is offline   Reply With Quote
Old 10-16-2011, 10:13 PM   #2
infinite012
Member#: 74392
2015 Forester
General rule is park your car perpendicular to a flat, white wall.
Mark where your headlights shine.
Drive straight back 25 ft. Aim your lights to the same spot you marked earlier.
Now lower the lights from that mark by approximately 2 inches.
This all assumes an ideal flat road and wall.
infinite012 is offline   Reply With Quote
Old 10-17-2011, 09:30 AM   #3
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Thank you. Jives with what I saw before, but I did not know if there was a horizontal aiming guide, though I don't know how on/off the horizontal aim might be after the retrofit.
Old 10-17-2011, 11:17 AM   #4
Ric WRX
Member#: 187009
2008 WRX Sedan Prem
VF52, CAMTuned, Stage 2
Go to HIDPlanet.com and look for aiming.
Ric WRX is offline   Reply With Quote
Old 10-17-2011, 11:26 AM   #5
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
It says that it varies by model.
http://www.hidplanet.com/forums/show...HID-headlights
Old 10-17-2011, 01:59 PM   #6
infinite012
Member#: 74392
2015 Forester
Horizontal aim should be straight. What I mean is, when you're parked up against the wall, the lights should point approximately straight forward. That's where you want the steps of your cutoff.
There will be two individual steps. If they come together, you've done it wrong. If one is higher than the other, you've done it wrong.
Old 10-18-2011, 03:26 PM   #7
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Found a daniel stern link. Added to post 1.
2008 HID retrofit Duvanator Interior & Exterior Modification 183 04-15-2014 11:12 AM
STi projector HID retrofit color question DLUX WRX Electrical & Lighting 3 08-03-2003 01:21 PM
2003 WRX HID retrofit twg Electrical & Lighting 4 05-17-2003 12:21 AM
HID retrofit kit on stock WRX headlights? Sideways Interior & Exterior Modification 2 10-10-2002 05:08 PM
anybody want to help with a HID retrofit on my car? Sideways North West Impreza Club Forum -- NWIC 3 10-10-2002 12:28 PM
