Old 10-17-2011, 11:14 AM   #1
Cobb Tuning
Member#: 4803
Default READ THIS FIRST: How to datalog and what to look for
Welcome to the first episode of Ask COBB! This episode covers the ins-and-outs of Subaru AccessPORT Data Logging and analysis to determine the health of your car and your tune.
This video is in HD, so for best video quality, be sure to select 1080p resolution and watch in full screen!
Remember that Off-The-Shelf Maps, including High Wastegate and Low Wastegate alternate maps can be downloaded from our AccessPORT Map Database at http://www.cobbtuning.com/subaruotsmaps. The Map Notes are downloadable from the same location and will give you a good understanding of map requirements, power output and target boost levels.
Let us know what you think!
Old 10-17-2011, 06:04 PM   #2
samus143
Member#: 270802
2006 wrx
Snow
Thank you for taking the time and making this video, it was very helpful in many ways, excellent job guys!
samus143 is offline   Reply With Quote
Old 04-11-2013, 12:34 PM   #3
sc00by_d00_06
Member#: 351393
2006 Impreza WRX STi
Fantastic. Thank you for all the support you guys provide!
sc00by_d00_06 is offline   Reply With Quote
Old 04-12-2013, 07:24 AM   #4
'08WRXRider
Member#: 276361
Excellent & informative. Keep up the good work.
'08WRXRider is offline   Reply With Quote
Old 04-20-2013, 02:32 AM   #5
Irish Adam
Member#: 353785
2002 Impreza WRX
Obsidian Black Pearl
are you going to possibly make a video list of how to properly use the Accessrace tuner software that you allow AP users to download directly from Cobbtuning.com? I have it and can't really make heads or tails from reading and I really don't want to destroy my engine, and do you have any info on how to datalog and create maps for the 4EAT that my wrx has?
Irish Adam is offline   Reply With Quote
Old 04-20-2013, 02:40 PM   #6
notdubszj
Member#: 330203
2013 WRX Stage 2
Thanks Cobb!
notdubszj is offline   Reply With Quote
Old 06-15-2013, 10:23 AM   #7
bchasc
Member#: 344087
2005 WRX Wagon
Great support, Thank you.
bchasc is offline   Reply With Quote
Old 07-16-2013, 10:14 PM   #8
HawkI06
Member#: 362011
2006 Wrx sti
I tried to do a datalog and when I hit okay to start it it just kept saying trying to connect to the ecu. Any idea why this happened or how to fix it?
HawkI06 is offline   Reply With Quote
Old 09-27-2013, 03:15 PM   #9
Ryan321
Member#: 225014
2005 Impreza WRX STI
Is there anyways to zoom into the maf curve from race tuner.
Ryan321 is offline   Reply With Quote
Old 01-07-2014, 05:09 PM   #10
ennigiser01
Member#: 378053
Thank you.
This video it's awesome!!
ennigiser01 is offline   Reply With Quote
Old 01-20-2014, 12:25 AM   #11
newphow
Member#: 348251
2003 subaru wrx
sonic yellow/black
bump
newphow is offline   Reply With Quote
Old 02-02-2014, 09:37 PM   #12
th05sti
Member#: 350762
2014 WRX
Default Great Job
This video helped me understand what I was looking at on my accessport. Thank you.
th05sti is offline   Reply With Quote
Old 02-20-2014, 10:43 PM   #13
erixon84
Member#: 354850
2013 WRX Sedan
Excellent video. My car is running good.
erixon84 is offline   Reply With Quote
Old 04-14-2014, 09:23 PM   #14
Mason_sti
Member#: 387778
2007 Wrx STi
Thank you, very helpful
Mason_sti is offline   Reply With Quote
Old 04-16-2014, 08:33 PM   #15
Modzilla
Member#: 388006
Thank you. Now I would like to upload my data log to get it analyzed on NASIOC until my tuner can look at it because I'm having an issue that I can't figure out and I need replies to post a thread... help?
Modzilla is offline   Reply With Quote
Old 05-27-2014, 01:42 AM   #16
fry
Member#: 391900
I installed my stage 2 and my car shut off while I was driving. So I was told to uninstall it then try to reinstall it. Also I was told to check the ground wire to see if it was connected correctly. And to disconnect my battery to try to reset the ECU. I did all this and now I can't get my car turn over. I tried to reinstall the access port after rehooking my battery up and now I can't get power when in the on position. Could it be the battery or something else
fry is offline   Reply With Quote
Old 05-27-2014, 05:42 AM   #17
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
Good try. You should be making a new thread. Not latching ok to someone else's.
And yes, the map notes and instructions clearly state to make sure your battery is fully charged so it does not die during installation.
Some people go so far as to put it on a trickle charger while working on the car with the AP.
Loyale93 is offline   Reply With Quote
Old 06-26-2014, 09:33 PM   #18
toilet_paper
Member#: 394688
Exclamation Tuning?
Just replaced my short block with a newer one with forged pistons and bores.. will I be needing a tuning? Or can I still use it as a DD.. for a while?
toilet_paper is offline   Reply With Quote
Old 03-05-2015, 11:19 AM   #19
swaggal0s0
Member#: 397211
so I'm doing everything right but when i open the spreadsheet its only 2 rows. Psi and Time?
swaggal0s0 is offline   Reply With Quote
Old 03-05-2015, 10:57 PM   #20
Casedog17
Member#: 381849
2006 Wrx STI
Very helpful video!
Casedog17 is offline   Reply With Quote
Old 03-23-2015, 11:20 PM   #21
elgatoloco
Member#: 416805
Default Nice Video - Thanks!
First time posting to the site. Very useful sticky to have around for us beginners. Thanks for the excellent video, is there a place to find more of these?
elgatoloco is offline   Reply With Quote
Old 03-29-2015, 03:04 PM   #22
j paggio
Member#: 417269
Does anyone know if when you do cobb stage 2 is there anything else you need to do with that modification or is everything that comes in the box is what you need.
j paggio is offline   Reply With Quote
Old 04-16-2015, 01:46 PM   #23
RouGueRex333
Member#: 402081
2008 Impreza WRX
Default How do I send maps to a Tuner?
I have tuned the Stage 2 to my 08 WRX, but I need to fine tune it so that the car is recognizing and adjusting not only to the Colorado Climate of 6,000 + elevation and humidity, but the modified parts other than the down pipe and axle back exhaust. I have bigger headers and up pipe and that's something that the off the shelf map might not take into account. I could be wrong or over doing it but the last time I got the tuner in (before I did new headers/cams/valves/gaskets) the Stage 2 tune seemed to be piggy backing on the stock ECU the wrong way and ended up giving my car a really low idle, almost to the point of stalling! I could specify more details but that would be a long story. So, how should I go about this COBB Tuning???
PS. If I'm in the wrong forum, please redirect me.
RouGueRex333 is offline   Reply With Quote
Old 07-01-2015, 03:20 AM   #24
dunsparth
Member#: 375944
2002 Subaru wrx
Great video thanks for all the info.
dunsparth is offline   Reply With Quote
Old 07-01-2015, 08:33 AM   #25
DJ Kimchi
Member#: 424390
Thanks for the vid.
DJ Kimchi is offline   Reply With Quote
Alert Kaiser - 1 of 3 - David Nelson son of Ozzie and Harriet dies at 74. Brad Pittiful Off-Topic 16 01-12-2011 01:53 PM
Help - EJ20G Data log inside Zora Pre-2002 Factory Turbo Powertrain 23 04-27-2009 10:45 AM
Get rid of this - Subaru tire pressure monitoring system Mooneyes13 General Community 93 11-09-2008 10:59 AM
Step 1 of 3 - interior swap SMUwrx34 Texas Impreza Club Forum -- TXIC 13 06-30-2007 08:19 PM
Missing 1 of 2 - Gas Tanker in NY WRSport Political Playground 7 05-19-2004 02:35 PM
