Welcome to the North American Subaru Impreza Owners Club Friday October 28, 2016
Old 10-17-2011, 12:00 PM   #1
Member#: 236388
Default Building the EJ207 Engine
Hi, I'm planning to rebuild the ej207 engine with those mods.
CP Pistons and Manley H Beam rods
Brian Crower stage 2 272/272 cams
supertech dual valvesprings and Ti Retainers
Cosworth Blueprinted high pressure oil pump
ACL Bearings
Brian Crower Adjustable cam gears
Haltech ECU
There are no local tunes tuning the stock ecu and my car is a MY99, so the AP is not compatible. Currently using a custom exahust and planning to do FMIC as well. How much would be the max boost I can run using the stock turbo? And whats your opinion about those mods I've mentioned? (such as anything else to be added or something you think that is not so necessary etc?)
da_coolest is offline   Reply With Quote
Old 10-19-2011, 03:47 AM   #2
B4 ProjectX
Member#: 298113
Exact same mods except for the BC cam gears and I have BC valve springs and ti retainers. Same ecu PS1000. Walbro fuel pump. Car is a BE5 Legacy B4. Single turbo converted and for the moment on the stock TD04. Running 1.5 bar peak boost. Pumps quite a bit of hot air after 3 runs but I am still on the TMIC. Planning on a FMIC with a bigger turbo.
B4 ProjectX is offline   Reply With Quote
02 Wagon Build/ JDM EJ207 V5 STi Swap GregZ Member's Car Gallery 17 10-28-2013 10:28 PM
ej207 engine build up torques/clearances ver.7 chubifcr Built Motor Discussion 5 12-08-2011 03:13 AM
Volkswagen may build the ‘world engine’ for Formula 1 AVANTI R5 Non-Subaru News & Rumors 12 05-12-2010 07:11 PM
AMS Top Shop Engine build..the quest for 1000hp on 100octane! AMS Member's Car Gallery 114 11-10-2008 06:40 PM
BMW building a diesel engine for the WTCC NYCshopper Non-Subaru News & Rumors 1 11-26-2007 06:48 PM
