Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 06-29-2012, 01:20 PM   #126
Bad Wagon
Member#: 53022
1999 Top Scoob Lego
08 Lego 3.0R Flared
I'll have those both finished ether today or tomorrow. The rear diffusor main plate will be at around a 25 deg angle and it will have an underspoiler around 15 deg. My spoiler I am making adjustable from 5-20 deg so I can dial it in once I get up to speed.
For now I only have one pic. I just finished this installment of work to the GC project I have been working on so now it goes to paint giving me some time to really push on the Forester to finish up the bulk of the project.
Picked these up from Glen at Prosport Gauges...
I got 7 Guages:
Boost
Fuel Press
Oil Press
Air/ Fuel Ratio
x2 EGT
Volts
T4 Sized Turbo Blanket
50' of Exhaust Wrap
These are all there new EVO series which has a sweep and a digital read out for quick reference when at speed at the track. All premium senders so they are small which is good because I have limited space. I got 2 EGT gauges. One for the exhaust and a while back I used one of there older EGT gauges to make a Brake Temp Guage. These new EVO series gauges have a faster sender so I should get faster results. I take the sender and drill into the pad material and it tells me the brake pad temp. The plus with this is that if I have a pad that has a max operating temp of 1100 deg and my gauge is reading close or above that I can ether change my braking style or swap in some hotter pads. This will help me run the best pad for the verious tracks I attend.
I'll have some more detailed pics of them when I get ready to install them sometime next week. Also for anyone looking at their turbo blankets wondering what size they need the T3 sized one works perfectly on WRX turbos and STi Vf39s or 16gs. The T4 size that I got is a pretty good fit for the Twinscroll turbos VF36,37s
Heres a pic of the T3 on a VF39/ 16g that I just installed on the GC I'm working on.
Johann
Bad Wagon is offline   Reply With Quote
Old 07-04-2012, 05:22 PM   #127
Bad Wagon
Member#: 53022
1999 Top Scoob Lego
08 Lego 3.0R Flared
Hey all got a good update to post today. The GC was finished a few days ago so I finally got to start putting some real time into the Forester.
Got started with fabbing up the spoiler brackets. I think the Hatch is a little weak from being stripped out so I am going to change it a little bit later this week.
After that I got started on the rear bumper support/ rear diffuser. After 2 Days I ended up with this. It only weighs 14lbs and it may not be very pretty but not all things that are functional are so. Oh and becuase racecar...
Nice step back shot...
Lastly for that day I finished up making some bumper/ hatch mounts. Piece of round pipe with a nut welded to the end. Slip the bumper on, shut the hatch screw in place...
Johann
Old 07-04-2012, 05:22 PM   #128
Bad Wagon
Member#: 53022
1999 Top Scoob Lego
08 Lego 3.0R Flared
Next was getting everything ready for paint so I started buttoning up the rear flares. I had a few ideas of what I wanted to do on the rear of the flares but I ended up just fitting them to the quarter pannel. They are a lot stronger and this is much simpler.
Next up was bolting them to the chassis. I decided I would make a tool to counter sink the metal to fit flush-mount screws. Took an m14 nut and welded an m6 nut in sided and make a sort of press.
Wroked like a charm. Going to be keeping this tool for a long time...
Johann
Old 07-05-2012, 01:23 AM   #129
nategr8ns
Member#: 198413
1999 Impreza OBS
Ninja 650r
That rear end looks so good... so mean.
Oh, btw, what's that metal box under the hood with the two round air filters?
nategr8ns is offline   Reply With Quote
Old 07-07-2012, 12:48 PM   #130
Kumachn
Member#: 264764
2004 Forester XT 5MT
Java Black Pearl
Looks like a Oil Catch Can.
Kumachn is offline   Reply With Quote
Old 07-15-2012, 06:49 PM   #131
RuskeR
Member#: 5824
2005 STi Aspen White
1990 240sx "SR20"
It was great to see this in person!
RuskeR is offline   Reply With Quote
Old 07-16-2012, 01:55 PM   #132
Bad Wagon
Member#: 53022
1999 Top Scoob Lego
08 Lego 3.0R Flared
Hey all sorry to the delay in updates. I worked my ass off the last 7 days to get it as close to finished as I could get it to get it to the NW Big Meet Car show. Some of you saw it there maybe it was a good time. Anyways lets go back a few days....
Once the fenders were all welded up and all the triming was finished it was finally time for some body filler.
I spent about 3 hours per side and I only did the rear flares. I'll be going back and taking care of the imperfections and other dents after I get it running.
All sanded ready for primer:
And... primed:
Next up was finally getting some color on it. Started with the cage first because it didn't require any masking. The color is very finiky so it has to do 3 super light coats and it still has a couple reactions but overall it turned out pretty good.
Then it was time to mask off the cage and paint the interior in a nice gloss black.
After that it was time to finish up the remainder of little things. Getting the mirrors mounted. Finishing the spoiler mounts and bolting the hatch on. Finishing the ducting for the v-mount. Very proud of this...
At this point I was working so many hours and so fast I kinda forgot to take pics... The white sealer I was planning on spraying was no good so all I could do was get 1 coat of some leftover black from the Legacy and some gunmetal grey from an R32 Skyline I painted a couple years ago one it so it was all one color. However I have pics from the show to show how she finally turned out. It was well recived even though it was not completly finished. I think the most common thing I herd was "this is insane" and "OMG". Also the GC project that I have been working along side this won best GC8 and it currently at Maxwell for tuning. I'll have more pics of that in a few days.
Well enjoy. I still have to swap the blocks after Mike at PIA finishes building it. Get a few undercarrage parts powder coated and then install the wiring. Once its done it will go to PIA for tuning and if there is enough time before WCSS I'll finish up the body work and get it in its final color.
Old 07-16-2012, 01:58 PM   #133
Bad Wagon
Member#: 53022
1999 Top Scoob Lego
08 Lego 3.0R Flared
Old 07-16-2012, 01:59 PM   #134
Bad Wagon
Member#: 53022
1999 Top Scoob Lego
08 Lego 3.0R Flared
I'll have some more pics once I get it off the trailer in a couple days I have a couple cars I need to bust out before I can put it back in the shop.
Johann
Old 07-16-2012, 02:52 PM   #135
nategr8ns
Member#: 198413
1999 Impreza OBS
Ninja 650r
No way... I have to see this in person when I'm back out west. Will you be making your way south in it very often?
Old 07-27-2012, 07:16 AM   #136
prochucker
Member#: 21038
05 STi CGM
08 WRX 5D SSM
Subaru Stars
Johann, you been too busy to get anything done?
prochucker is offline   Reply With Quote
Old 07-27-2012, 11:05 AM   #137
Bad Wagon
Member#: 53022
1999 Top Scoob Lego
08 Lego 3.0R Flared
My block is still not finished and I don't really want to pull anything off it till it is. I also got a new job so I'm not working in the shop 7 days a week anymore. I have all the remaining parts to get it running ordered though. And I have been working on the harness in the house when I have time but I doubt the Forester is going to get any love for at least another week or 2. Kinda just waiting on this block. I didn't want to finish up the body work and repaint it untill it was running so I could put it through its paces and make sure its noy going to rub anywhere or anything so...
I'll have an update as some point...
Johann
Old 07-27-2012, 02:54 PM   #138
prochucker
Member#: 21038
05 STi CGM
08 WRX 5D SSM
Subaru Stars
Johann
Well thanks for the update, I figured you were busy.
Old 07-30-2012, 08:21 PM   #139
frogmonk
Member#: 74489
'04 FXT/05 Baja Tur
'71-FF1/05 Saab-92X-Aero
Your car looks really badass.
Can you post more pictures when you get a chance? I'd like to see a side view that shows the profile of the rear spoiler and a rear shot that shows rear diffuser straight on. Good luck with the new job!
frogmonk is offline   Reply With Quote
Old 07-30-2012, 11:08 PM   #140
Bad Wagon
Member#: 53022
1999 Top Scoob Lego
08 Lego 3.0R Flared
Ya I'll be able to this weekend.
Johann
Old 07-31-2012, 12:17 AM   #141
nategr8ns
Member#: 198413
1999 Impreza OBS
Ninja 650r
Johann
That's what we like to hear!
Old 07-31-2012, 03:34 PM   #142
Kansloos
Member#: 327770
Im following this thread from the Netherlands with a drewl bucket in my hands. Very awesome project.
Kansloos is offline   Reply With Quote
Old 08-01-2012, 11:17 AM   #143
Bad Wagon
Member#: 53022
1999 Top Scoob Lego
08 Lego 3.0R Flared
haha thanks.
Old 08-16-2012, 02:06 AM   #144
Bratcher15 FOZ
Member#: 323741
Ok NEED HELP!!!! I have a 1999 Subaru forester slammed 3" exhaust all done cold air intake all done. now I want to work on the engine is there any parts I can do to bring my horsepower in the 200? List them please and prices! I want to know everything! Thanks...
Bratcher15 FOZ is offline   Reply With Quote
Old 08-16-2012, 10:15 AM   #145
Bad Wagon
Member#: 53022
1999 Top Scoob Lego
08 Lego 3.0R Flared
Well for an N/A engine the only other supporting mod I would do is a header.
You'll need to go internal to make any more real power. Higher comp pistons and cams should get you close.
You could also supercharge it. Its easier and cheaper then doing a turbo and it can get you an additional 50-70 hp on stock internals so easily reach 200whp.
There are some kits out there but you'd be better off building it from scratch using a SC out of another car that came with one. Eaton m62 off a 230 kompressor (sp) would be a nice fit.
Johann
Old 08-16-2012, 10:44 AM   #146
Bratcher15 FOZ
Member#: 323741
Thanks man I think I'll supercharge it how much do you think that will cost?
Old 08-16-2012, 10:56 AM   #147
Bad Wagon
Member#: 53022
1999 Top Scoob Lego
08 Lego 3.0R Flared
Well it depends on how much you do. Search rs25 there is a lot of info on there.
Old 08-16-2012, 10:58 AM   #148
Bratcher15 FOZ
Member#: 323741
Ok and you think my stock engine can hold the supercharger with blowing anything?
Old 08-16-2012, 11:06 AM   #149
nategr8ns
Member#: 198413
1999 Impreza OBS
Ninja 650r
$2 grand. Maybe less if you get good deals on parts. Just make sure not to **** up while tuning for it.
http://www.ludicrous-speed.com/wiki/...C_Build_Part_1
Old 08-16-2012, 11:58 AM   #150
Bad Wagon
Member#: 53022
1999 Top Scoob Lego
08 Lego 3.0R Flared
Ya 5-6 psi is what most are running.
The ForeSTAR Build thread. girodisc Member's Car Gallery 460 05-20-2013 08:13 PM
For love of the Bug-Eye build thread DemiSlayer Rocky Mountains Impreza Club Forum -- RMIC 23 11-27-2009 12:26 AM
the steel building thread.... toulakid Off-Topic 3 08-31-2009 03:22 AM
Wh'appen to Tai Chih left the building thread? blaster88 Mid Atlantic Impreza Club -- MAIC 12 11-09-2001 04:26 PM
