Welcome to the North American Subaru Impreza Owners Club Saturday September 20, 2014
Old 10-17-2011, 06:39 PM   #1
wrxstijdm
Member#: 254590
1998 V4 Impreza STI
EJ20K engine
Default Weird issue when starting
Guys,
I have a weird issue when starting my car...
I usually put the key on the "On" position, wait for around 10 secs for the fuel pump to "send" the fuel, then crank it...
It always starts perfectly, goes up to 1200 rpms, but then comes down to 500 rpms (the car almost shuts off) during 5 seconds and then back to 1200 rpms and idles perfectly.
What could be the issue during those 5 secs?
I have cleaned injectors, changed fuel filter, plugs (as regular maintenance, not to fix this), but situation has not changed...
If I press a little the gas pedal before it comes down to 500 rpm, during those 5 secs, then the issue doesn't take place.
It happens both when the engine is hot or cold... But if it is hot, it lasts only like 2 secs...
Other than this, car runs perfectly fine...
wrxstijdm is offline   Reply With Quote
Old 10-18-2011, 08:57 AM   #2
pmugabi
Member#: 280926
Air leak, maybe from a BOV.
pmugabi is offline   Reply With Quote
Old 10-18-2011, 08:59 AM   #3
wrxstijdm
Member#: 254590
1998 V4 Impreza STI
EJ20K engine
No BOV, car is absolutely stock...
Old 10-18-2011, 12:17 PM   #4
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
There is a somewhat standard list of things that contribute to weird starting issues.
Plugs/Coilpacks
Coolant temp sensor
Fuel pump
FPR
Dirty/defective MAF
Also cam sensors are frequently mentioned as the cause of weirdness.
TommyAtomic is offline   Reply With Quote
Old 11-13-2011, 12:06 PM   #5
wrxstijdm
Member#: 254590
1998 V4 Impreza STI
EJ20K engine
Just a heads up on this, in case somebody has a similar issue....
I installed a grounding kit on my car and the problem dissapeared! I guess when the car starts all sensors need to have a good "electricity flow" or something like that...
Anyways, I'm glad I fixed this
Old 11-15-2011, 12:23 PM   #6
lagopodous
Member#: 301043
1995 WRX
RA white
I was having the same issue and did some research on here and found it to be the IACV. Problem fixed, but now I get a studdering problem. Feels electrical as it will be there one minute, no matter what RPM, and then its like someone flipped a switch and it goes back to normal. You can hear it in the exhaust note even. Cant seem to find any consistancy to it. I think ill reset the ecu first, then check my plugs. I did the coil conversion already, been running great for the last 4 years but this one has me stumped on where to start looking. Any advice is mucho appreciatedo!
lagopodous is offline   Reply With Quote
Old 11-15-2011, 01:10 PM   #7
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Do not reset the ecu first. This is not a troubleshooting step. It will not help.
Make changes first. Repair/replace suspicious parts FIRST - THEN reset ECU.
Check your coolant levels and take a look at what evoscan or similar software thinks of the readings from your coolant sensor. You may need a new coolant sensor. Also you may just have a bad batch of fuel. Winter fuel (oxygenated fuel) is generally complete crap and can result in some fuel trim weirdness.
Its possible that you are experiencing false knock. Evoscan or similar software may be able give you more info to check that.
Old 12-08-2011, 12:12 PM   #8
wrxstijdm
Member#: 254590
1998 V4 Impreza STI
EJ20K engine
Problem is back again... I figured it only disappeared cause the ECU was reset... So now that the ECU "learned" again, the issue came back..
Any idea what the issue might be?
Old 12-08-2011, 12:38 PM   #9
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Plugs/Coilpacks
Coolant temp sensor?
Fuel pump
FPR
Dirty/defective MAF
Also add dirty injectors to the list.
Weird issue that's starting to cost me... TTFOWIA Newbies & FAQs 17 06-03-2009 01:11 PM
Weird sound when starting up? LiDrummer Newbies & FAQs 7 11-15-2007 06:43 PM
Weird sound when I started my car... Alex RS General Forum Archive 3 03-20-2001 12:05 AM
Weird clutch problem when starting? LaxCat RS Normally Aspirated Powertrain 0 02-20-2001 04:33 PM
weird idle when starting up....Please HELP... Michael Normally Aspirated Powertrain 7 02-16-2001 10:10 AM
