Old 10-18-2011, 02:29 PM   #1
Dori Ninja
Member#: 73974
00 2.5RS
Sedona Red Pearl
Default STi Side Feeds on WRX??
hey guys, quick question, i have a set of modded STi side feed injectors sittin in the storage unit from a previous project that has since been scrapped, but now i just purchased an EJ255 swap thats missing injectors and rails...now i have the stock STi rails as well...can i run these on my 255 or is there a diff in mounting points for the rails or connectors for the injectors?? in my search i found there both high impedance so electronically they should be fine but i was just wondering if mechanically id be ok....
Dori Ninja is offline   Reply With Quote
Old 10-18-2011, 02:36 PM   #2
vision.dynamix
Member#: 139955
# OneBoston
Youd need Side Feed TGVs also.
vision.dynamix is online now   Reply With Quote
Old 10-18-2011, 03:28 PM   #3
STIBungy
Member#: 51684
2004 Impreza WRX STI
Also the vacuum connection are located at different spots on a sidefeed intake manifold vs a topfeed one so you'll need to run the line for that accordingly.
STIBungy is offline   Reply With Quote
Old 10-18-2011, 11:33 PM   #4
Dori Ninja
Member#: 73974
00 2.5RS
Sedona Red Pearl
ic ic...and the side feed TGV's will bolt up fine??? thoes are missing as well, and i plan to do the delete so if thats the case ill just stick with what i got and run the side feeds....
FS : Perrin side feed fuel rails and modified 800cc STi side feed injectors kingsdman Engine/Power/Exhaust 0 10-24-2010 01:05 AM
Perrin Modified 850cc STI Side Feed Injectors, WRX 5sp Alum DSS, & more Cheap! turbocharged NWIC Private Classifieds 4 02-17-2010 04:35 PM
STI side skirts on WRX? ccc_wrx04 Newbies & FAQs 8 05-08-2006 12:19 PM
Sti side skirts on WRX, look good? Rex_Guy Member's Car Gallery 19 06-24-2004 10:30 AM
sti side skirts on wrx??? wrx_snobordr Interior & Exterior Modification 7 02-27-2004 11:43 PM
Message Board Statistics All times are GMT -4. The time now is 10:08 PM.
