Old 05-09-2012, 03:16 PM   #51
Big_DeWeY
Member#: 37078
95 L
Blue-ish
In for the bull****.
Big_DeWeY is offline   Reply With Quote
Old 05-09-2012, 03:29 PM   #52
jamal
Member#: 71875
98 Legacy GT
my wheels fit
I would love to hear more about putting a 94mm wheel in a 108mm housing.
jamal is offline   Reply With Quote
Old 05-09-2012, 05:18 PM   #53
B.R.E.D
Member#: 289606
06 WRX
white
Like throwing a hotdog down a hallway
B.R.E.D is offline   Reply With Quote
Old 05-09-2012, 05:21 PM   #54
Big_DeWeY
Member#: 37078
95 L
Blue-ish
Can someone do a "response" video for this?
Old 05-09-2012, 09:28 PM   #55
Dipp
Member#: 127907
99RS 9.54 @ 146
2.65L & FOBIA fab & S374
Blow threw MAF
Not twin scroll ?
Access port
Stock cams
No sleeves
Good luck making 1,000 HP the odds are heavily stacked against you, also FYI no one cares unless it's Wheel Horse Power.
Dipp is offline   Reply With Quote
Old 05-09-2012, 11:29 PM   #56
wrxadam05
Member#: 84070
2015 Fiesta ST - E30
500whp GRB STI
That was easily the worst video I have ever seen.
wrxadam05 is offline   Reply With Quote
Old 05-11-2012, 06:58 AM   #57
raggedoutsti
Member#: 255714
2005 STi
psm
Hi, I'm here for the gang bang
raggedoutsti is offline   Reply With Quote
Old 05-11-2012, 07:44 AM   #58
TrunkMonkeyManiac
Member#: 175898
2002 Impreza
Originally Posted by subypal
Here is the first STi to my knowledge that features the Subaru Block Supports by S&R performance - it is claiming 65 psi on a gt45R turbo with GT40 wheel!!! It is a DD and has no problems with cooling FYI. Runs like a champ.
Video Link: http://youtu.be/7SoGzbrxKuw
:facepalm:
TrunkMonkeyManiac is offline   Reply With Quote
Old 05-11-2012, 11:45 AM   #59
207STi
Member#: 197062
1998 Swapped Impreza
black
"Upgraded rods and bearing" Saaaaaaweeeeeeet. This guy sounds like the lamest person on the face of the planet.
207STi is offline   Reply With Quote
Old 05-11-2012, 11:48 AM   #60
S&R Performance
Member#: 146435
The blocks have done very well for us. I'm not sure why drew had said anything about 1000hp. It's not something that we're aiming for. We were looking to offer a block to handle more boost without having to sleeve and so far we've done several at 35-40psi and they've been awesome.
Not sure what in the world 94mm in 108mm comment was referencing either....
S&R Performance is offline   Reply With Quote
Old 05-11-2012, 11:57 AM   #61
berdugo
Member#: 163108
07 EuroDM STi 2.5L
Is it possible to sleeve the block then put your block support product after sleeving?
berdugo is offline   Reply With Quote
Old 05-11-2012, 12:09 PM   #62
smitty5788
Member#: 267886
2011 STI
Besids all the other bull**** ... did you saw really nice MEGAN coilovers?
smitty5788 is offline   Reply With Quote
Old 05-11-2012, 01:10 PM   #63
NW2TONE
Member#: 212509
unde your hood makin
your **** go faster
Your still never gonna get around ovaling out the lower part of the cylinder after some mileage with high hp on stock sleeves.
NW2TONE is offline   Reply With Quote
Old 05-11-2012, 05:32 PM   #64
Ilovecugars
Member#: 299442
2005 Forester XT
Sorry dont post here much but have a couple questions.
Yes you have supported the top of the each cylinder so now this will help with them flexing independent of each other. But everything under the supports can still expand under high pressure and cause stress in the metal. Which in turn even if you could support the whole length of the cylinder and have zero room for the walls to expand any direction you face another problem. Under the high cylinder pressure it puts alot of force on the aluminium walls, after awhile this should cause the metal to crystallize and become very brittle and then cause the cracks. Have you guys figured out the hp point where having reduced cylinder flex with the guard is helpful in having long engine life, but before the point where you are at risk of cracking the walls? As others have stated its not a matter of support with preventing cracking the walls, its the need for stronger material to take the pressure.
Second question: I see your milling profiles on the top of the deck to making openings for the support. How well are you holding tolerance on these holes going around with an endmill. Are your probing every block to check for consistency? Or each block has supports just to fit that one? What is the interference fit on the pieces being pressed in? I just ask because I see no other way you are hold them in besides the press fit. I just wonder if there is any risk of the supports moving after time?
Ilovecugars is offline   Reply With Quote
Old 05-11-2012, 08:58 PM   #65
B.R.E.D
Member#: 289606
06 WRX
white
Waisting your time man. 50 psi on a 40\42R is no problem for this beast.
Old 10-30-2012, 02:51 PM   #66
The Djrik
Member#: 215707
2003 WRX STI
how much better is it than pining the block?
The Djrik is offline   Reply With Quote
Old 10-30-2012, 03:44 PM   #67
Paidfor
Member#: 267815
Be in awe
dont hate .)
My VF39 is "Capable" of 40 psi.......doesnt mean **** tho lol
Paidfor is offline   Reply With Quote
Old 10-31-2012, 12:25 PM   #68
banshee04
Member#: 179014
'06 WRX/STi
Built Motor/6766/E85
That video just melted my brain!
banshee04 is offline   Reply With Quote
Old 11-22-2012, 10:49 AM   #69
slowgenius
Member#: 48350
04 Jackstands
Dirty PSM
Been a while since S&R updated this thread. Any new info?
slowgenius is offline   Reply With Quote
Old 11-22-2012, 02:26 PM   #70
jdpsearcher
Member#: 291214
2011 STI Sedan
PBP
I used to have an S&R stage 2.5 Block but sold it for a huge loss when S&R wouldn't provide any of the specs on my built, balanced and blue printed shortblock....
I couldn't trust them....I did find someone I CAN trust that provides PROOF of their build in ASF Machine....I have a thread in this section as well....
jdpsearcher is offline   Reply With Quote
Old 11-22-2012, 02:50 PM   #71
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
Roll em up!
Dooo Eeeeit !
sense of nature is offline   Reply With Quote
Old 11-22-2012, 08:00 PM   #72
Rex935
Member#: 205077
2010 WRX STI SE
I just got my car back from S&R today after their stage 2+ block treatment. Well update if i run into any issues. My block wasn't done the same as others though. They made a few revisions.
Rex935 is offline   Reply With Quote
Old 11-22-2012, 09:42 PM   #73
TwinscrollGT35R
Member#: 256810
Was that so it would hit 1000hp?
TwinscrollGT35R is offline   Reply With Quote
Old 11-22-2012, 09:57 PM   #74
Rex935
Member#: 205077
2010 WRX STI SE
Lol no. My hp goal isn't that high.
Old 11-23-2012, 01:15 AM   #75
RNL26
Member#: 338637
2002 Subaru Wrx
Red
I'm also interested in how the S&R block holds up, I've seen videos of cars with their blocks in, but I found nobody to vogue for their blocks or give their opinion on them.
RNL26 is offline   Reply With Quote
Would you pay for an annual membership to NASIOC if signiture blocks were allowed? Smurftastic General Community 70 07-06-2011 02:56 PM
VIDEO: Ken Block Gymkhana practice, or one hoon to rule them all AVANTI R5 Non-Subaru News & Rumors 74 04-01-2009 01:11 PM
VIDEO: Subaru ATV 12AM General Community 1 06-30-2007 07:30 AM
can the stock block take more than 16 psi safely? Scrappypower Mid West Subaru Owners Club Forum -- MWSOC 2 05-17-2003 12:02 PM
