Old 10-19-2011, 12:06 AM   #1
MakuseruSukotto
Member#: 293159
2005 WRX
CGM
Default Questions about Boost.
I've got an 05 WRX. Got my AP and have been fiddling around with it lately and noticed a few things that were kind of off.
First, running the 93oct map Cobb says I should be making approx 14lbs boost. I did a pull in 3rd and managed 10.5. So should I run the HWG version to get boost up?
If so, why isn't my car making the target boost. Cobb's site says something about if it's not making target boost there may be a mechanical problem; something that I may have to adjust. If they say that, then why is there a HWG map?
Also, if I'm accelerating from a stop; just regular light driving, the boost will go from -10 up to about .8-1.0, this is at about 2-2.5k rpm, but then it will slowly drop down to -4 to -8 and stay there as long as im crusing at that speed.
Why is it doing this? Is that normal?
MakuseruSukotto is offline   Reply With Quote
Old 10-19-2011, 08:18 AM   #2
Cobb Tuning
Member#: 4803
Originally Posted by MakuseruSukotto View Post
I've got an 04 WRX. Got my AP and have been fiddling around with it lately and noticed a few things that were kind of off.
The HWG map is necessary due to car-to-car variations that may impact the ability to hit target boost. But, there are many other reasons why a car may not hit target boost, including mechanical issues, altitude (peak boost listed is for sea level), or the peak boost is not being determined correctly. To determine if you are hitting peak boost, you want to do a 3rd gear run wide open throttle run from about 2000 RPM up to near redline (if you can do so safely).
Do you have a version 1 AccessPORT (black brick-looking device) or version 2 (gray with color screen)?
Bill
Old 10-19-2011, 12:35 PM   #3
MakuseruSukotto
Member#: 293159
2005 WRX
CGM
Bill
It's a V2 Accessport.
My peak of 10.5 came from a 3rd gear pull. 2000rpm to 6800rpm.
And as far as altitude, I'm at roughly 1200ft, and it was probably 60F outside.
I'm going to flash the HWG map today and give it another pull and see what happens.
Old 10-20-2011, 10:22 AM   #4
Cobb Tuning
Member#: 4803
Before flashing the HWG map, I would first switch to the new v310 beta maps (will soon be the new current maps). Try the normal wastegate map first:
http://forums.nasioc.com/forums/show....php?t=2233868
Reflash the v310 beta map to your car and then do a data log as explained in this video:
Then post up your logs on google docs and link to it here (make sure you set the permissions to public). We can then take a look at your logs and see how things are before switching to the HWG map.
Bill
Old 10-20-2011, 01:28 PM   #5
MakuseruSukotto
Member#: 293159
2005 WRX
CGM
I'll try that today.
Awesome support by Cobb!
Thanks guys.
Old 10-22-2011, 12:01 AM   #6
MakuseruSukotto
Member#: 293159
2005 WRX
CGM
Ok, I flashed v310.
Still making low boost, 11.37 peak.
Here's the google doc.
https://docs.google.com/spreadsheet/...Gc&output=html
One other thing that concerns me is that Fine Knock Learn goes to 0.35 during high boost. It's that always suppose to be at 0?
I appreciate you guys at Cobb looking at this!
Old 10-22-2011, 10:02 AM   #7
Cobb Tuning
Member#: 4803
Ok, I flashed v310.
It appears that you are still running the v300 map. Make sure you download the v310 map and make sure you select the v310 rather than the v300 map when reflashing (when you go to change maps via AP, it will list the version in the map description).
Bill
Old 10-22-2011, 02:59 PM   #8
MakuseruSukotto
Member#: 293159
2005 WRX
CGM
Bill
That log was from a v310 map.
Old 10-23-2011, 09:40 AM   #9
Cobb Tuning
Member#: 4803
The timing in the map is not right for the v310 map based on that log. There are two possibilities here:
1. We had a bug in the older beta maps for the 04 WRX that impacted one of the timing maps. Can you tell me when and where you downloaded your beta map and the exact name of the map?
2. You need to make sure that you reflash the beta map when you go to change maps. Do not select the real-time flash option. This is because some of the timing maps will not be changed if you flash via real-time.
Bill
Old 10-23-2011, 01:05 PM   #10
MakuseruSukotto
Member#: 293159
2005 WRX
CGM
It was a link here on nasioc somewhere. The map is called Stage 1 93 Octane v310.
It was just flashed real-time though. I'll do a real reflash today with the map you linked me to.
Can you comment on that fine knock of .35? Should I be worried?
Old 10-23-2011, 08:15 PM   #11
MakuseruSukotto
Member#: 293159
2005 WRX
CGM
Did a pull from 3k to 5.5k.
Still topped out at 11.4 PSI.
Fine Knock stayed at 0 this time though.
I'll try the HWG version tomorrow.
Old 10-23-2011, 11:15 PM   #12
Cobb Tuning
Member#: 4803
That isn't an issue. You were effectively running only a portion of the changes designated by the v310 map by only flashing it real-time so let's see how the v310 reflash does now.
Bill
Old 10-24-2011, 01:29 AM   #13
MakuseruSukotto
Member#: 293159
2005 WRX
CGM
Bill
I did the normal reflash and posted the log above.
No fine knock, but still boost was just 11.4psi.
Old 10-24-2011, 10:31 AM   #14
Cobb Tuning
Member#: 4803
Can you post a link to your latest log on the v310 relfash? The last log I see is the one you posted on 10-21 which wasn't running the full v310 reflash.
Bill
Old 10-24-2011, 12:47 PM   #15
MakuseruSukotto
Member#: 293159
2005 WRX
CGM
Bill
Sorry about that, I thought I posted it.
https://docs.google.com/spreadsheet/...hl=en_US#gid=0
There we go.
And again, that's for the support!
Old 10-24-2011, 01:04 PM   #16
Cobb Tuning
Member#: 4803
There we go.
Yeah, I would go ahead and flash the HWG v310 map. Try to start your WOT run at around 2000 RPM, if you can do so safely.
Bill
Old 10-24-2011, 02:54 PM   #17
MakuseruSukotto
Member#: 293159
2005 WRX
CGM
Bill
I started much earlier, but forgot to press the log button.
Now do I need to do a complete reflash, or will an OTF reflash work?
Old 10-25-2011, 10:36 AM   #18
Cobb Tuning
Member#: 4803
You need to do a complete reflash with these maps (i.e. connect the test mode connectors, choose "reflash" when changing maps, etc). Do not flash as real-time.
Bill
Old 10-25-2011, 01:15 PM   #19
MakuseruSukotto
Member#: 293159
2005 WRX
CGM
Bill
Alright, I'll do that. What's the point of the real-time flashing then?
Old 10-25-2011, 01:37 PM   #20
Cobb Tuning
Member#: 4803
Real-time flashing should be used if you are making temporary relatively minor changes on top of your reflashed map. For example, running anti-theft, fuel economy, valet, etc
Real-time flashing maps allow for changes to about 10 or so of the most typically tuned tables for boost, fuel, timing, etc. Reflashed maps allow for changes to those tables plus any of 300+ tables defined by our tuning software and changes to the ECU for any additional features such as launch control. As such, it is critical that you reflash maps when using a newer map version or changing mods (such as going from stage 1 to stage 2), to make sure that you get all the changes in the tune. Use the real-time for temporary changes as described above.
Bill
Old 10-25-2011, 06:11 PM   #21
MakuseruSukotto
Member#: 293159
2005 WRX
CGM
Bill
I didn't know that.
Thank you very much!
Old 10-26-2011, 07:09 PM   #22
MakuseruSukotto
Member#: 293159
2005 WRX
CGM
Flashed the HWG map.
Peak boost was lower than the normal stage 1.
https://docs.google.com/spreadsheet/...GdzZtekE#gid=0
Peak of 10.96 PSI @4600rpm.
Any idea why I can't reach target boost on any maps?
Old 10-26-2011, 07:29 PM   #23
Cobb Tuning
Member#: 4803
There's a lot of car-to-car variation in boost control with these cars. The next step would be to tighten the wastegate arm a bit at a time until you hit target boost.
Bill
Old 10-26-2011, 08:16 PM   #24
MakuseruSukotto
Member#: 293159
2005 WRX
CGM
Bill
Would you recommend flashing back to the normal map and then doing that? Or staying with the HWG map and doing it?
Old 10-27-2011, 10:08 AM   #25
Cobb Tuning
Member#: 4803
I would stay with the HWG map for now. Tighten the arm in small increments (half-a-turn), then log to check boost, and tighten again, until you get close to your target boost (within 1 psi).
Bill
Question about boost/duty cycle setting for AVC-R KillerRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 07-31-2002 10:06 AM
Question about boost controllers kotaro Legacy Forum 2 07-06-2002 06:45 PM
Question about boost line vacuum and a MBC. Cjchaps Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-28-2002 09:26 PM
quick question about boost gauge vacuum? marvd00d Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-28-2002 01:46 AM
Question about boost on auto WRX WRX_02_227 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-04-2002 09:24 PM
