Welcome to the North American Subaru Impreza Owners Club Monday April 27, 2015
Old 10-19-2011, 11:17 AM   #1
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
Default ver8 207 engine harness and ecu into 02 wrx
Ok so I have some questions and issues, I did this swap and it worked great for about 1k now im starting to have issues, I have now started looking at the fsm wiring for both and my issue I believe is in in a ground in the black engine harness plug ( if I can get it running, and I move that plug it dies haven't gotten it running again so not sure which wire it is, but I am getting a cel for the coolant temp and tps, both share the black with a green stripe ground wire) Well that ground goes to the sheilded sensor and ground junction thing, well between ver8/7 and usdm wrx they are way different. It now actually makes me wonder how these swaps are even possible.
Has anyone else had this issue before or is there a common fix for it????
Also if I check the power and ground and signal on the tps and the map which uses both the same power and ground, I actually get a weird number, I get 5 volts. On the power and 7 volts on the ground, and .02 on the signal, what would cause a voltage split between the two??? Any. Of the grounds in that stupid junction thing? ?
seanathanq83 is offline   Reply With Quote
Fs 05 Wrx 2.0 Engine,harness And Ecu juscool Engine/Power/Exhaust 7 10-04-2009 08:45 AM
2002 wrx complete engine + harness and ecu 69subaru360 Engine/Power/Exhaust 22 08-14-2009 06:56 PM
02 wrx engine harness and ecu skate enjoi Engine/Power/Exhaust 11 01-13-2009 10:20 PM
WTB: 02/03 WRX Complete Engine Harness and ECU RS_NW Private 'Wanted' Classifieds 1 09-09-2004 10:34 AM
Looking for EJ20T engine, tranny, and ECU from 02 or 03 WRX marcus12 Private 'Wanted' Classifieds 3 11-04-2003 09:40 PM
