Old 10-19-2011, 05:18 PM   #1
Dj Xtz
Member#: 183720
2003 Impreza WRX
Sonic Yellow w/DGM 2-tone
Default Added Grimmspeed 3-Port EBCS to existing Stage 3 2.0L WRX Setup
Recently I tuned my Stage 3 WRX for my Dark Blue Denso 560cc Injectors (Thanks Bill for giving me advice and reviewing my datalogs). I have now added a Grimmspeed 3-port EBCS and loaded a real conservative map with a boost target of 16psi. WGDCs are 70% of bleeder set up. I datalogged a 3rd gear pull and reviewed it. All looked good except one weird anomoly at 4120rpm where I got a spike of 19.7psi.....Here is the datalog to review:
https://docs.google.com/spreadsheet/...MyV1E&hl=en_US
Miguel
Dj Xtz is offline   Reply With Quote
Old 10-19-2011, 05:31 PM   #2
dazedone
Member#: 173938
06 sti
matte black
your logging to many things at once. this make the logs not have very much detail.
If you haven't read this http://www.romraider.com/forum/viewt...hp?f=33&t=5384 you should. It will help you make more useful logs
This page has just about every thing you need to know http://www.romraider.com/forum/viewforum.php?f=33
dazedone is offline   Reply With Quote
Old 10-19-2011, 06:24 PM   #3
Dj Xtz
Member#: 183720
2003 Impreza WRX
Thanks for the tip and links. I'll keep that in mind when I datalog again.
Miguel
Old 10-20-2011, 05:14 PM   #4
Dj Xtz
Member#: 183720
2003 Impreza WRX
Default New Datalog for consevative 16psi map
Still concerned with A/F Trim Learning. Boost targets are being hit. Minor knock instance before boost. No boost spike on this log.
https://docs.google.com/spreadsheet/...5xdGc&hl=en_US
Miguel
NY/NNJ 2.0L WRX WAGON Front and Rear Axles. 2.0L PS pump munkis Private 'Wanted' Classifieds 0 03-19-2009 01:35 PM
2004 5MT 2.0L WRX ECU w/Ecutek Stage 2 installed Unabomber Engine/Power/Exhaust 10 08-01-2007 09:17 PM
2004 5MT 2.0L WRX ECU w/Ecutek Stage 2 installed Unabomber MAIC Private Classifieds 0 06-21-2007 11:19 AM
Poll: Longetivity of Stage 4 2.0L WRX gopsu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 112 05-29-2007 10:41 AM
Feeler, FS/FT 2.0l WRX Cobb AccessECU Stage II REX8 Engine/Power/Exhaust 4 11-10-2006 06:37 PM
