Old 10-24-2011, 05:31 PM   #26
hardhitter_alert
Member#: 293841
2007 STi
hybrid boost control:
bypass adapter:
hardhitter_alert is offline   Reply With Quote
Old 10-25-2011, 01:30 PM   #27
BoostinChick
Member#: 218971
2007 WRX
For the oil pressure gauge, what source do you plan on tapping for that sensor? I recommend this -
http://www.wrxtra.com/catalog/produc...338cbfa3e3b94a
Other than that, have fun and don't blow up your motor!
BoostinChick is offline   Reply With Quote
Old 10-25-2011, 02:07 PM   #28
Shayhan27
Member#: 205906
05 WRX
CGM
Good luck
Great write up I like the picks.
Eager to see what kind of power you make...
Wish I had the Balls to save money and DIY all my stuff..Instead I donate my cash to the Mike Warfield Go fast charitable fund....LOLOLOLOLOL
Shayhan27 is offline   Reply With Quote
Old 10-25-2011, 02:20 PM   #29
MY EJ20TTTTTT
Member#: 275239
2002 Rallying WRX
Rock chipped MBP
dont blow up your motor.
the turbo needs at least 1000 miles to be fully broken in too, btw. or youll be screaming at it "why oh why did you die?"
MY EJ20TTTTTT is offline   Reply With Quote
Old 10-25-2011, 03:37 PM   #30
AREA1320
Member#: 112508
No they dont
AREA1320 is offline   Reply With Quote
Old 10-26-2011, 11:19 PM   #31
hardhitter_alert
Member#: 293841
2007 STi
I have already purchased a kit to attach the sensor and just need to figure out how to loosen the belt tensioner to remove the alternator.
Originally Posted by Shayhan27 View Post
Good luck
Thanks I'm sure it will be tons of power but hopefully not enough to blow the engine
Originally Posted by AREA1320 View Post
No they dont
How many miles will it need?
Old 10-26-2011, 11:25 PM   #32
demafly
Member#: 299122
2005 WRX - Stg 2
Interested to see how fitment is on FMIC.
demafly is offline   Reply With Quote
Old 10-26-2011, 11:29 PM   #33
hardhitter_alert
Member#: 293841
2007 STi
spark plugs were a pain in the ass to change:
I had to modify the crankcase breather hoses to delete the hard line that was crimping the bypass hose between the throttle body. Thanks Perrin
Old 10-26-2011, 11:44 PM   #34
Tut4u2
Member#: 40424
05 STi
Who told you this? Don't spread bad information.
Just prime the turbo with oil before starting the car up. Put out the fuel pump fuse or disconnect the crank sensor behind the alternator, crank the car over, plug it back in and you're good to go.
I would say get a tune so you don't blow your engine up.
Look up how to replace the P/S and A/C belts that will tell you how to remove the alternator.
Lastly, the angle of the inlet looks off but it might be just the picture.
Tut4u2 is offline   Reply With Quote
Old 10-27-2011, 12:08 AM   #35
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Originally Posted by Unabomber View Post
1. Its obvious you do your shopping for car parts at Kmart.
Damn, Unabomber. That's a pretty crappy thing to say about so many vendors who pay to advertise on this site.
Old 10-27-2011, 12:16 AM   #36
NSFW
Member#: 140444
05 Stage Free LGT
Well it's not that many parts though right? I need the fuel pump and injectors to support the turbo.. the filter/intake/maf are needed to support the additional airflow. It's not like I can put the turbo on and tune.. I need most of the other parts too
So do the turbo last. I realize I'm a bit late to this party but FWIW, I did things in roughly this order:
* Pump and injectors, then adjust the tune
* intake, then adjust the tune
* FMIC, tune didn't need any adjusting
* up-pipe, down-pipe, mid-pipe, and real tuning this time
* turbo, and more real tuning
* new intake, adjust tune
* new injectors, adjust tune
Tuning costs very little if you DIY. (It just takes a lot of time.) If I had to pay for tuning I'd probably do things a bit differently (up/dp at same time as turbo) but doing a couple things at a time makes it easier to troubleshoot the inevitable problems that come up when you're doing your own work and new to the platform. And for stuff like injectors and intakes, you don't need a whole tune, so a tuner who knows what he's doing can get them done pretty quickly (esp. if he's tune the same parts before) so it shouldn't cost near what a full tune costs.
Old 10-27-2011, 12:35 AM   #37
j255c
Member#: 89554
2006 EVO SE
Black E85 30PSI dd
I dont see the problem in doing it all at once. Just take your time pressure test the thing and drive it like a grandma with whatever basemap your tuner gives you to get you from your house to the shop.
Stupid imo to pay for a tune for an intake, then pay for a tune for bigger injectors, then pay for a tune for fmic, then pay for a tune for the turbo. Do it all at once and be patient you should be fine.
But absolutely have money aside for a new block if **** happens.
j255c is offline   Reply With Quote
Old 10-27-2011, 01:00 AM   #38
NSFW
Member#: 140444
05 Stage Free LGT
Consider reading the post above yours.
Old 10-27-2011, 10:19 AM   #39
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
Best way to prime the turbo with oil:
Remove your fuse panel / coin box below the steering wheel. Pull out the fuse that is denoted IGN / Air Bag (something like that). This will defeat the fuel pump and is the easiest method out there. From memory it is middle row, 2nd in from the right, but double check the guide on the coin box first.
Stephen
IA Performance is offline   Reply With Quote
Old 10-27-2011, 02:18 PM   #40
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
2. Its obvious you are going to run into huge problems as you are buying first, then asking for help, which is the opposite of what you are supposed to do.
3. Its obvious you will be motor shopping very soon as well.
thanks
didnt bother to read this whole thread....but has it blowed up yet???
Old 10-27-2011, 02:49 PM   #41
Subarusesh
Member#: 288160
2008 Impreza 2.5i
why does he shop at kmart? there's a perrin inlet tube right there that's not from k-mart is it?
Subarusesh is offline   Reply With Quote
Old 10-28-2011, 11:12 AM   #42
hardhitter_alert
Member#: 293841
2007 STi
There was no way the turbo was going in with that perrin intake pipe in the way so I had to take the manifold off. I figured I would do TGV deletes while I'm at it.
Old 10-28-2011, 11:24 AM   #43
hardhitter_alert
Member#: 293841
2007 STi
Yes it has blowed up and there are kmart parts all strewn across the street
Old 10-28-2011, 11:30 AM   #44
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
See below.
Sorry here's the parts list:
Kinugawa Turbo TD06SL2 Garrett 60-1 8cm with 3” inlet
Prosport Boost/Oil pressure gauges
3" maf housing
SSAutochrome FMIC
Psychoreo is offline   Reply With Quote
Old 10-28-2011, 06:53 PM   #45
hardhitter_alert
Member#: 293841
2007 STi
ran into an issue.. damn kmart parts
http://forums.nasioc.com/forums/show....php?t=2262458
Old 10-30-2011, 11:15 PM   #46
Sw20matt
Member#: 268770
2006 WRX TR
I had the same problem with my inlet. I had to pull the tgv and install the intake then reinstall the tgv. it was a very tight fit but I got it. you might need to get a coupler with a little bit of a "S" shape to move it over. but A rotated kit would be best.
Sw20matt is offline   Reply With Quote
Old 11-05-2011, 01:01 AM   #47
hardhitter_alert
Member#: 293841
2007 STi
Everything installed.. primed turbo and started it up.. time for tuning. One issue is that the coupler hits the electronic throttle body plug and I had to grind it but it still hits.
Old 11-05-2011, 01:30 AM   #48
hardhitter_alert
Member#: 293841
2007 STi
ported tgvs and intake:
Old 11-05-2011, 09:26 AM   #49
Psychoreo
Member#: 79643
2015 WRX STI
What'd you do to make the turbo fit? (pics take too long to load on mobile.)
Grind down the outside of the tgv?
Old 11-05-2011, 09:51 AM   #50
Tut4u2
Member#: 40424
05 STi
Exactly what he did.
LOTS OF NEW PARTS! AP v2!TXS TBE! MORE! nothingclub Engine/Power/Exhaust 27 08-14-2007 04:08 PM
FS: '85 MR2, lots of new parts. daniel_gabriel Private Vehicle 'For Sale' Classifieds 0 06-08-2006 10:31 AM
Fresh pics of the Mighty WRX, lots of new parts!! MightyWRX02 Member's Car Gallery 71 12-09-2005 09:47 PM
Lots of new parts must go!!! Yellow03Wrx Tri-State Area Forum 0 02-20-2003 08:09 PM
Lots of new parts in stock today! Z1 Performance Tri-State Area Forum 14 05-22-2002 12:45 PM
