Old 10-20-2011, 01:33 PM   #1
scooby24
Member#: 56414
2004 Forester XT 5MT
Default Rev matching in scope with AP?
Does the AP have the functionality in scope to, at any point, be able to develop a rev matching function when downshifting, similar to that of a 370z? Would the logic be able to detect if you were in a higher gear, as soon as sensing you went into a lower gear, rev match before clutch is engaged?
If it does, Cobb, you'd be my hero.
scooby24 is offline   Reply With Quote
Old 10-20-2011, 01:37 PM   #2
badmeat
Member#: 213680
2004 STI
I don't really know if an ecu would be able to detect and react to you pushing in the clutch and selecting a lower gear to rev-match in time...
The car would essentially have from the time that you select the lower gear(with the clutch already engaged) until the clutch begins to disengage to rev. That seems like tenths of a second, if that. I suggest learning heel-toe or side-foot method.
badmeat is offline   Reply With Quote
Old 10-20-2011, 01:44 PM   #3
scooby24
Member#: 56414
I do currently rev match manually using heel-toe, but it's difficult in all but my puma's so I generally resort to just blipping before going for the brake. After seeing it in the 370z I was just thinking, you know, they are managing to do it...why couldn't we?
Old 10-20-2011, 02:13 PM   #4
KOJAK-02-WRX
Member#: 208052
2004 SGM FXT-6speed
*SOLD* 02 PSM WRX
It wouldn't even have to detect you downshifting, it could just keep the throttle up for the first 2 seconds after you put in the clutch, since it shouldn't take that long to shift, and if you don't reengage the clutch in that time it would let the engine idle down as normal.
KOJAK-02-WRX is offline   Reply With Quote
Old 10-21-2011, 10:07 AM   #5
Cobb Tuning
Member#: 4803
There are a lot of different hacks that would be possible for the Subaru ECU. We are currently working on speed density for the 2.5L turbo Subarus. Beyond that, we have not made any decisions on any future improvements.
Bill
passing emmisions in CA with AP V1 JPinn AccessPort 11 01-05-2008 05:50 PM
Low Boost in STI with AP? Poppa smurf Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 10-21-2004 01:56 AM
Question about Raised rev limiter in 1.20 AP bren wrx Engine Management & Tuning 4 10-05-2004 04:05 PM
rev matching in an auto ScoobyBoy Transmission (AT/MT) & Driveline 23 07-26-2002 04:59 PM
it may be a dumb question, but what is rev matching? SubieNubie General Community 6 02-13-2002 01:18 PM
