Old 08-06-2002, 09:17 AM   #1
trboCIVIC&WRX
Member#: 6426
Default HKS fuel cut defender?? are you using it?
I am looking for any input from people who are actually using the HKS fcd...
-how well does it work?
-where does it tap into?
-have you had any problems with it?
-pros/cons?
etc.. etc...
TIA
trboCIVIC&WRX is offline   Reply With Quote
Old 08-06-2002, 09:30 AM   #2
Blue_2K2_WRX
Member#: 20502
WR blue
I am very intersted in this also. Does this help with the computer freaking out when I put on my MBC.
Blue_2K2_WRX is offline   Reply With Quote
Old 08-06-2002, 04:09 PM   #3
trboCIVIC&WRX
Member#: 6426
WOW! nobody is using this?
I dont know if that is a good thing or a bad thing....
Old 08-06-2002, 05:03 PM   #4
mitch808
Member#: 10228
2002 Subaru WRX
Ever thought of searching? There were a few posts a while back that people had installed it and found some caveats, etc.
Other then that, it worked for them.
Try FCD as a search word
mitch808 is offline   Reply With Quote
Old 08-06-2002, 08:23 PM   #5
gazoline
Member#: 10595
'98 BMW M3
I use the HKS FCD with my VF30, STI injectors, HKS EVCIV & HKS SAFR etc. Since installing the FCD, I have yet to hit boost cut and have had no problems with it whatsoever. It is completely invisible, which is exactly its purpose...
You can tap into the ECU - which wires exactly, I forget, but call HKS USA and they will give you the exact colors/codes and get the wiring diagram off of www.northursalia.com
Also, I set the FCD to "10". Are you using a bigger than stock turbo? cause the stock turbo probably doesn't work great above 16.5 psi......
gazoline is offline   Reply With Quote
Old 08-06-2002, 08:39 PM   #6
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
One word : potentiometer.
It works, it's simple, and it's cheap.
Just worry about lack of fueling when you get into the higher boost levels.
Old 08-07-2002, 09:06 AM   #7
trboCIVIC&WRX
Member#: 6426
thanks for the input guys!
and yes, I "tried searching"
Im not exactly new around here...
geez! everybody is so snippy these days...
Old 08-07-2002, 09:16 AM   #8
Quantum-Racing.com
Vendor
Member#: 20483
I agree with 8Complex. The HKS item is very cheap and simple but the MkIV guys say stay away from it. The GReddy BCC is a clamp, so it's better in design. I don't know if it will work for the EJ20 or not.
Quantum-Racing.com is offline   Reply With Quote
Old 08-07-2002, 09:59 AM   #9
TurboRex
Member#: 8635
04 STI, 07 FXT
I use the mrt and it is a clamp. It is pretty cheap and so far works just fine.
Greg
TurboRex is offline   Reply With Quote
Old 08-09-2002, 05:22 PM   #10
tranjo
Member#: 11745
2002 Rex cobb tuned
Greg
Is it a clamp for MAP? I think I am experiencing boost cutt.
I have STI injectors, supra pump, APS R/T spec kit.
seems to cut something at heavy boost over 120MPH(really pushing the car(18-19)PSI
Since I have a unichip it should remove fuel cut?right?
I was told maybe I have air prob?
I think I need a clamp.
what do you think?
tranjo is offline   Reply With Quote
Old 08-07-2003, 07:53 PM   #11
aREX4X
Member#: 18781
I have a Vishnu Stage 2 (unichip) and I get the cut in 4th gear and it's annoying as hell. Second and third gear I get a nice 17.5 psi then on a cold day I get 18 psi in fourth and experience boost cut. I run a MBC and like it, except for this. I am really looking into getting a FCD but am worried about overboosting. I have the pump and STI injectors, is it okay to get like 18-19 psi?
X...
aREX4X is offline   Reply With Quote
Old 08-07-2003, 08:09 PM   #12
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
Try pm'ing Pace
He made a few of them, I'm running his right now.
Some loose details:
- Adjustable clamp-type FCD.
- Professional black-box packaging.
- Requires splicing into ECM harness (3 wires).
- Installation instructions included for UTec'd cars, as well as for those with no aftermarket EMS.
- Pre-configured clamp voltage with instructions on adjustment (should not be necessary).
- In-built circuit protection from voltage spikes.
- To be priced under $50.
MAD REX is offline   Reply With Quote
hks fuel cut defender midnight2.5rs-t Engine/Power/Exhaust 26 09-09-2008 07:27 PM
Hks Fuel Cut Defender perrinphantom Engine/Power/Exhaust 0 06-18-2007 01:01 AM
hks fuel cut....60 shipped never used vatorn10 Engine/Power/Exhaust 7 11-27-2006 12:09 AM
Apexi Super Afc2 Controller And Hks Fuel Cut Defender For Sale!! Waking The Fallen Engine/Power/Exhaust 2 09-14-2006 12:33 PM
looking for hks fuel cut defender wiring diagram boogerwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-13-2002 11:16 PM
