Old 10-21-2011, 01:05 PM   #1
93GC8Dub
Member#: 217150
1993 Wrx rhd gc8
Default Help a Scoobie out!JDM
For starters i was having an issue where at high RPM's i would get random sputters/ almost like a fuel cut. I havent yet done coilpacks so i believed that was issue till i was reading a thread on someone with similar issues which resulted in listenning to another member about adding saulder to pins on the MAF cause they get issues over time. I added the saulder and the car wasnt the same again... this resulted in me tracking down a used 22(86)*0AA160 MAF . I then tried it, and turns out they were different as one had 5 pins and the original 4. so i Purchased a genuine subaru 4 pin MAF for $500+ . to take it home and it STILL NOT WORK.
So i try and erase the code 23 from the ecu but...unsuccesful i even did the infamous no battery for 30 min trick...and last of all i started the car without the sensor and plugged it in to notice no change. Help me out guys.
Subaru-"this part is non refundable" opted to test it for me. and this will be done today, latest tomorro
My thoughts: If test fails..
are their any fuses related to the MAF at all?
where do these wires to the MAF come from? -could i have grounded something out or shorted it? what might i have done this to?
The fault code 23 online could be the curcuit too...Anything i could have screwed up?
Could i have screwed up the ECU in toying with it like this?-its still giving me a code and not working correctly....???
HELP
*might be reversed
93GC8Dub is offline   Reply With Quote
Old 10-21-2011, 02:12 PM   #2
Jarrod164
Member#: 253937
1995 WRX
Well if it was fuel cut wouldn't your car hit a wall basically? I was getting misfiring/sputtering at high boost and that is definitely a problem with the coils. To go off and buy a $500 maf sounds absolutely ridiculous though. Are you on any of the other forums? I thought I saw something on jdmvip about soldering the maf. Just found a thread on WSC but the guys car was fixed.
Jarrod164 is offline   Reply With Quote
Old 10-21-2011, 06:01 PM   #3
93GC8Dub
Member#: 217150
1993 Wrx rhd gc8
Ya saldering the MAF was what i thought to be a win win, if it wasnt the problem, so what? well it hooped my sensor and threw an engine code when i did it, thats why i had to get a new MAF but now its still showing the same fault code(23) and i have a new maf...????....???? the coils i intend on doing here soon but i did the solder to see if it "might" have been the problem
Old 10-22-2011, 12:56 AM   #4
Jarrod164
Member#: 253937
1995 WRX
Reset your ecu?
Old 10-22-2011, 01:43 AM   #5
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Check your ignition coils.
Marnix is offline   Reply With Quote
Old 10-22-2011, 03:03 AM   #6
derk
Member#: 162625
your coilpacks are worn out, get new ones or rewire for GD coils
derk is offline   Reply With Quote
Old 10-23-2011, 01:44 PM   #7
93GC8Dub
Member#: 217150
1993 Wrx rhd gc8
The car was idling and working fine before the code was tossed... I will go
Get them and do the conversion but why would the coilpacks be the issue with a fault code 23?
Old 10-23-2011, 02:10 PM   #8
derk
Member#: 162625
oh. i didnt read the whole thing, just the part about high rpm sputter
have you tried resetting the ecu AFTER you installed hte new maf?
if so, have you checked the actual wiring harness for the maf for damaged/decayed/frayed wires?
the high rpm stutter issue definitely is indicative of a coil pack issue though, you probably have more than 1 problem going on at once
Old 10-23-2011, 06:37 PM   #9
93GC8Dub
Member#: 217150
1993 Wrx rhd gc8
Ya i did reset it after the new maf was installed... and i noticed that the car is overfuelling now and i think it might be in limp mode and obviously still has the code 23... it doesnt go over say 3000-3300RPM...also it is all over the place for fueling puttering and sometimes not even starting.
wiring harness is good nice and clean connection as far as volts go.
im gonna get the coilpacks right away, but for now the car didnt even start for me today so i pulled the plugs and there was fuel all over them i also noticed that they were a NGK BRK6EIX i believe and the other forums say it should be BRK7EIX
Old 10-24-2011, 01:30 AM   #10
derk
Member#: 162625
running a heat range 6 plug wont really make much of a difference especially if you're just running stockish boost levels, and it definitely wont cause your car not to start.
the plugs might be wet because of a misfire due to no spark, not necessarily caused by an overfueling issue.
try to tackle it one at a time, first do the coil packs just to get that out of the way, since you'll want to upgrade the coilpacks anyway, and that also rules out one of the possibilities (make sure you get a reputable shop to do it for you though, other wise if they **** it up you could be chasing yourself in circles haha)
next, make sure the new maf you got is the correct one for the car, maybe you made a mistake with cross referencing part numbers? try to borrow a maf from a friend with a jdm gc8 with a known working maf
after that, make sure you have adequate fuel pressure, a faulty FPR could definitely cause hard/no start/ stutters
Old 10-24-2011, 03:31 PM   #11
93GC8Dub
Member#: 217150
1993 Wrx rhd gc8
well today i put it back together once and tried starting, it wanted to fire up and i was hearing one piston firing but it still woulnt crank, the fuel pump is priming i can hear it and im thinking if not coilpack(which take a week from subaru and are $117 a peice) that my injectors are mangled, i was reading that the MAF and injectors go hand and hand and by trying to saulder the MAF maybe i grounded, or shorted something out...the pump is a walbro 255 and its pretty much 2 months old...lol i just want my car going, dam haha
Old 10-25-2011, 11:50 AM   #12
Jarrod164
Member#: 253937
1995 WRX
Didn't you buy a new maf though? I don't see how you could be having issues with it if it's new. Buy used coil packs. You can get 4 for $120 I'm sure.
Too bad I just gave away my oem injectors but there are probably a few guys around Edmonton that have a set after going to 550's.
Old 10-25-2011, 12:26 PM   #13
93GC8Dub
Member#: 217150
1993 Wrx rhd gc8
ya i got one right from Suabru, thing is the cars symptoms did change from when the first MAF went after i sauldered it, so i figured it might have been a efective MAF from subaru so I bought one that came off another suby, once i hooked up the slightly used MAF the car didnt start at all with or without the MAF(before it started with MAF disconnected and connected but had no symptom change even when started without conncted and connecting it) so that lead me to pull the plugs to find them covered in fuel, which made me think the issue is spark...I really am not sure, Help me out guys
Old 10-25-2011, 02:12 PM   #14
Jarrod164
Member#: 253937
1995 WRX
Maybe you did short something out when you soldered... are all your fuses ok?
Old 10-25-2011, 06:05 PM   #15
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
If you have fuel on your plugs its gonna be a lack of spark.
Have you checked your coils? Might be time for a coil upgrade.
Can you verify spark when you crank the engine?
Unplug the fuel pump. Pull a coil and put a plug in the coil boot. Have a buddy crank the engine. Depending on your setup you may need to make sure that your coil is grounded. Its a little redneck but if your good on spark you will see your spark plug fire when the engine cranks. If its weak or its not firing consistantly then you have coil issues.
TommyAtomic is offline   Reply With Quote
Old 10-29-2011, 03:05 PM   #16
93GC8Dub
Member#: 217150
1993 Wrx rhd gc8
new plugs installed and coilpacks coming from japan(FML) The car started today and was not pissing the fuel out the rear end like it was last time however it still through the fault code "23" which is MAF like i said though the car is running better with the installed MAF then the first symptoms i have, it temporarily allowed me to rev the car normally and then tossed the MAF code and started not being able to rev past 2400 or so....While at idle, the car ran fairly normal i would say, other then the first innitial start...
Does anyone know what else the fault code 23 could be linked to?
could this in anyway relate to the 02 sensor or ECU?
Any other ideas? I get the coilpacks monday...
Old 10-29-2011, 03:06 PM   #17
93GC8Dub
Member#: 217150
1993 Wrx rhd gc8
I tested all fused but the ones that are big and black(naghhahah)kinda couldnt test those but all the ones under the hood and steering column
WTB: For Bugeye - JDM Headlights, Oem front/rear lip - Help a Vendor Out!! Built Industries Private 'Wanted' Classifieds 4 12-28-2010 11:23 PM
NYC JDM part out, JDM STI rear seat with ski path through, JDM STI door cards andivic Tri-State Area Private Classifieds 8 12-03-2007 11:43 PM
DUo maxwell help me out. JDM ej20g EGT??? supermoose Subaru Conversions 7 09-17-2005 06:20 AM
Would anyone like to help a Scooby brother out Scooby South South West Impreza Club Forum -- SWIC 1 06-15-2001 09:19 PM
Help a Scooby Brother out.. Scooby South Texas Impreza Club Forum -- TXIC 2 06-15-2001 07:36 PM
