Old 10-21-2011, 03:23 PM   #1
Farvardeen
Member#: 182384
2014 Impreza WRX STI
Default Difference between EJ257BG1LB & EJ257BW7CH
I'm trying to replace my 05 sti engine (EJ257BW7CH)
with an engine from an 08 sti (EJ257BG1LB )
(I have checked the part# of both engines,only the pistons had the exact same part# ...but i know that part#s don't give the full story. Are both engines interchangeable? If not is there a high degree of modification required to install the 08 engine into the 05?
Farvardeen is offline   Reply With Quote
Old 10-21-2011, 07:45 PM   #2
Tut4u2
Member#: 40424
05 STi
If you're doing JUST the short block then its a direct swap and no other modifications are needed. The heads are different however so doing a long block is going to cost more money and effort.
Tut4u2 is online now   Reply With Quote
Difference Between WRX & RS WRX-in-LA General Community 30 02-19-2002 11:20 AM
Difference Between 48 & 53 mvstype Brakes, Steering & Suspension 4 12-12-2001 11:37 AM
difference between wrx & wrx sti TemeculaPD Newbies & FAQs 14 10-08-2001 04:29 PM
Difference between P1 & STi 4 pot brakes? VALENTA Brakes, Steering & Suspension 6 12-01-2000 03:30 PM
Difference between 3W-30 & 10W-30? Jason Technical Forum Archive 3 08-13-2000 01:21 AM
