Old 04-20-2012, 01:45 AM   #51
SW21MR2
Member#: 60135
2005 Kona Stink-E
My mom always told me the Brembos were too much brake for me...
Well, originally I was going to go back to stock and sell the car before getting married. Then I decided to keep the car. Then I decided to make it stock but keep the car. Then I decided I'd like to try something else later on down the road.
These brakes are great, and I thought brake feel would be similar since I held onto the lines and mc cylinder brace. I gotta say... the OEM brakes are terrible. Already ordered lines that are WRX specific and pads.
I think I'm going to miss the look more than anything.
SW21MR2 is offline   Reply With Quote
Old 04-20-2012, 07:14 AM   #52
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
Love my new setup. Huge improvement over stock
bluemax189 is offline   Reply With Quote
Old 04-20-2012, 04:23 PM   #53
SW21MR2
Member#: 60135
2005 Kona Stink-E
I have a new brake set up in the works.
Old 04-20-2012, 04:50 PM   #54
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Dirty Smurf
What size spacers are you running?
bicycle_wreck is offline   Reply With Quote
Old 04-20-2012, 07:06 PM   #55
SW21MR2
Member#: 60135
2005 Kona Stink-E
I'm curious too. I ditched my stockers to fit the Brembos. Kinda regretting that now except for the fact that the 5 zigens are WAY easier to clean.
Old 04-20-2012, 07:50 PM   #56
xbeamelite
Member#: 281250
2007 STi Ltd
UGM
you need 3mm spacers to clear the brembos
xbeamelite is offline   Reply With Quote
Old 04-21-2012, 05:49 PM   #57
KNS Brakes
NASIOC Storefront Vendor
Member#: 125739
2015 WRB WRX
Need Brakes? 919.420.0021
You can now run goldies in the rear or FHI 2 pots. More pics to follow
-Ken
KNS Brakes is offline   Reply With Quote
Old 04-21-2012, 06:20 PM   #58
Pearly_Whites
Member#: 164714
2007 WRX TR
Satin White Pearl
-Ken
Huh? Which rotor?
Pearly_Whites is offline   Reply With Quote
Old 04-21-2012, 10:38 PM   #59
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
With this new bracket from KNS, 08+ STI rotor for the goldies, 10+ LGT rotor for the 2-pots
Power6 is offline   Reply With Quote
Old 04-21-2012, 10:52 PM   #60
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
awesome kns!!!!!!
Old 04-22-2012, 09:46 AM   #61
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
very interested in information KNS.
i didnt know that the FHI 2pots and brembo rear 2 pots used the same size rotor, or do they not and just have the same caliper mounting points?. and i cant for the life of me find the sticky with brake specs for all the different suby models.
gsrcrxsi is offline   Reply With Quote
Old 04-22-2012, 11:08 AM   #62
SW21MR2
Member#: 60135
2005 Kona Stink-E
you will have to use 2010+ legacy gt rear rotor for the FHI 2 pots.
Old 04-22-2012, 12:07 PM   #63
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
so the mounting points are the same for brembo and fhi 2pot calipers? or is kns making 2 different brackets? sounds like its the same bracket from his post, but im just trying to clarify.
and the 10+ LGT rear rotor uses the same size parking brake i assume? I already have the front FHI 4-pots on my 2010 WRX, and would like to add the rear 2 pots too.
Old 04-22-2012, 01:46 PM   #64
SW21MR2
Member#: 60135
2005 Kona Stink-E
the bracket will allow you to use either caliper. the mounting holes are the same. the reason why you need to use the lgt 2010 rear rotor is because it's the same dimensions as the 06/07 rotors, but with the same size parking brake as the 08+ wrx and sti.
Old 05-08-2012, 12:48 PM   #65
KNS Brakes
Member#: 125739
2015 WRB WRX
First 10 pairs available to ship by end of this week, just waiting for hardware to show up.
Link to order: Conversion Bracket v2
Please call us if you have any question about rotors for your application.
Here is few pictures of gold Brembo caliper and red 2 pot bolted to 2009 STi knuckle.
Old 05-08-2012, 09:19 PM   #66
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Is there room to use any other kind of fastener, Ken? Those Button Head Allens arent exactly known for holding up to tools very well.
Old 05-09-2012, 08:25 AM   #67
KNS Brakes
Member#: 125739
2015 WRB WRX
Really tight fit.
We will supply Grade 12.9 fasteners though.
I would suggest no air tools and a hex head socket rather than a hex key
Old 05-09-2012, 08:37 AM   #68
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Also, Y U NO USE LOCK WASHERS? I added my own Hardened lock washers to my GD Brembo Bracket (which fit great and is strong as hell, BTW.)
Old 05-21-2012, 02:50 PM   #69
SW21MR2
Member#: 60135
2005 Kona Stink-E
Old 10-15-2012, 08:45 AM   #70
redwrx11
Member#: 278510
2011 WRX Hatchback
Red
What ss brake lines did you use or should i use? sti? i have a 2011 wrx
redwrx11 is offline   Reply With Quote
Old 10-15-2012, 10:23 AM   #71
SW21MR2
Member#: 60135
2005 Kona Stink-E
A lot of companies, like StopTech, have stopped differentiating between the two. The rear WRX brake lines are longer than the STi ones they used to make. Most companies make ones to WRX spec that fit both the Brembos and OEM WRX brakes.
Old 10-16-2012, 12:25 AM   #72
monkiboy
Member#: 202958
2008 wrx
you want to run STI ss lines in the rear. for the front it does not matter if they are WRX or STI; either will work. or if you have existing ss lines on your wrx brakes, you can take the wrx ss lines you have in the front and swap them to the rear and just buy one set of lines vs two.
monkiboy is offline   Reply With Quote
Old 11-20-2012, 04:39 AM   #73
IMADRIVER
Member#: 218883
13 STI
So, you should buy the STI rear DBA rotors or will the WRX rears from DBA work as well?
IMADRIVER is offline   Reply With Quote
Old 11-20-2012, 10:22 AM   #74
SW21MR2
Member#: 60135
2005 Kona Stink-E
You need an STi rear rotor (it's larger in diameter than the WRX rotor and thicker due to being a vented rotor). Just make sure it's dual patterned for 5x100 too.
Old 11-20-2012, 10:27 AM   #75
KNS Brakes
Member#: 125739
2015 WRB WRX
If your you have an 08+ WRX, you can just outright buy a rotor for an 08+ STi, the parking brake is the same as the WRX in 08+.
If you have 02-07 WRX, DBA makes a conversion rotor which contains the parking brake drum dimensions of WRX and the outer dimensions of the STi.
-Nick
First Suspention Upgrade for 2008+ STi ? EssTeeEye10 General Community 7 02-28-2010 11:13 AM
turbo upgrade for 2008 WRX? dedgley Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 04-30-2008 04:57 PM
sti brembos overkill for GC with wrx swap? dcgear Brakes, Steering & Suspension 13 04-09-2008 11:50 PM
Brake Upgrades for 2008 WRX bassmasterrap Brakes, Steering & Suspension 3 12-27-2007 02:56 PM
What brakes for a 2.5RS while staying in STS? MattDell Brakes, Steering & Suspension 7 11-19-2002 09:22 PM
