Old 01-30-2013, 03:44 PM   #76
WRXncrew
Member#: 39970
2008 LGT Spec.B
Quartz Silver Metalic
Originally Posted by KNS Brakes View Post
If your you have an 08+ WRX, you can just outright buy a rotor for an 08+ STi, the parking brake is the same as the WRX in 08+.
If you have 02-07 WRX, DBA makes a conversion rotor which contains the parking brake drum dimensions of WRX and the outer dimensions of the STi.
-Nick
What about for a 2008 - 09 Legacy GT (spec.B) will the brackets work? Also, rear disc with the drum did they change this over to 190mm or is it 170mm for the rear parking drum?
I think I will pull them off to be certain.
WRXncrew is offline   Reply With Quote
Old 01-30-2013, 03:58 PM   #77
KNS Brakes
NASIOC Storefront Vendor
Member#: 125739
2015 WRB WRX
Need Brakes? 919.420.0021
05-09 Legacy uses the older version 1 bracket that we are currently out of stock on but taking reservations. 05-09 Legacy also has the older 170mm drum.
Drums didn't change on the Legacy until 10+.
So you would need our version 1 bracket, DBA converstion rotor OR oversized brake shoes for a legacy
Get it?
-Nick
KNS Brakes is offline   Reply With Quote
Old 01-30-2013, 05:15 PM   #78
WRXncrew
Member#: 39970
2008 LGT Spec.B
Get it?
-Nick
I get it, thanks.
Does the version 1 bracket only fit 05-09 Legacy, or is this for other MY Imprezas to allow the rear 2 pot Brembo?
Old 01-30-2013, 05:18 PM   #79
KNS Brakes
Member#: 125739
2015 WRB WRX
version 1 fits up to the 09 legacy, up to the 07 wrx, and up to the 08 forrester.
Not sure if that answered your questions?
-Nick
Old 02-01-2013, 06:31 PM   #80
WRXncrew
Member#: 39970
2008 LGT Spec.B
-Nick
I just sent an email for quote on rear brake upgrades.
Also, does the V1 rear brackets allow the FHI rear calipers to mount as well, or just the rear 2 pot Brembo?
Old 02-04-2013, 11:50 AM   #81
KNS Brakes
Member#: 125739
2015 WRB WRX
Got it, no the V1 bracket does not allow the FHI calipers to mount.
-Nick
Old 02-04-2013, 01:24 PM   #82
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
KNS,
i see the pics you have from test fitment of this bracket are on an STI rear knuckle. i am planning to install the FHI 2-pots in the rear soon, on my 2010 WRX.
so for that i would need:
this bracket + hardware
10+ LGT rear rotors
will the dust sheild have to be trimmed/removed? obviously this isnt necessary on the STI
gsrcrxsi is offline   Reply With Quote
Old 02-04-2013, 01:35 PM   #83
KNS Brakes
Member#: 125739
2015 WRB WRX
Yes you will need our V2 bracket which we have in stock with its hardware, and you will need the 10+ rear rotor, which we also have in stock.
Most likely not you won't have to trim the dust shield.
-Nick
Old 02-06-2013, 04:35 PM   #84
the_truth
Member#: 332140
Chapter/Region: HIIC
2013 WRX
Just an FYI, the 08+ STi rear calipers use a different bolt than recommended. The part number suggested are too short and have a different thread pitch.
the_truth is offline   Reply With Quote
Old 06-21-2013, 11:04 AM   #85
SW21MR2
Member#: 60135
2005 Kona Stink-E
Pictures fixed on first post... sorta. I don't remember which ones were up there. (-_-!)
SW21MR2 is offline   Reply With Quote
Old 08-30-2013, 09:35 PM   #86
stimofo808
Member#: 367011
Thank you for posting your install notes.
I'm about to start gathering parts for this.
Please clarify:
How do the 2008+ STI Brembos mount on the WRX hub? Are there brackets and does it fit?
Do I reuse all the STI caliper bolts on the WRX hub?
What size are the rotors?
Instead of triming the rear dust shield, would STI dust shield work on the WRX?
When removing the brake lines to swap to SS lines, how do you prevent the fluid from coming out?
What do you mean by "The bend on the (rear) caliper side is different." If I ordered STI SS lines front and rear, would that work out fine?
stimofo808 is offline   Reply With Quote
Old 08-31-2013, 01:11 AM   #87
yongsik_park
Member#: 228107
2005 Impreza WRX
Dark Grey Metallic
Didn't you need a big brake adapter for the rear?
yongsik_park is offline   Reply With Quote
Old 08-31-2013, 02:05 AM   #88
SW21MR2
Member#: 60135
2005 Kona Stink-E
Please clarify:
The 2008+ STi Brembo calipers are a direct bolt on to the 2008+ WRX hubs. You use the STi bolts because the calipers have a different thread pattern. The hubs are smooth bore, so the bolts just slide through the hub and thread into the caliper.
When changing lines, even just changing the calipers, you can't stop the fluid from coming out. You just have to bleed the brakes after installing the calipers and/or lines.
The rear dust shields on the WRX are too small in diameter, and they will touch the STi rear rotor. You either have to bend it out of the way or remove it completely. It is spot welded on there. If you're going to replace it with an STi rear dust shield, you'd either have to spot weld it on, glue it, or rivet it on. I'm not sure if you can just buy the rear dust shields.
Old 08-31-2013, 02:06 AM   #89
SW21MR2
Member#: 60135
2005 Kona Stink-E
No, the 08+ rear STi Brembo bolts perfectly to the 08+ WRX hub.
Old 08-31-2013, 02:47 AM   #90
stimofo808
Member#: 367011
THANK YOU! Big help. I appreciate your time.
Old 12-16-2013, 03:08 AM   #91
WhatsASubie
Member#: 362544
2013 Wrx
satin white pearl
question do i have to cut the rear dust guards? can i just remove them?
WhatsASubie is offline   Reply With Quote
Old 12-16-2013, 06:08 AM   #92
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
This was answered 3 times in posts above you.
For anyone else who can't scroll up or a page back.
You have to bend the shield back or remove the dust shield. It is spot welded to the hub. You can achieve this by drilling the spot welds or bending it back and forth until the welds release... This is YOUR choice.
It is doubtful that you can reweld the shield back on.
Louie is offline   Reply With Quote
Old 02-25-2014, 10:47 PM   #93
cano
Member#: 372988
Chapter/Region: PRSIC
08 WRX (ge)
sf5 fozzie
The rear 04 brembos dont work on the 08 wrx at all?
cano is offline   Reply With Quote
Old 02-26-2014, 05:17 AM   #94
KNS Brakes
Member#: 125739
2015 WRB WRX
You need our bracket to do that.
http://www.knsbrakes.com/c/kns-bracket
Scroll down to the V2 bracket
Old 02-26-2014, 05:26 AM   #95
cano
Member#: 372988
08 WRX (ge)
sf5 fozzie
Thanks! Great help!!!
Old 06-12-2014, 07:43 AM   #96
RosscoWRX
Member#: 324464
2010 WRX Hatch
I'm looking into this and trying to get my hands on an 08+ set of Sti Brembo's for my 2010 WRX. I'm running Work Kiwami's 18x8.5 +47 and was wondering if anyone knew if they would clear for sure or not. Also will a 3mm spacer in the front allow me to clear on stock rims like the 2011's from my understanding or would I have to run larger spacers.
RosscoWRX is offline   Reply With Quote
Old 08-05-2014, 07:48 AM   #97
point78
Member#: 344329
2008 Wrx, 6mt
I put a set of goldies on my '08 WRX yesterday, front and back.
Went with KNS rotors, Hawk5.0 pads, & Goodrich lines.
Everything bolted right up no problem.
I "thought" the wrx brakes were good enough.
I'm going to need stickier tires...
point78 is offline   Reply With Quote
Old 08-05-2014, 09:57 AM   #98
KNS Brakes
Member#: 125739
2015 WRB WRX
Feedback on the Hawk 5.0 pads would be fantastic, glad we were able to help.
-Nick
Old 08-05-2014, 11:12 AM   #99
point78
Member#: 344329
2008 Wrx, 6mt
I about gave myself whiplash when I was backing out of the garage & tapped the brakes for the first time.
Huge difference with the new setup vs stock. Much less pedal force & travel required.
I've only had the stock pads on this wrx.
Took it out to a deserted road last night and did the bed in of 7 medium stops, from highway speed, drove another 10 mins, did another 7 medium stops, then did 6 hard stops just at abs activation.
Initial bite feels good, it's not to grabby, but add a little more pedal force they really bite in and hold.
I drove from Denver, up to my place in the mountains. (I'm at 9200')
There are two long downhill sections, like 10-15 minute long. With the stock setup I was really careful not to heat the brakes to much, and still I managed to warp a rotor.
I tested these out much more than I normally would. I couldn't really tell a difference between cold(it was about 50deg outside), or when I had really put some heat into them.
No shudder or squeaking from the pads(so far), and I left the shims out of the front.
I really like them.
Great service from the guys at KNS too-thanks for sending them out so fast.
Old 08-06-2014, 03:17 AM   #100
clyne08
Member#: 383428
Big thanks for writing this guide
I searched the UK and spoke with our biggest aftermarket brake specialist but due to lack of interest in the WRX narrowbodies in England nobody could help.
Anyway i found your guide bought the bits and fitted them yesterday no problems at all, i am currently bedding in the discs and pads for the manufacturer's recommended 300 miles, but they feel better already even under light braking.
clyne08 is offline   Reply With Quote
First Suspention Upgrade for 2008+ STi ? EssTeeEye10 General Community 7 02-28-2010 11:13 AM
turbo upgrade for 2008 WRX? dedgley Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 04-30-2008 04:57 PM
sti brembos overkill for GC with wrx swap? dcgear Brakes, Steering & Suspension 13 04-09-2008 11:50 PM
Brake Upgrades for 2008 WRX bassmasterrap Brakes, Steering & Suspension 3 12-27-2007 02:56 PM
What brakes for a 2.5RS while staying in STS? MattDell Brakes, Steering & Suspension 7 11-19-2002 09:22 PM
