Old 10-22-2011, 11:03 AM   #1
TopSpeed
Member#: 78884
Go faster
at TopSpeed
Default TopSpeed - 2011 Sti - [email protected] - Stock tmic, Dom 1.5, E85
Last night we were finally able to break away from our busy shop schedule and get our TopSpeed Motorsports 2011 Project Sti to the drag strip. Even with less then ideal track conditions we came away with some runs.
Our main goal all along with this TopSpeed Project has been to follow the K.I.S.S principal. Keep It Simple Stupid. No exotic ported heads, sleeved blocks, JDM cams.... etc. We wanted to build this one around a very mild well behaved setup. One that doesn't break the bank so to speak, but lays down exotic car numbers. Hard to argue with numbers like this that we have exceeded our goal.
TopSpeed has done the following mods:
TSM SS1 shortblock
Invidia EQL race header
Invidia catted downpipe
Invidia catback
Blouch Dom1.5 (10cm)
ID1000cc
Walbro 390
Inlet hose
Cobb APv2
TopSpeed E85 Tune
TSM Cai
What we feel is even more impressive about this run is the fact the car is still on the OEM STOCK TMIC, stock heads, cams, and intake manifold w/tgv.
For those video BUFFS
Boost for all the drag passes was limited to 24-25psi at redline do to the TMIC intercooler not being able to support the CFM needed and currently the car makes 443whp and 486tq.
With track temps around 55f last night traction was a big issues. I actually on one run got a 1.63 sixty foot but then spun hard going into third down the track. I really feel this car has a 10 pass in it with better conditions and surely one with a larger TMIC.
Here is the timeslip
Thanks,
Doug
TopSpeed is offline   Reply With Quote
Old 10-22-2011, 12:32 PM   #2
rexblake
Member#: 178426
2010 S4
Gray
Very nice!
rexblake is offline   Reply With Quote
Old 10-22-2011, 12:42 PM   #3
big18g
Member#: 165872
2005 wrx
black
Both the plot and the slip are impressive to say the least. Great job
big18g is offline   Reply With Quote
Old 10-22-2011, 07:18 PM   #4
pharo
Member#: 79266
2005 05 Sti
the slow color
That is an awesome trap speed and e.t. Is there a particular reason you choose to upgrade to a built block but wanted to continue using an oem tmic?
pharo is offline   Reply With Quote
Old 10-22-2011, 07:23 PM   #5
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Sick! TMIC POWER
Junior2JZ is offline   Reply With Quote
Old 10-22-2011, 09:05 PM   #6
jdpsearcher
Member#: 291214
2011 STI Sedan
PBP
I have to say this is pretty close to the perfect daily driver on E85.
Are you still on the stock clutch?
I would love to see a bit more work say:
TGV deletes, bigger TMIC, fully coated or wrapped header, up pipe, downpipe, turbo blanket, EWG.
How do you think some headwork would affect this combination? Nothing radical, some bigger valves, mild port work and 262 cams.
I think that would put you over 500whp and torque, and increase top end a bit.
jdpsearcher is offline   Reply With Quote
Old 10-22-2011, 09:33 PM   #7
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Very nice! How are you able to keep fueling up with the ID1000's at that power level on E85?
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 10-22-2011, 09:37 PM   #8
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
-- Ed
The walbro390(400?) holds fuel pressure. Id1000s will flow lots of fuel at higher pressures.
Old 10-22-2011, 09:40 PM   #9
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Is there an aftermarket FPR on this car to bump base pressure?
-- Ed
Old 10-22-2011, 09:42 PM   #10
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
-- Ed
Probably not, but you don't need one to hold pressure up top. You just need a fuel pump that can hold pressure and not drop off.
Old 10-22-2011, 10:48 PM   #11
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
I understand that, but I still find it tough to believe that the ID1000's could flow that much at the stock base pressure.
-- Ed
Old 10-22-2011, 11:24 PM   #12
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
-- Ed
They would be flowing around 1240-1260cc holding 68-70psi to red line. That is plenty of fuel for 450whp on e85
Old 10-22-2011, 11:51 PM   #13
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
The relative pressure across the injector doesn't change from base. The best you can hope for is for a consistent relative pressure across the rpm range.
-- Ed
Old 10-23-2011, 12:27 AM   #14
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
-- Ed
Exactly what I am saying. The id1000s will flow 1240-1260cc with 68-70psi pressure. The walbro400 can sustain that pressure across the rpm range while the other smaller pumps drop to 55 and reduce the injector flow over 100cc.
Old 10-23-2011, 12:46 AM   #15
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
You're not getting it. The pressure across the injector doesn't change from static. As far as the injector is concerned its always seeing a relative pressure of ~3bar. At 3bar the ID1000's flow less than 1000cc.
-- Ed
Old 10-23-2011, 01:11 AM   #16
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
-- Ed
You know that fuel pressure rises right? How does the pressure stay at 43 when you put 25psi of boost into the manifold, it is a rising rate system... Rail pressure shoots to around 68-70psi, so now your injectors are seeing 70psi and have a flow capability of 1250+cc.
Old 10-23-2011, 01:54 AM   #17
TopSpeed
Member#: 78884
Go faster
at TopSpeed
Jr. When the fuel pressure rises so does the boost pressure. This is done at an equal 1/1 ratio so the relative fuel pressure doesn't change. The whole concept is to keep fuel pressure rising at the same rate as manifold pressure. The injectors won't flow more because they are having to work against the boost pressure.
Ed. 55 psi base pressure.
Posted from my phone so sorry if its a bit off
Doug
Old 10-23-2011, 02:57 AM   #18
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Doug
Thanks Doug.
I was trying to explain but did not word it clearly enough aparantly. The only way relative fuel pressure can rise is if the pump is over running the FPR or if you're using an RRFPR (rising rate fuel pressure regulator).
So are you running an aftermarket FPR to bump pressure or did you modify the stocker?
-- Ed
Old 10-23-2011, 02:59 AM   #19
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
It's actually not a rising rate system. It's a 1:1 system. For every psi of manifold pressure, fuel pressure changes by 1psi as well. This maintains a constant relative pressure across the injector.
-- Ed
Old 10-23-2011, 09:57 AM   #20
javid
Member#: 54304
04 STi
TopSpeed-dAng!
Nice work Doug!
Go corn or go home?
javid is offline   Reply With Quote
Old 10-23-2011, 11:49 AM   #21
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
hahaha, ok ok I get what you are saying. Just different wording, but same concept.
Old 10-24-2011, 10:36 AM   #22
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
Very nice! 24-25psi, so it seems that turbo really like boost levels in the mid 20s. AFR? Just curious.
tazswing is offline   Reply With Quote
Old 10-24-2011, 10:54 AM   #23
TopSpeed
Member#: 78884
Go faster
at TopSpeed
Thanks Doug.
-- Ed
Its a stock modded FPR on this car. We have seen issues with the 2011 cars needing a FPR, but we are still running the stocker on ours.
~Cicio
Old 10-24-2011, 11:20 AM   #24
THE_SMURF
Member#: 260624
2007 Z06/ZX10R
omg this is sick... what would make it even more sick if it was a 2011 WRX
love your work, cant wait to see what it does on an upgraded tmic...
THE_SMURF is offline   Reply With Quote
Old 10-24-2011, 12:03 PM   #25
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Wow! Maybe I missed it but what does the car weigh?
wgr73 is offline   Reply With Quote
TopSpeed Motorsports - **2011 STI** Invidia Race Header Tested!! TopSpeed NASIOC Project Cars 79 02-22-2016 07:37 PM
TopSpeed Motorsports | DOM 1.5 TESTING COMPLETE!!! TopSpeed Proven Power Bragging 225 10-16-2014 08:25 PM
TopSpeed Motorsports - 2011 STI Baseline & Protune Results! TopSpeed Proven Power Bragging 18 01-15-2011 05:03 PM
Evo bragging, 11.010 @ 124.55 on stock turbo neonglh Proven Power Bragging 75 01-04-2010 10:35 PM
AMS GT30R Kit with TXS Top mount 11.3 @ 124 AMS Proven Power Bragging 97 06-17-2008 07:14 PM
