Old 10-23-2011, 10:26 AM   #1
2002t-wrex
Member#: 37729
2004 WRX Wagon
Default A/C doesnt work after JDM Ver7 Swap into 2003 WRX
Hey everyone,
After swapping a JDM STi ver 7 motor and ECU into my 03 WRX my A/C and fog lights no longer work. I am assuming this has somthing to do with the JDM ECU. Does anyone have the pinouts for this ecu so I can get these working again?
Thanks everyone!
2002t-wrex is offline   Reply With Quote
Old 10-27-2011, 06:03 PM   #2
ECMFab
Member#: 281995
Hey I was thinking about this very same swap. Did you keep your 5 speed or do a full conversion?
ECMFab is offline   Reply With Quote
Old 09-17-2012, 01:48 AM   #3
imppu2001wrx
Member#: 137499
2002 STi Wagon 60-1
I have this same issue, my A/C is not working after swapping to V8 JDM STi ECU. I have two other problems too, speedo and AVCS is not working either.
imppu2001wrx is offline   Reply With Quote
Old 09-21-2012, 05:02 PM   #4
simon021
Member#: 157532
2002 MY03 EJ207 E85
Dom 1.5XTR Twinscroll!
Anyone figure this out? About to swap in an EJ207 myself and just got my AC recharged after not having it for an entire summer. It would sure be a shame if it didn't work!
simon021 is offline   Reply With Quote
Old 09-21-2012, 05:13 PM   #5
ECMFab
Member#: 281995
I swapped a version 7 into my bugeye and everything was fine. I used the jdm engine harness and jdm ecu. I then repinned my usdm chassis harness with the shielded wires from the jdm cut chassis harness to the ecu and used the version 7 smaller ac compressor then put in new o rings for the fittings and got it charged.
Old 09-21-2012, 06:52 PM   #6
25rsti
Member#: 166324
How did you guys plug in your ac? My jdm ac plug doesnt match up to the my 03 wrx plug for the ac.
Old 09-21-2012, 07:00 PM   #7
ECMFab
Member#: 281995
Use the JDM engine harness. It plugs right into the USDM chassis harness..
Old 09-21-2012, 07:02 PM   #8
25rsti
Member#: 166324
I am using the jdm engine harness. Everything else is plugged in except the ac.
Old 09-21-2012, 07:16 PM   #9
ECMFab
Member#: 281995
You took off the jdm ac compressor? That's the one you should use.
Old 09-21-2012, 07:48 PM   #10
25rsti
Member#: 166324
Nope. JDM complete. JDM a/c. My wrx a/c plug doesnt plug in and has 3 wires, the plug coming off the jdm a/c only has one wire too.
Old 09-21-2012, 09:36 PM   #11
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
Use the USDM compressor and it works just fine, you have to swap over the US compressor mounts since the JDM compressor is slightly different. you just flop it out of the way while swapping to avoid venting the system.
The JDM compressor that came on my motor was rusted as hell inside, they are not ment to be left open to the elements as most are once the hoses are cut.
lukeskywrx is offline   Reply With Quote
Old 09-22-2012, 07:35 AM   #12
25rsti
Member#: 166324
I heard that's the easiest way BUT I don't have a usdm one. I'm building a shell I bought.
Old 09-22-2012, 10:06 AM   #13
ECMFab
Member#: 281995
Did you get a complete engine along with a complete engine harness? If so, it should be hooked up already. I don't understand what the issue is. Mine was already plugged in as far as I know. I just slightly bent the lines going to the compressor so the usdm ac lines would work on the jdm compressor.
Old 09-23-2012, 09:21 AM   #14
25rsti
Member#: 166324
I got the complete engine harness. The issue is; there is a plug on the a/c. IT plugs into the a/c plug from the cars "in engine bulkhead harness", not the engine harness.
Old 09-24-2012, 08:29 AM   #15
ECMFab
Member#: 281995
Hopefully someone else chimes in. I dont recall having any plugging in issues at all, and definitely dont remember swapping a plug to make it work. My chassis was an 02 and I don't think there is a difference between the 02 and the 03. As far as I remember, everything plugged right in.
Old 09-25-2012, 06:53 AM   #16
25rsti
Member#: 166324
Until I start my car I wont know if it works, but I spliced, soldered, heatshrinked and plugged in my A/C. I had found an old a/c from my other bugeye and just used that plug.
Jdm 6mt swap into 04 wrx Mr.BlackNorris Subaru Conversions 4 02-12-2012 06:14 PM
How to make DCCD work on a 6MT swap into a WRX (or other non-STi) TROLL Transmission (AT/MT) & Driveline 45 01-23-2011 05:32 PM
Reputable source for jdm transmission? Swapping into 07 wrx q's.. Trevor723 Subaru Conversions 0 02-15-2009 09:13 AM
JDM V7 swap into 2002 WRX, Will it pass NYS inspection?? jonepachek Subaru Conversions 1 08-20-2005 01:25 PM
AC lines after V7 sti swap into a wrx.. cronic Subaru Conversions 3 02-20-2004 10:16 PM
