Old 10-23-2011, 10:58 AM   #1
turbo sol
Member#: 245106
2004 WRX Wagon
San Remo
Cool Killer B / STI pan install on EJ205 DIY
I installed a new STI pan and Killer B pickup for better oil control and peace-of-mind with the milage i'm racking up on the WRX and the horror stories I have heard about the factory pickup failing. I didn't want to be a statistic. And It wasn't too expensive to make happen.
Parts needed
STI dipstick (I bought it used off this forum)
STI pan (I bought it used off this forum)
STI oil baffle (new from Subaru like $8-10)
Killer B pickup (Fred bean parts had the best price I found)
my process
1. remove intercooler (this is only to get to the pitch stop)
2. undo pitch stop
3. undo bolts on motor mounts holding them to the subframe
4. jack up on transmission to gain 1-2" of clearance on back of pan for the rear 4 bolts on the pan
5. remove driver side heat shield on manifold (if its still there)
6. remover driver side motor mount (maybe not be needed)
7. drop pan
8. remove pickup
9. remove baffle
10. clean pan sealing surface on block
11. install new part (I used lock tight on the pick-up and baffle bolts)
pitch stop unhooked
mount bolts removed
4 rear bolts (you can't see them but they are there)
raising motor - go slowly and be careful
secret weapon
removing 4 rear bolts
pan removed
baffle / pickup installed
turbo sol is offline   Reply With Quote
Old 10-23-2011, 01:33 PM   #2
207STi
Member#: 197062
1998 Swapped Impreza
black
Great write up man. I've said it once and I'll say it a million times. This place needs it's own dedicated DIY sub forum like rs25 has.
207STi is offline   Reply With Quote
Old 10-23-2011, 04:26 PM   #3
nevin95 LSi
Member#: 219571
'02 wrx wagon 288k+
'95 SVX ebony mica
I didn't even take out the pitch stop when I did mine. Really not too horrible of a job, honestly. Did it when I did my EL headers.
nevin95 LSi is offline   Reply With Quote
Old 10-23-2011, 04:43 PM   #4
turbo sol
Member#: 245106
2004 WRX Wagon
San Remo
i didn't even try it with the pitch stop in… If I ever go back in I'll give it a shot!
my factory heat shield gave me tons of problems for space. Running headers or even just having them off would make a BIG difference in the amount of space you have to work in.
Old 10-23-2011, 04:45 PM   #5
nevin95 LSi
Member#: 219571
'02 wrx wagon 288k+
'95 SVX ebony mica
Well, to be fair I had already removed all the manifold stuff, since I was doing that at the same time. So yes, I could see how maybe it would have been needed. But I was still able to raise the motor up enough to get the job done!
Old 10-25-2011, 03:47 PM   #6
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Great write-up!!
Personally, I just loosen the pitch stops so the bushings don't twist. It might not even harm them, but I'm an err on the side of safety kind of guy.
If you've got a decent selection of swivel joints, extensions and arm like an orangutan you can even loosen the pitch stop without remoing the intercooler.
KillerBMotorsport is online now   Reply With Quote
Old 10-26-2011, 05:16 PM   #7
dux10
Member#: 235338
2002 Faggin Wagon
srp
Shoulda got the Killer B baffle as well...
dux10 is offline   Reply With Quote
Old 10-26-2011, 10:00 PM   #8
turbo sol
Member#: 245106
2004 WRX Wagon
San Remo
i thought about the Killer B baffle, but a new OEM baffle is $8. and this isn't a track car. so since it's a DD I'm more than set.
Old 10-29-2011, 03:41 PM   #9
subiefiend
Member#: 266060
2010 corolla S, 09
civic si,09 fj TRD,04 GDB
^^good call! Great dyi walk thru!!:woot:
subiefiend is offline   Reply With Quote
Old 10-30-2011, 09:52 AM   #10
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
2.5 hybrid 367whp/363wtq
i did the same exact install on my 05 wrx because i was installing EL headers. pretty straigt forward install. also, note, if anyone has a larger after market sway bar, you will prob need to lower by removing if from the mounting brackets (not the sway bar end links) good write up!
shadowmd is offline   Reply With Quote
Old 10-30-2011, 09:24 PM   #11
Pinned
Member#: 152707
Is the STi dipstick/dipstick tube different than the 2.0L WRX stuff?
Pinned is offline   Reply With Quote
Old 10-31-2011, 11:56 PM   #12
turbo sol
Member#: 245106
2004 WRX Wagon
San Remo
to my understanding the difference is the low/full markings on the actual dipstick.
Old 03-16-2012, 04:36 PM   #13
bakerderek0
Member#: 303430
2003 WRX Sedan
ah crap, i just got on here to find out how to get the rear bolts out of the pan. I OP said i need the baffle too. I'm installing the Perrin EL Header. They said just the pan & pickup, this is the first Ive heard of the sti baffle being required. I've also learned I need the sti dipstick is needed too, but is the sti baffle really necesarry? guess I need to find out before I get this pan all the way off.
bakerderek0 is offline   Reply With Quote
Old 03-16-2012, 05:06 PM   #14
bakerderek0
Member#: 303430
2003 WRX Sedan
searched. found answer. who'd a thunk it...
Old 03-16-2012, 08:23 PM   #15
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
In case you like to hear it straight from the horses mouth... The baffle is not required, the pan/pickup still fit just fine with an OEM baffle (EJ25 STi or from ANY 2006+ EJ). You can get those used dirt cheap if you're looking to save a few bucks.
Most of the older EJ cars just remark the dipstick with the new "full" level. If you're feeling ambitious, you will need a dipstick and dipstick tube from an EJ25 STi or from ANY 2006+ EJ.
Old 03-17-2012, 01:16 AM   #16
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Good pictures. I suggest that anyone doing this has a few extra pieces of 2x4 and put them under the motor mounts. That way if the jack falls somehow it wont crush your hand.
Removing the pitch mount is a good idea.
Killer B oil pickup install on 04 FXT -- pan won't go back on.... JLee50 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 12-20-2010 08:53 PM
DIY '08+ STi Exhaust Install on '08+ WRX InsideOut104 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 12-29-2009 01:30 PM
STi Fuel Pump on EJ205 + VF39 markman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-06-2007 06:57 AM
2004/05 Perrin STI rails installed on 1998 RS CUNNINGHAM Normally Aspirated with bolt-on Forced Induction Powertrain 15 02-09-2007 04:33 PM
STi injectors installed on a 99 RS WRC 555 Mid Atlantic Impreza Club -- MAIC 0 08-18-2002 11:48 PM
