Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum
Old 08-06-2002, 02:52 PM   #1
SubaruStu
Member#: 8972
2003 WRX Wagon
Question Ottawa - Brake Fluid choices
A quick one for people here in Ottawa. What brake fluid are you using?
Does it really make a difference (for 99% street driving) between
Motul or SuperBlue or Crappy Tire DOT4.
What the choices and where can I get it?
Thanks...Stu
SubaruStu is offline   Reply With Quote
Old 08-06-2002, 03:01 PM   #2
goobie
Member#: 8273
2006 WRX Wagon
Hey Stu,
Personally I don't think you would notice any difference going with a "high performance" brake fluid than you would with crappy tire's finest. Going to DOT 4 would be a good idea though, as I believe (I may be wrong) that the car comes stock with a lower boiling point DOT 3 fluid. I'm not 100% certain for the brakes, but I'm pretty sure the clutch master cylinder comes filled with DOT 3 form the factory.
Chad
goobie is offline   Reply With Quote
Old 08-06-2002, 03:43 PM   #3
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
I bought Motul from Lachute last week.... but it's not cheap stuff.... For a litre, the price was around $35.... but I think it was still cheaper than Mturmel got the Motul from RMR in Montreal....
To do a full flush, you'll need about 700-800ml...
Robin
Robin2 is offline   Reply With Quote
Old 08-06-2002, 07:10 PM   #4
mturmel
Member#: 2473
World Rally Blue
Nope; got it for 17$ for 500ml, IIRC
The other "feature" of a high performance brqke (damn azerty keyboard... ) fluid is its hygroscopic nature, ie it accumulates moisture, so you need to flush it every 6 months or so depending on usage. I'll most likely switch to something less exotic when I flush it for the winter... I did find a difference after a few laps around Shannonville, better fade/sponginess resistance. Unlikely that you'll see a difference on the street unless you drive like Tom... you never boil your brake fluid on the street, hopefully...
Matt in Belgium (T-5 to Nurburgring...)
mturmel is offline   Reply With Quote
Old 08-06-2002, 08:10 PM   #5
Turbo Tin Can
Member#: 18383
son of a bitch
Turbo Tin Can is offline   Reply With Quote
Old 08-06-2002, 08:22 PM   #6
SubaruStu
Member#: 8972
2003 WRX Wagon
I think that I'll save the cash and go with Crappy Tire, since I don't
use the brakes as hard as (Tom) you guys do.
Now how about a "powerbleeder" vs "speedbleeder" nipples vs
con a friend into helping you?
Stu
Old 08-06-2002, 09:24 PM   #7
Turbo Tin Can
Member#: 18383
how did i get dragged into this conversatoin, the funny thing is i probably daily drive much freindlier than u bastards
Old 08-06-2002, 10:06 PM   #8
SubaruStu
Member#: 8972
2003 WRX Wagon
You are right. In your defense, the my only experience with your
driving was at the autocross with the scan tool. You were quite
reasonable (but maybe it had something to do with the police
officer next to us on the Nicholas on-ramp??).
The rest is pure hearsay and I'll have none of it in my thread
Old 08-07-2002, 12:03 AM   #9
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
Does it? I didn't know that! I might go for the regular stuff till next summer then and keep the motul for next spring.
Robin
Old 08-07-2002, 02:44 PM   #10
goobie
Member#: 8273
2006 WRX Wagon
Default Hydrualic Brake Fluid
Actually ALL Hydrualic fluid (Brake fluid included) generally speaking is Hydroscopic by nature. Over time it will draw mosture out of the air/atmosphere thus increasing the H20 content in the fluid thereby reducing the fluid's boiling point. IIRC The hotter the fluid is, the quicker it can absorb water and break down the fluid hydrualic properties.
For regular street driving changing the fluid once, every 1.5 - 2 years should be fine. If you drive hard/brake hard on a regular basis (i.e. lots of track time), you should change the fluid more often, maybe every 6 months as Matt mentioned. Changing it this often for street use would be quite an overkill.
Chad
Old 08-07-2002, 03:16 PM   #11
Turbo Tin Can
Member#: 18383
LOL thread hijacking btw speedbleeders are the cats ass.
Old 08-08-2002, 10:24 PM   #12
Legacy
Member#: 10188
2007 Forester XT
Back to the topic, has anyone else heard that SUPERBLUE is the same stuff in a different container as the heavy duty brake fluid you can buy from FORD that also happens to be blue ?
I was told this recently and have yet to verify.
Legacy is offline   Reply With Quote
Old 08-09-2002, 10:05 AM   #13
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
I've heard of Superblue brake fluid.... supposed to be pretty good and at a decent price........
One guy I know with a Miata uses Superblue...
Robin
STi Brake Pads / SS Brake Lines / Brake Fluid TicketsForMePlease Private 'Wanted' Classifieds 4 11-30-2006 11:47 AM
Just replaced brake fluid...couple of questions...did we replace all the old fluid? ImportVenom Service & Maintenance 9 03-20-2006 11:23 PM
Brake fluids being mixed when replacing the brake fluid? DVN428 Brakes, Steering & Suspension 1 12-06-2004 03:37 PM
Brake Fluid/Steering Fluid/Diff. Fluid/Transmission Fluid Jasno999 Brakes, Steering & Suspension 11 09-27-2002 12:22 PM
How many ounces of brake fluid to switch fluid? Steppin Razor Brakes, Steering & Suspension 3 09-26-2002 07:36 PM
