Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 10-23-2011, 10:43 PM   #1
02 Buru
Member#: 298493
Default fuel pump/injector upgrade 02 WRX
I have a stock 02 WRX, FMIC, BOV, welded internal WG running EWG linked to factory boost control(??not sure??), ~16PSI, ~174hp on a mustang. Looking to upgrade the fuel pump/injectors to something a little more. What size are my stock injectors/fuel pump. What size should i upgrade to ? Im planning for about ~300 to the wheels in the end, maybe less even . Thanks guys.
02 Buru is offline   Reply With Quote
Old 10-23-2011, 10:47 PM   #2
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
you need to call your local tuner with this question. for your power goals, you're going to need a new turbo as well.
oh and get rid of the bov and replace it with a bypass valve.
drewvdw is offline   Reply With Quote
Old 10-23-2011, 10:58 PM   #3
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
don't listen to him about your bov...he obviously hasn't read the bov sticky...
to answer your questions...
for the fuel pump, stock 02 wrx pump is 130lph...the walbro 255lph pump should do just fine for your power goals.
for the injectors, stock 02 injectors are 440cc...if you are staying on regular pump gas, sti pinks (550ish cc's) should do you just fine if you aren't planning on upgrading anymore after that. for some extra headroom on regular pump gas, you could go with something a little bigger in case you decide to go bigger later. if you are going with e85, the injectors need to be in the 850-1000cc range for the stock turbo.
your tuner probably has his preferences to sizes and brands for injectors, so you probably want to talk to him before purchasing to get his opinions.
feel free to pm me if you have any other questions...
amalgrover is offline   Reply With Quote
Old 10-24-2011, 02:53 AM   #4
caesar
Member#: 30745
SRP Greddy(R.I.P)
Bugeye & '99 LandRover D2
If ur going to upgrade pump & injectors youre going to need EMS aswell.Amalgrover got u covered with everything else...
caesar is offline   Reply With Quote
Old 12-08-2011, 07:43 PM   #5
02 Buru
Member#: 298493
thanks guys, def. some good advice for the future. Looks like the first I will be doing is a new fuel pump, as Im pretty sure i just blew mine romping on the highway just now. car barley idles, have to give it gas to keep it alive at ~2300 RPMs. fuel pump makes noise when i turn the key, but the car stalls when i try to go in 1st. definitely looking to get the walbro 255. gotta check to make sure thats my problem first. possibly FPR?
Old 12-08-2011, 11:13 PM   #6
02 Buru
Member#: 298493
Update: Turns out the problem was one of my FMIC pipes came off AGAIN!!!..... Getting new couplers and t-clamps tomorrow.
Old 12-09-2011, 08:41 AM   #7
amalgrover
Member#: 183480
2009 Forester XT
T-bolt clamps FTW ...haven't had a T-bolt blow off yet on any of the cars i have tuned
Old 12-09-2011, 10:18 AM   #8
Dat8687
Member#: 243261
2004 WRX
Java black pearl
You mean recirc it yea he probably should if its not the type that seals at idle
Dat8687 is offline   Reply With Quote
Old 12-09-2011, 08:14 PM   #9
amalgrover
Member#: 183480
2009 Forester XT
99% of your posts make 0% of sense...a bypass valve IS a recirc type valve, and there are ZERO valves on the market that are open at idle...that wouldn't be called a blow off valve or bypass valve, that would be called a vacuum leak valve...
Old 01-02-2012, 05:27 AM   #10
Cftom
Member#: 304726
2004 WRX
is there any benefit to upgrading the fuel pump only? i'd guess no since the injectors can only inject so much.
Cftom is offline   Reply With Quote
Old 01-02-2012, 05:27 AM   #11
Cftom
Member#: 304726
2004 WRX
Old 01-02-2012, 05:55 AM   #12
Dat8687
Member#: 243261
2004 WRX
Java black pearl
Stock injectors are 440s.. Which can support you in the mid high 200s with proper fuel pressure.. But be warned its not wise to run injectors higher than 80 percent duty cycle for long..
300 wheel STI pinks will easily support that but if you want headway go bigger.
Old 01-02-2012, 10:24 AM   #13
RP31
Member#: 123574
2005 stuck-in-garage
CGM STi
Originally Posted by amalgrover View Post
...there are ZERO valves on the market that are open at idle...that wouldn't be called a blow off valve or bypass valve, that would be called a vacuum leak valve...
I believe TurboXS sells one of those.
RP31 is offline   Reply With Quote
Old 01-02-2012, 10:34 AM   #14
amalgrover
Member#: 183480
2009 Forester XT
i think i might have heard of this valve
Old 01-02-2012, 11:57 AM   #15
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
Was this car purchased in the middle of a part out? The mods are very random and some of them actually harmful to performance. Your car makes what most WRXs would make stock on your normal Mustang dyno.
Byzantium is offline   Reply With Quote
Old 03-14-2012, 04:54 PM   #16
SubaDre7
Member#: 242645
bump!
SubaDre7 is offline   Reply With Quote
Old 03-14-2012, 05:23 PM   #17
liv4psi
Member#: 206505
'04 STI
JBP, 360whp 355tq @18psi
Originally Posted by SubaDre7
bump!
For what?
Byz got banned?
liv4psi is offline   Reply With Quote
Old 03-14-2012, 05:25 PM   #18
RP31
Member#: 123574
CGM STi
He did! Hooray!
Old 03-14-2012, 05:27 PM   #19
liv4psi
Member#: 206505
'04 STI
He did! Hooray!
I almost made a celebration thread in General. I tried to like him, since he was helpful in his own way. But try as I might, it always ended in me wanting to kick him the nuts.
565cc blue injectors and Walbro 255 fuel pump for my 02 WRX 02wrxroger Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 04-09-2010 06:33 PM
Walbro 255 lph Fuel Pump - w/ 02+ WRX Setup Kit maddhatteroo7 Engine/Power/Exhaust 2 09-04-2006 01:29 PM
Fuel pump controller for 02 wrx cornerbuddy28 Private 'Wanted' Classifieds 2 08-24-2006 01:48 AM
I need a stock fuel pump for a 02 wrx mesa50w Private 'Wanted' Classifieds 4 07-27-2005 06:11 PM
Fuel pump/injector upgrades for my impreza "L-T" farrell Normally Aspirated with bolt-on Forced Induction Powertrain 11 01-09-2005 05:09 PM
