#1 |
Member#: 177674
NWIC
Hey all. I know have a couple build threads going on right now but I figure I would share this one as well since there is so much love for the GCs.
This project is a compliation of me and a few of my friends coming together to rebuild a car that was lost by my buddy. A freind of his rolled it. Originally this car was owned by a member on this forum that was attempting to do an EZ30r swap to it. After taking it to a few shops and getting hosed he decided to give up on the project and sold it to my buddy over at PIA. I bought a car from a freind of mine that need to get rid of it because he needed cash to buy a new car. It was a 2002 RS that I converted into a stock WRX. I traded this car to get the GC because I wanted the EZ30r for the Legacy. Held onto the car for a long time while I was waiting for time to start the EZ swap and my freind (the one that got his car wrecked) bought his old car back from insurence and was looking for a good 4dr shell to rebuild the car. I sold him this car w/o the EZ and this is where this build starts. All these first pics are from him while he was stripping the car down at my shop. He stipped all the drivetrain out of this car and out of the Forester I just bought (the ForeSTAR build thread car) because I sold some parts off it for the GC. His original car had a Ver 7 STi swap but he was worried that because of the rollover there could have been some internal dammage to the motor so he gave the engine to another good freind of mine for a rebuild. The tranny is also getting a once over by my buddy Mike at PIA so this car is getting worked on from all fronts all at the same time by a small team of misfits. Okay lets start off with the mods list. Engine: JDM EJ20 STi Engine Mods: Balanced internals (crank pulley to flywheel) ACL racing bearings Port and polished cylinder heads ARP head studs Rotated Intake Manifold 850cc Injectors Engine Management: Hydra EMS ECU Innovative wideband Turbo timer (integrated with alarm system) Tune from Maxwell Power Services Turbo: 16G EVO Turbo Mods: Port and polished Tial 38mm wastegate Custom Rotated uppipe, downpipe, and screamer pipe Greddy Ti-C catback OBX FMIC with custom piping Transmission/Drivetrain: Custom build 5 speed PPG semi-straight cut gear set Spec Stage 3 clutch (6 puck) ACT lightweight flywheel 2004 STi R180 Raer Diff/ Hubs/ Brake Swap Brakes: 2004 STi Brembo's custom painted Girodisc slotted rotors Girodisc stainless brake lines Girodisc Magic Pads [b]Wheels/Tires[b] Rota SVN-R 18x10, +30 offset 255/35/18 G-force KDW's 15mm hub-centric wheel spacers Suspension: Tein SS coil-overs -TEMPORARY LOL Perrin sway bars (front/rear) Whiteline anti-lift kit Cusco strut tower bars (front/rear) Interior: 2004 WRX dash assembly 2004 WRX Pedal set 2007 STi gauge cluster 2005 STi Seats, Carpet, Steering wheel Defi boost, Oil Press, Fuel Pressure gauges in ATI dash pod Custom painted door panels, headliner Custom door cards wrapped in blue fabric Custom Modded 6 point roll cage Corbeau harnesses Exterior: Por-15 undercarriage/ engine bay Vis racing side skirts Seibon CW carbon fiber front lip JUN S-13 replica fender flares 3M carbon fiber wrap (hood, roof, trunk 2.5RS front bumper Depo smoked headlamps, corner lights, turn signals (bumper and fender) JDM v6 front grill JDM v6 fog light covers JDM v6 tail lamps Hood latch/vertical beam mount delete Sparco hood pins Heres the car the day he bouight the car from me: ![]() ![]() Shortly after he started cleaning out the inside and getting all the interior gutted. It was tan. Its getting dropped off at my buddy's shop so it can get painted black. ![]() A week latre he had the drivetrain all dropped out: ![]() Then I spent a night and stripped all the parts out of the engine bay and removed all the dash wiring to get access to the firewall. ![]()
#2 |
Member#: 203835
BAIC
Vehicle:1993 GC Impreza and 1992 MR2 Turbo SMG T-tops |
this is going to be a beast
#3 |
Member#: 285777
Vehicle:2004 STi- |
Good to see another GC being pulled from the junk yard and given the love it needs...
Cant wait to see this together GLWYB |
#4 |
Member#: 177674
NWIC
Once that was done he wanted to touch up a couple little rust spots on the chassis so I cleaned the underside and then coated it in POR15 and some undercoating.
Before: ![]() After: ![]() The next day after it was all dry he swapped in the rearend and front assy from the Forester. ![]() ![]() Suspension and wheels in and back on the ground: ![]() In another location that same night my buddy with the engine was getting started on his rebuild. ![]() ![]() Should be finished in a week or so. While the engine and tranny are getting loved I got busy with my portion of the project: WRX Wiring Conversion WRX Dash Swap Custom Modded 6pt Roll Cage Smoothed Engine Bay Relocated Battery, Fuse Box Relocated ABS w/ Custom Brake Lines Bolt On Fender Flares w/ Herra Frush but functional stance (Like the Lego) Got Started on the Dash Swap. I was happy I got to do this one right way because the windshield needs to be swapped so I got to pull it. Tonight I will make the holes for the Blower and Heater in the Firewall and plug all the un-used holes along with removal and addign metal to start the smoothed out engine bay. Once the Dash and wiring are in for good I am going to make some nice custom trim pieces that cover the gap on the sides from the dash swap so it will be cleaner. I'll be doing it from laser cut acrylic and then having it panted to match. ![]() This project is on the fast track so stay tuned for updates. Once I run out of work and I am waiting for parts back from other places I will be back onthe ForeSTAR project to check that one out too its also going to be a good one. Johann @ Girodisc |
#5 |
Member#: 241492
NESIC
Vehicle:2006 Forester, RBP Tuned by M@ at WI! |
as long as i find them, i will always subscribe to your build threads. you are truly inspirational
#6 |
Member#: 281829
Vehicle:1999 2.5RS 02 WRX |
awesome build
#7 |
Member#: 133454
Vehicle:2004 Forester AW |
Tuned in. I want a white sedan.
#8 |
Member#: 177674
NWIC
Got some more work done last night.
Started by finishing my modifications to the cage. I'm not going to finish it for good until the interior panels are back in to make sure there is enough clearance. ![]() Removed some parts off the engine bay to get ready to smooth it out. ![]() mocked up the cover pieces to be redone in metal and welded on. However by the time I was ready to cut metal it was to late to make that much noise. ![]() Also got the ABS Pump Relocated. Had to order some tools last night for mounting the fender flares, I needed to get a new flaring tool. Also ordered up some parts, Wire, Nutzerts, so while I am waiting for those things I am going to install the heater and blower so I can get the holes cut in the wall and start smoothing everything out. Also I have to de-loom all the wiring so I can relocate the fuse box and crap. More pics soon. Johann @ Girodisc |
#9 |
Member#: 177674
NWIC
Got another update. Got a good amount of work done this weekend.
I started the day but getting the FMIC Mounted. ![]() Then I got the Header Core and Blower Motor from the WRX Fitted. Got the Fire Wall All ready to go. Plugged a couple unused holes to make it look a little cleaner. I have one more to plug but I need to finish the wiring to figure out with one I am going to keep. ![]() Next I pushed her outside and cleaned the engine bay all out so I could start prepping the bay for the metal pieces I need to make and for the All-metal filler. Used a product calls Scuff It. Its a mild abrasive past that has a cleaning detergent it. One red scuff pad and this stuff will clean your bay down super easy its really great stuff. ![]() Next it was the rear fender flares. Got my nifty nutzert tool and hardware in so I got the rear flares mounted. I need to Jonny to drop the bumper off so I can fit it and trim it for the intercooler and get the front flares on. 15mm spacers and extended studs already on the way. ![]() ![]() To finish out my weekend I got the harnesses ready for some custom work. The wire isn't here yet so I have to wait before I can cut any wire. ![]() ![]() For the wiring there are a couple things that need to be done just to get it to fit nicely in the GC with the converted dash. Next will all have to do with the wire tuck. Fuse box wiring will be reversed and extended to mount next to the battery in the trunk. All the wiring for the engine bay is going to come out of the wire wall in one spot just above the tranny so its all clean and consolidated. Wiper motor, and passenger side ABS wires are going to go out through the inside of the fender and poke into the engine bay in a unnoticeable spot. My new brake line flaring tool came in so I will be able to start fab work on the new lines for the relocated ABS pump in a couple days. More updates with the motor and tranny should be soon to follow. Johann @ Girodisc |
#10 |
Member#: 107554
Vehicle:03 03/07 yellow |
wow..
#11 |
Member#: 139996
Vehicle:2004 Subaru WRX STi PSM |
subbing. badass.
#12 |
Member#: 216597
Vehicle:2003 WRX PSM |
This build looks like amazing can't wait to see the progress!
#13 |
"Tekeli-li! Tekeli-li!"
Moderator Member#: 14145
NWIC
Vehicle:'02 WRX Cars? Stupid! |
aaand subscribed
#14 |
Member#: 147776
NWIC
Vehicle:'02 Impreza WRX '85 Toyota Corolla |
Hey, that first pic of the wiring harness look familar...
![]() Oh now I remember ![]() |
#15 |
Member#: 100651
RMIC
Vehicle:2010 STI OBP |
awesome work man, I wish I had half the knowledge and experience you have on rebuilding cars.
#16 |
Member#: 51164
International
Vehicle:Jap Jp mag 09 Ti mag 09 (cover) |
Superb work, have to say you are the king of scooby work!!
Ricey |
#17 |
Member#: 177674
NWIC
King? No. Maybe like a exuberant henchman. Or like a mad scientist. lol Id have to give the King of scooby work to say a shop owner or something. Dom, the guy that owns Ebishu and Team Orange, one of the cosworth or prodrive desginers, etc..
My shop is more like a freak show. haha So the car is going into paint on the 14th so I had the bumper and lip dropped off so I could finish the exterior work and get that all ready. I am going to finish up the engine bay this week as well while I am still waiting for the materials to do the wire tuck. While the car is at paint I will be getting both the motor and the tranny back so I can work on reversing the manifold. Its also going to give me some time to make some headway on the ForeSTAR. Once I get the GC back I'll start throwing parts at it and it should be on course to finish before the end of the month. I'll have some good updates in a couple days. Johann @ Girodisc |
#18 | |
Member#: 89594
NWIC
Vehicle:2007 STi OBP |
#19 |
Member#: 177674
NWIC
Yeah true. I have been the 1st to do a lot of things probably because I am the only one dumb enough to actually attempt them.
This build I'd say is going to be one of the only normalish builds I have done. Couple custom things but all been done before by me or others on the forum. The Forester, Legacy, Explorer, and Subreal Atom (Coming Soon) are getting all the crazy ideas I have floating around in my head. Johann @ Girodisc |
#20 |
Member#: 299693
SCIC
Vehicle:2007 STI OPB |
oooooo flares! looks good so far man!
#21 |
Member#: 250987
International
Vehicle:2003 JDM WRX STI Grey |
Niceee proyect.... Good luck
#22 |
Member#: 177674
NWIC
Update Time:
Had to take a day off work so I could get my fireplace fixed. So... I got a whole day in the shop. Started by trimming the front bumper to fit the FMIC and getting the front fender flares bolted on. ![]() Bumper is sagging in the middle so I fitted the headlights and grill so I can make a new custom bumper support. ![]() Then, I moved on to some wiring. Fitted the WRX Dash harness, heater and blower motor so I could setup the wires to do the custom tuck. ![]() I consolidated all the engine bay wiring to one point on the firewall. Wiper and Passenger ABS will poke through where the rear brake lines used to go. The brown and grey engine harness wires that connect by the fuse box will also be joining these wires so not only will it look super clean but all the wiring will be in one spot so disconnecting the engine for removal will be easier and take less time. Last a pic of the car at a distance. Its getting there. ![]() Next up will be finishing the engine bay sheet metal and body work, then a coat of gloss black paint. Next will be fab work on the custom bumper support, fitting the lip, side skirts, and rear spats. Then cutting out the fenders and quarters, and finally modification to the harness for the wire tuck and relocated fuse box. Then the car is off the paint for a couple weeks and I'll get some time to work on the ForeSTAR project and get the tranny and engine here. Once it comes back it will be a nice sprint to the finish installing everything, fitting the custom rotated turbo kit, and reversed manifold and sending it on its marry way. Next update will be Monday to show the fruits of my weekend labor. Johann @ Girodisc |
#23 |
Member#: 177674
NWIC
Got some work done over the weekend. Mainly little tedious stuff to get the car ready for paint. I did however get some pics of the bumper beam I made so the bumper would fit correctly.
![]() ![]() Tonight and tomorrow I will be getting the rear spats and side skirts fitted as well as finish cutting out and modifying the rear quarter panels Johann @ Girodisc |
#24 |
Member#: 106909
Vehicle:2002 V7 STi Prodrive Edition... Black! |
Loving this.
Your threads are always a great read Giro, well done frayz ![]() |
#25 |
Member#: 139159
NWIC
Vehicle:0207 did i hurt your feelings? grow a pair |
I claim you to be the king of this stuff man!
| Thread Tools | |
| Display Modes | |
| A Wicked GC build | Pandafactory | Member's Car Gallery | 39 | 09-09-2011 11:20 AM |
| FS : Near new 06 WRX Wagon Struts for sell (0.5+ Camber for koni GC build on sedan) | SammyRex | Suspension/Brakes/Handling | 3 | 03-12-2011 04:37 PM |
| My newest GC build thread*** NEW PICS*** | sleepysubie | Rocky Mountains Impreza Club Forum -- RMIC | 69 | 10-03-2010 02:38 PM |
| gregbolbys gc build | GregBolby | Member's Car Gallery | 23 | 11-08-2009 09:34 AM |
| My Humble GC build | A Guy with a STi | Member's Car Gallery | 78 | 03-23-2009 03:21 PM |
