#1 |
Member#: 78840
BAIC
What would the stock boost be for a ver7 ej207 w/vf30? Thought it was 14.5 psi but im boosting 19-20psi currently with no ebc or other mods. Makes me wonder if it was tuned possibly. Was thinking about using open ecu to flash back to stock. Thanks for the input!
#2 |
Member#: 298119
Vehicle:2005 Impreza WRX PSM |
Stock boost on those engines is around 18-19 psi IIRC.
Ej257's run 14.5 psi stock. |
#3 |
Member#: 78840
BAIC
Thats what I kept hearing until I've talked to a local tuner here in Tokyo and figured they knew more about it. Odd thing is I'm pretty sure my ej20g was at 14.5lbs.
#4 | |
Member#: 142447
South East
Vehicle:2002 WRX Banged Up Blue |
#5 |
Member#: 78840
BAIC
Ok ray. I thought it was weird with it.boosting 1.6bar 19-20lbs and its not modded more than a catback currently.
#6 |
Member#: 1581
Vehicle:MY00 RS/STi7 MY01 RS Both Silverthorne |
My ej207 peaks at 18-19 normally. Once in a while it hits 21ish. It it catless and has full exhaust including a header. I've been running it like that for 8 years with no issues.
#7 |
Member#: 51480
International
Vehicle:1984 AM5, 1994 BC4, 2010 BR5 |
Factory boost for V5/6 EJ207 is 800 mmHg = 1.1 bar = 15.5 psi.
#8 | |
Member#: 78840
BAIC
#9 |
Member#: 46135
Vehicle:02 WRX Powered by Sti V9 Spec C |
Stock is 18.56 PSI in my V9 JDM EJ207.
The documentation you're looking for is found in the ROM image that people pull from Stock JDM ECU. The boost target is 18.56, I've logged 18.7 and the boost cut is over 22.4 PSI I got 3 other images from 3 different sources and the tables were all identical. The S cars have an even higher fuel cut, in the 23 PSi range. Take a look at the Ej207 owners forum, there is a lot of info there, most EJ207 are after 2002. I don't know what you are doing (You're running this engine in Tokyo/Japan or in BAIC USA), but if you're running a JDM EJ207 with mods and did not tune anything, you should run it with 100 Octane unleaded gasoline, not with 93 and certainly not with 91. If you're looking to reflash it back to stock JDM spec, that spec is for 100 Octane gasoline that these cars are needing to run in Japan. Prior to me getting my ECU reflashed, when I was still running it stock, waiting for the reflash, I fuelled cam 2 100 unleaded, as a temporary safety measure. If you're running an EUdm EJ207, this is different. Another important difference that one needs to understand is that there are quite many differences between the hardware and stock tuning of a JDM EJ207 and EUdm EJ 207. The EUdm does not run wthe boost that the JDM runs stock. This is why you're getting two apparently contradictory answers. There are differences in heads, coil packs, spark plugs, etctec. Last edited by Vlad; 10-26-2011 at 12:33 PM. |
#10 |
Member#: 51480
International
I misread in the first post for which EJ207 version the request was... My statement of boost levels is for V5/6 engines, not for the V7.
And V5/6 EJ207 cannot be compared with later versions. The short blocks are completely different. V7 and up have semi-closed deck blocks with MUCH tougher connecting rods, so do not try to run V7 and up boost levels on V5/6 engines, they will throw a rod! |
#11 | |
Member#: 298119
Where I'm from, we have both JDM and EUDM and ADM cars :| I've seen two stock JDM bugeye STi's run at 18-19 psi boost. Their redline was around 8200 or so rpm? I've seen ONE EUDM bugeye STi run at closer to 15 psi I think, but that car also redlines at "only" 7500 rpm. What's up with that? As far as I recall though, both cars used similar spark plugs! Well, it may be possible that the OE heat ranges were different, but I'm not sure if the owners had changed the plugs to those different ranges, or that was in stock trim. |
#12 |
Member#: 46135
The 207 may have started in 2001 or late 2000. I've read somewhere that late model GC8 had EJ207 in a very late Version 6.
As long as we're talking new body, beginning with 2001, the JDM had VF30 in the Sti and VF34 in the Sti Spec C. The AUS had something else to my knowledge, probably the EU as well. This becomes more true with newer models. With mid year 2003, the JDM become twinscroll and the EUDM stay single scroll. Differences start to include cams and such. Turbos are twinscroll, VF 36, 37. The S cars have the very special VF42. With 2005 the EUDM and AUS become EJ257, while the JDM stay EJ207. A while ago, one of the board memebers analyzed the part numbers for the components. The JDM V7 were different than any otherones and just for '02, the cams for Spec C are said to have been very radical, and that later they reverted to a more "normal design" that then carried to all the V8+ twinscrolls. The V8+ Twinscroll Spec C are said to have different cams as well. The heads are a big part of the reason, for sure.The redline is quite different, easily visible when you look on ebay at misc clusters. The JDM clearly show redline at 8000, while the rest at 7200. The extra 200RPM are said to be only a visual reading or an innertia thing, because I've personally seen that no Subaru (not even the mighty GRB Spec C EJ207) has in the ROM the fuel cut over 8000. In other words, let's say you're logging a run to the limitator. You hit 8000, the limitator kicks in and cuts the fuel. The engine will gain another 200rpm due to accelerative innertia, before it starts to slow down. Your log might show 8200 therefore. I have the owner's manuals of both the JDM and EUDM. Their reccomended spark plugs are 1 range different. The coil packs have a different part number and are revised for the different range plugs. Doing plugs without doing coil packs doe not give you the same effect. The reasons for the different RPM ranges can be many: Legal liabillity, Local laws about timing belt replacement interval (in Japan they are allowed to tell owners to replace every 50 K miles, while I believe that in US that is not the case). The timing belt is a different part number, possibly with less stretch, but with more frequent replacements. Don't get me wrong, people have run and are running JDM EJ207 with USDM timing belts and the engine runs fine. But doing stuff by-the-book, you would get a different timing belt. A big reason are the different heads. The spec C cars got an oil radiator and no cooler. The S cars are even more special and differ in the ROM as well. The body/chassis is different and the weight is different. The ratios in the gearbox from the close ratio JDM 6 speed may not have made it to export markets. Last edited by Vlad; 10-27-2011 at 10:06 AM. |
#13 |
Member#: 1581
I know the UKDM STi ver 7 ran a VF35 turbo and the small port heads.
#14 |
Member#: 298119
Vlad - you sir, are a Subaru-God. Excellent info!
So can we run the JDM EJ207 coil packs with the colder plugs for a better effect? |
#15 |
Member#: 46135
Thanks
![]() If you've looked at Romraider, it had a time of development and then stagnation. hardly anything new is coming out. One of the very last things to come out was the Dwell angle table. To do everything right, you would need: -Plugs -Coil packs -Access to the dwell angle table for your ECU The way things worked with Romraider, things became available first for certain ECu's , then for everybody. I think they stopped at "for some". Then you copy the JDM OEM ECU image, open the dwell table, copy the whole thing and paste it into your ECU. There might be more implications than this, a tuner would get into further detail about additional changes needing to be made, but my feeling is that at this point you'd be 99% there with the spark plugs. Last edited by Vlad; 10-27-2011 at 10:47 AM. |
#16 | |
Member#: 204358
SCIC
Vehicle:01 2.5RS W/ EJ257 Black |
I have never heard about this. |
#17 |
Member#: 46135
The talk about versions is just fan club talk, so we can understand Sti generations easier. Subaru has stopped calling them versions since version 6.
As far as Subaru is concerned, a V7 is a GD revision A. All these were revisions and the GD body has revisions A through F. People have agreed that GDA is V7, GDB-D are V8 and GDE-F are V9. Now, the current bodystyle, GR which may be upto revision D already is said in "Sti talk" to be V10, so far and yes, it still has an EJ207, quite improved too. Last edited by Vlad; 10-31-2011 at 09:43 AM. |
#18 | |
Member#: 204358
SCIC
In any event, google is your friend, simply type in your shortblock and heads and you will get your answers. |
#19 |
Member#: 46135
Yeh, just go to Subaru's Japanese site and look at the spec C, the EJ207 is clearly shown in the features, it's still around. These days with dual AVCS and more closed deck than the EJ257.
The regular Sti doesn't have it though. |
#20 |
Member#: 88618
SCIC
Vehicle:1994 Legacy "The Silver Slug" |
Guys 2005 my is considered ver.9
#21 |
Member#: 78840
BAIC
Im in tokyo... On base gas is midgrade and thats all we have. Off base is significantly more expensive for hi-octane (¥200/liter)
#22 | |
Member#: 142447
South East
In what way? I thought the only changes were the addition of smog devices, and no other additions to increase power or power band were added? |
#23 |
Member#: 142447
South East
#24 |
Member#: 46135
Off base and on base might be coded differently. You surely understand the differences between MON, RON and AKI.
Wikipedia has definitions, I don't have time to go there now. If you want an USDM tune for 91, then you may be able to use a mid-grade gasoline. Other than that, talk to the local tuners and ask them what they tank.. |
#25 | |
Member#: 78840
BAIC
75-78(78 on a good day) at least my cola went up and i dont buy **** out in town much other than a train ticket
![]() Quote:
| Thread Tools | |
| Display Modes | |
| FS : JDM STi Ver 7 EJ207 Intake Manifold/TGV deletes | Ryan23 | Engine/Power/Exhaust | 18 | 11-18-2010 05:08 PM |
| FS : HOU: STI ver 7 EJ207 and other WRX parts! | Bolster | TXIC Private Classifieds | 21 | 11-10-2010 10:35 PM |
| FS : Ver 7 ej207 ~30,000mi runs great | Lexington | MWSOC Private Classifieds | 49 | 10-22-2010 01:02 PM |
| FS NYC: STi Ver. 7 EJ207 and 8 sets of wheels/tires + tons more! | garface | Tri-State Area Private Classifieds | 26 | 11-11-2009 12:17 PM |
| ver. 7 ej207 help | EJ25I | Factory 2.0L Turbo Powertrain | 12 | 03-18-2007 10:48 PM |
