Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 11-27-2012, 08:44 PM   #76
Smurftastic
Member#: 243697
02 | BLOD Founding
Member | TopScoob 031
Oil temp gauge in, interior coming together, and halfway through a bottle of BG 44K - things are good
Smurftastic is offline   Reply With Quote
Old 12-01-2012, 09:59 PM   #77
Smurftastic
Member#: 243697
02 | BLOD Founding
Merp
Old 12-02-2012, 02:42 AM   #78
guru_method
Member#: 189118
Chapter/Region: PRSIC
2003 S.Yellow WRX
2008 BMW 335i
a bugeye is a terrible thing to waste...
guru_method is offline   Reply With Quote
Old 12-08-2012, 01:29 AM   #79
Smurftastic
Member#: 243697
02 | BLOD Founding
Old 12-17-2012, 11:25 PM   #80
Smurftastic
Member#: 243697
02 | BLOD Founding
..... changes are coming... work is in progress
Old 12-19-2012, 03:32 PM   #81
Smurftastic
Member#: 243697
02 | BLOD Founding
For a while now I've been working on the interior.. a few aesthetic things (dyed the headliner black, thought about suede but too much or a risk of sagging) and specific gauges for monitoring. A few unique touches here and there. Finally got around to installing the shifter trim, here are some of the overall results
Old 12-20-2012, 07:02 PM   #82
lino129
Member#: 251820
Rally Blue
What did you use on your headliner smurf? I tried to do mine with either Dupicolor or simply spray, I can't recall. But I didn't like it, not dark enough, so I peeled it off and tried to do suede, which is NOT a 1 person job. So that came off. And I used just some general fabric with more give from the local craft store. But I would almost rather get a new headliner and start over and just use some GOOD dye...
lino129 is offline   Reply With Quote
Old 12-20-2012, 08:32 PM   #83
Smurftastic
Member#: 243697
02 | BLOD Founding
I used duplicolor vinyl dye... at least three or four coats to make sure it was a nice solid black
Old 12-20-2012, 09:13 PM   #84
blessthekellen
Member#: 273859
MY98
WRX
Looking good smurf. Its the small details I love most.
Question, your shift boot, is it being held up by the sparco shift knob?
or is it just sitting closely under it (no collar on the shift knob)
blessthekellen is offline   Reply With Quote
Old 12-20-2012, 09:21 PM   #85
Smurftastic
Member#: 243697
02 | BLOD Founding
The bottom of the shift knob hangs out and slightly over the collar of the shift boot... so they almost look like one contiguous piece. You know, sort of like Canada and the US :-D
Old 12-22-2012, 11:35 PM   #86
lino129
Member#: 251820
Rally Blue
Alright man thanks.
Also, your car is sick.
Also, also, why prosport? I've read they are terribly spotty. You must not be having any problems with them though?
Old 12-23-2012, 01:47 AM   #87
Smurftastic
Member#: 243697
02 | BLOD Founding
I did a good amount of research on WHY people have spotty issues with Prosport, and the results showed that the problem was more with the sender and sender install location than the actual gauge itself. I took a lot of effort to install the senders in safe locations and have not had a single issue yet.
Not that I wouldn't mind DEFI gauges, but I'm on a married guy's budget
Old 12-23-2012, 10:52 AM   #88
ToddMcF2002
Member#: 135007
2014 STi Hatch
Crystal Black Silica
Looking sweet! All I need to do is install my rear coils but I've been laaaazy. Its cold in the garage.
ToddMcF2002 is offline   Reply With Quote
Old 12-23-2012, 01:36 PM   #89
Smurftastic
Member#: 243697
02 | BLOD Founding
Get a space heater! No excuses! Lol
Old 01-19-2013, 12:20 AM   #90
Smurftastic
Member#: 243697
02 | BLOD Founding
I just spent four or five hours extending the entire engine wiring harness to finally have all wiring out if the way for new sheet metal in the engine bay --- THAT much closer to finishing this shave/tuck job. Sheet metal 75% in... hopefully finish up over the weekend.
I have now had this build a little more than two years.. so in retrospect, I have put up some before/after photos:
Old 01-19-2013, 12:59 AM   #91
SoonerOrLater
Member#: 97924
2007 WRX STi
Love the whole car man. Really jealous of the roof vent.
SoonerOrLater is offline   Reply With Quote
Old 01-19-2013, 01:09 AM   #92
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
I can see the back of my head and my girlfriends face in one of those pics.
Now you need to get either an odyssey pc680 and put it under your seat or one of these new fangled lithium iron batteries that are super small.
The tuck is coming along quite nicely
EvileyeZ88 is offline   Reply With Quote
Old 01-19-2013, 01:16 AM   #93
Smurftastic
Member#: 243697
02 | BLOD Founding
Oh, that is a slightly older pic up there -- this is now my trunk
I don't plan on putting any new engine bay pics up until I finish the new paint job. Right now, the driver's side has no battery, fuse box, or reservoir
Old 01-19-2013, 02:56 AM   #94
SubyStud555
Member#: 185048
07 Legacy Spec B
06 SGM Sti
Seek and you shall find! Nice build, what made you decide to go back to a top mount?
SubyStud555 is offline   Reply With Quote
Old 01-19-2013, 03:07 AM   #95
Smurftastic
Member#: 243697
02 | BLOD Founding
Running 16 PSI on a TD04 really didn't call for any need of a FMIC, plus the car wasn't tuned for it. Plus, all the distance required for the air to travel through the FMIC pipes caused an excess turbo lag that I really didn't enjoy... I think when I switched to the V7 TMIC, the turbo lag decreased by about 300 RPM!
Old 01-20-2013, 07:48 PM   #96
Smurftastic
Member#: 243697
02 | BLOD Founding
Productive day in the garage... sheet metal complete, smoothing complete. Next step is sanding and then in for primer/paint. Still deciding on the color but leaning towards a glossy stockish blue.
Old 02-05-2013, 08:17 PM   #97
Smurftastic
Member#: 243697
02 | BLOD Founding
The wait is finally over! I completed the engine bay project this weekend... after many months relocating everything except for A/C, P/S, and ABS, because hey, this is still a daily driver! Put in new sheet metal and repainted everything. I still need to buff and wax the new paint, but happy to have completed this project a little bit at a time over the past many months
I still need to clean up a few more things, buff/wax the new paint, and fix a few tuck issues, but this definitely feels like a good milestone.
Old 02-05-2013, 11:19 PM   #98
lilblue619
Member#: 288292
2004 sti
wrb. the blue one.
You got my top scoob vote.
lilblue619 is offline   Reply With Quote
Old 02-05-2013, 11:33 PM   #99
Smurftastic
Member#: 243697
02 | BLOD Founding
Hey, thanks!
Old 02-09-2013, 07:23 PM   #100
Smurftastic
Member#: 243697
02 | BLOD Founding
A few more pics my friend Jerry took for the TopScoob competition... he did a great job!
It's about damned time someone made a musical I would actually go see. UberWilhelm Off-Topic 6 07-03-2010 12:28 AM
MY20G Bugeye Build Thread white02_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 02-04-2010 09:02 PM
It's about damn time I got a dog! Nick Off-Topic 137 02-07-2008 04:52 PM
It's about damn time....Remy is getting a new car.. Remy E. LeBeau Off-Topic 43 04-02-2004 04:27 PM
It's about damn time i did it... Hassassin Proven Power Bragging 35 11-19-2003 02:32 PM
