Old 08-06-2002, 07:27 PM   #1
zacek
Member#: 19467
04 WRX STi
WR Blue - original owner
Default Reducing cluking noise in TEINs
Would raising the rear of the car reduce the clunking noise off the rear type FLEX coilovers? Also, once we got all the measurements as recommended by TEIN's reference, what is the best way to lower and higher up the car?
- Use the spring perch?
or
- Move the lower bracket up or down
zacek is offline   Reply With Quote
Old 08-06-2002, 08:09 PM   #2
Tuning Factory Inc.
Vendor
Member#: 3600
Move lower bracket to adjust height. One trick I use to reduce noise a bit is to use some rubber sheeting between the strut mount and the body of the car. Doesn't solve it but helps. To be honest the clunking doesn't bother me at all (although I RARELY notice it on my RA's).
Tuning Factory Inc. is offline   Reply With Quote
Old 08-07-2002, 03:03 PM   #3
zacek
Member#: 19467
04 WRX STi
I have raised the rear of my WRX by about 3/4" by using the spring perch. I figured that small amount should not bring the damper out of travel spec. Basically here are my new settings. Using the Type FLEX reference measurements as per TEINs manual. The reference value for "C" is 163mm. I moved the perch up making the value of "C" change to 185mm. For reference I have the stock wheels. After this change, the clunking noise was noticeable reduced. During street cruising it still shows up now and then spewcially on bumpy and roads with above average imperfections. However on the freeway the clunking pretty much dissapeared. When going over a big freeway bump I can still hear the clunk howerver the sound is pretty much absorbed by the simulatneous damper squeak, so you can hardly notice it. Definitely it does not annoyme anymore. I will be adding the rubber as suggested by God, that should reduce the noise even more. I think after puting that rubber sheet on all 4 struts mounts I should be very pleased with the setup. I now have a 2 finger gap in the rear and 1 and a half finger gap in the front. (stock wheels). Once I put my 18" wheels that gap should be gone.
Wagon cargo mat reduce cabin noise? badkid Car Audio, Video & Security 3 05-22-2004 06:57 PM
Reducing Road Noise TNT Newbies & FAQs 10 03-03-2004 03:23 PM
Does the wagon spoiler reduce wind noise? clyde General Community 13 01-12-2004 06:12 PM
Reducing Exhaust Noise in Cabin topcover Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-04-2002 01:27 PM
help! need to reduce exhaust noise BlueWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 09-04-2002 09:15 AM
