Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Suspension/Brakes/Handling
Closed Thread
Old 10-28-2011, 12:54 PM   #1
Performance Race Solutions
Vendor Sales Rating: (2)
Member#: 248291
2005 Your Dream Car
Default AST Coilovers - Whiteline - DBA - Girodisc - H&R - Eibach - BC Racing + Much More~
Performance Race Solutions Has got your covered when it comes to suspension goodies. Not only can we sell you quality parts, but we can give you advice on setting up your suspension so that your car will handle like a giant go-kart. With years of real world driving experience and countless hours of track time, we know what works.
AST Coilovers
The 4150 Series shocks introduce high performance monotube technology at prices competitive with twin tube insert coilover kits. They include purpose built strut and shock bodies, shortened from stock lengths. All kits come with anodized aluminum adjusters that stay on the shock; no need to keep your pockets full of tools to make quick adjustments.
Benefits include:
Monotube design - gives the biggest piston sizes available
Floating piston design with high pressure nitrogen means no cavitation around the piston
Adjuster knobs permanently mounted on the dampers – no fumbling for knobs
Fully threaded strut bodies allow maximum tire width without fender rolling or larger spacers
Rebuildable by AST-USA – get the valving you want, when you want it.
AST-USA provides a 12 month warranty on the 4150 Series shocks and dampers.
Rebound Adjustable ("Singles")
22mm diameter shaft struts, non-inverted
Steel cylinder body shocks, non-inverted
Rubber bushings for "eye" shock mounts
Optional spherical upper shock mount assemblies
Non-synthetic hydraulic fluid
BC Racing Coilovers
BR model is perfect for street driving and occasional road course duty. With easily accessible adjustment knobs for fine tuning your compression/rebound and separately adjustable ride height, having a performance coilover system couldn’t be any easier. You choose how low or high you want your vehicle, no preset ride height here, and our patented concave lower locking ring keeps it locked in. All of our systems come with pillowball mounts to provide the most feedback possible from your suspension and to sharpen your steering response. BC’s available front and rear camber plates also allow you to get the perfect alignment setup without compromise. All this while providing a strong, attractive looking coilover system.
-Mono-tube shock design
-30 levels of damping force adjustment, adjust compression/rebound
-Pillowball mounts and adjustable camber plates included (where applicable)
- Adjustable rear camber plates available
- Separate full length height adjustable
- One year warranty
- Rebuildable
H&R Street Coilovers
H&R Street Performance coilovers feature an innovative mono-tube gas shock construction, the perfect suspension solution for 02-07 Subaru WRX & STI owners who can appreciate precise handling and superb ride comfort. Using premium quality materials, H&R engineers fine-tune each Street Performance kit with progressive rate springs to ensure better handling and a premium ride. H&R Street Performance coilovers feature a fully threaded custom shocks, allowing you to modify vehicle height using easy to adjust spring seats. Adjustable height control allows you to dial in your 02-07 Subaru WRX & STI to look and handle according to your own personal style. All H&R Street Performance coilovers are fully designed and tested in-house at the H&R headquarters in Germany.
Specs:
02-03 WRX - Front Lowering Adjustment: 1.2 - 2.5, Rear Lowering Adjustment: 1.0 - 2.0
04-07 WRX/04 STI - Front Lowering Adjustment: 1.2 - 2.3, Rear Lowering Adjustment: 1.0 - 1.9
05-07 STI - Front Lowering Adjustment: 1.2 - 2.3, Rear Lowering Adjustment: 1.0 - 1.9
Street Performance coilovers feature adjustable ride height only.
Whiteline Adjustable 4 Piece Control Arm and Lateral Link Kits
Whiteline's full Adjustable Rear Lateral Links Kit includes all four adjustable lateral links (two control arms and two front control arms) pre-fitted with polyurethane bushings for improved suspension compliance. These Whiteline lateral links were specifically designed to provide you with the ability to adjust camber, toe and track width configurations of the rear suspension with extreme precision. The high-grade steel and top-quality polyurethane Whiteline uses results in a greater range of alignment settings and more precise adjustment of the toe, camber and track. You will also benefit from the more direct connection between your 02-07 WRX / 04-07 STI's body and rear suspension delivering more predictable dynamic behavior.
Girodisc 2pc Slotted Rotors
The Girodisc system is a direct replacement for the OE disc. No modifications are necessary. The disc will bolt directly to the car and work with OE calipers perfectly. By upgrading your brakes with lightweight high performance replacements as opposed to a big brake kit, your factory bias is maintained as well as your ABS efficiency. The Girodisc front rotors are approx 16.5lbs vs. 20.5lbs for the stock units. This reduction in rotational and unsprung weight allows for quicker acceleration and suspension response.
The central hat section of the disc is made from 6061-T6 aircraft specification aluminum. The disc is made from cast iron to the same specification and material as used by professional racing organizations. It is a curved vane design, developed in racing to act as a centrifugal pump to force cooling air through the disc.
The rotor and hat have a floating mount system, which utilizes 10 high strength alloy steel drive pins, manufactured by Girodisc to our own specifications and cadmium plated for a long lasting corrosion resistance. These pins take the load from braking actions while maintaining the axial and radial float between the hat and disc. In order to keep the rotors from making noise when cold, the pins are mounted with anti-noise spring washers on the rotor side which allow the rotor to grow with heat expansion but eliminate the rattle and noise associated with floating rotors. This float also allows the rotor to self center between the pads.
Once the Girodisc system is in place, simply replace the cast iron rotor when needed.
When used with performance pads and hi-temp fluid, you have what amounts to a truly amazing solution to overheating or warping rotors.
Girodisc Bailout Front Rotors
Due to the pressing times many of us do not have the funds to spend a lot of money on our cars. We understand that brakes are very important to your safety and we want to be able to offer brake options for every budget so we have released what we call our Bailout Special. It is comprised of our blank, un-plated Girodisc rotors which come from the same castings we use for our premium slotted rotors so you know they are of the highest quality. Please note that this is for a set of front and rear rotors only.
Eibach Lowering Springs
Eibach produces some of the highest quality springs in the world. They can be found everywhere from high performance street cars to full race F1 cars. Eibach springs are built from the ground up - starting with full research and development for every application to determine the best balance between performance and ride quality. Eibach springs are on average 2.75 pounds lighter than the competition. This reduction of unsprung mass is equivalent to removing 50 pounds from your car! All Eibach springs come with an unbeatable Million Mile Warranty.
The Eibach Pro-Kit will greatly improve handling with a moderate drop that is perfect for a daily driven car. The reduced wheel gap will make your car look the way it should have come from the factory, and the lower center of gravity dramatically helps in the corners. The Pro-Kit features a progressive spring design for the ultimate mix of comfort and performance.
GTSPEC Lateral Links
GTSPEC's Lateral Link Arms are designed to lock out the existing toe angle adjuster and replace it with a stiffer adjustable steel arm with lock washers. The factory adjuster is prone to slippage under load and the soft rubber bushings are designed around reducing noise and vibration rather than providing maximum performance. The GTSPEC arms are single point adjustable to reduce the chances of them coming loose during performance driving. GTSPEC's adjustable arms with their polyurethane bushings will aid in more consistent toe alignment during braking, cornering, and hard acceleration. These are best used in conjunction with the GTSPEC camber arms.
Perrin Super Steer Kit 08+ WRX&STi
The Perrin Super Steer system will add a go-cart type feel to your Subaru in only 3 hours of work! The Super Steer reduces the amount steering input needed to steer through corners making your Subaru feel crisp and responsive. The Super Steer bodies are the key to what makes them work. The secret is how they change the steering racks leverage on your front hubs. Made from CNC'ed 6061 aluminum, these pieces are overbuilt to ensure a lifetime of use.
The Super Steer System includes new steering rack tie rod ends. Instead of us using heavy OEM type ends, we chose lighter and stronger spherical rod ends, and billet aluminum rod end adapters. For lowered STI's the rod ends double as a ball joint extender allowing you to retain correct steering geometry, even at extreme ride heights. All rod ends come pre adjusted to OEM spec so you can drive safely to your alignment shop.
The Perrin Super Steer increases steering articulation and therefore needs new stops to limit wheel travel. Each kit includes two collars which create new stops for the steering rack, eliminating the possibility of tire contact with the body while every stop is securely locked in place with 4 bolts eliminating any possibility of failure.
__________________
[COLOR=Black]
[/COLOR]
[COLOR=DimGray]407.878.5870
[COLOR=DimGray]Check us out on[/COLOR]
[/COLOR][COLOR=DimGray]
[/COLOR]
Performance Race Solutions is offline
Old 10-28-2011, 02:54 PM   #2
weboyd87
Member Sales Rating: (10)
Member#: 256451
2007 WRX Wagon
Do you carry Eibach springs for a 07 wagon? If so price shipped to 17357.
Thank you
weboyd87 is offline
Old 10-28-2011, 03:27 PM   #3
Member#: 248291
2005 Your Dream Car
Thank you
PM Sent!
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 10-29-2011, 01:34 PM   #4
Member#: 248291
2005 Your Dream Car
Bump for a great weekend!
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 10-30-2011, 01:40 PM   #5
njwill33
Member#: 283691
How much for the eibach springs for an '11 imprrza shipped 08527
njwill33 is offline
Old 10-31-2011, 01:23 AM   #6
The Big Kahoona
Member#: 294763
2011 STI
I'll take you up on that advice offer.
I'm looking at setting my '11 STI for lots of track time. Street comfort and whatnot does not matter to me ( so no BC stuff!)
Need advice on suspension bits. So far I've only got sways and endlinks on
The Big Kahoona is offline
Old 10-31-2011, 11:02 AM   #7
Member#: 248291
2005 Your Dream Car
PM's Sent! Let me know if you have any questions!
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 10-31-2011, 03:16 PM   #8
Member#: 248291
2005 Your Dream Car
Bump for some "Scary" deals!
...ok that was cheezy, but im in the holiday spirit lol
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 11-03-2011, 02:28 PM   #9
Member#: 248291
2005 Your Dream Car
H&R Sway Bar's!
Both professional and amateur racers agree, upgrading the sway bars on your Subaru may be the single most effective suspension modification. H&R Sport Sway Bars are crafted from the highest tensile strength steel available, a proprietary (hf) 50CrV4 steel alloy. This design guarantees a smooth transitional sway bar function, decreasing feedback response time and increasing stiffness. H&R Sport Sway Bars will reduce body roll while improving lateral stability and cornering grip. Adhering to the same manufacturing philosophy as H&R’s world-renowned springs, each H&R Sport Sway Bar is cold-formed and heat-treated. Before testing, the H&R shot-peen process ensures durability and dimensional accuracy. In addition, each H&R sway bar will endure a series of rigorous quality control tests, ensuring that all finished products meet the high standard you expect from H&R. All H&R Sway bars include their exclusive urethane/Teflon grease-less composite sway bar bushings.
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 11-04-2011, 02:30 PM   #10
Member#: 248291
2005 Your Dream Car
Bump For the Weekend fast approaching!
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 11-08-2011, 04:40 PM   #11
Member#: 248291
2005 Your Dream Car
PM's replied to. keep em coming!
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 11-14-2011, 01:00 PM   #12
Member#: 248291
2005 Your Dream Car
All weekend PM's replied to! Ready to get some parts out the door
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 11-15-2011, 02:37 PM   #13
Member#: 248291
2005 Your Dream Car
Whiteline Bump Steer Kit
Lowering the ride height of your Suabru can be a very effective modification, enhancing handling by creating a lower vehicle center of gravity and giving the car an aggressive look by minimizing wheel gap. Unfortunately, once the stock ride height has been altered, the front end roll-center is modified as well, which can actually make your car handle worse than stock when carving out those deep corners. The suspension gurus at Whiteline have developed the perfect cure to this ailment, the Whiteline roll-center kit. The Whiteline roll-center kit, also called the ROCK kit, realigns the suspension geometry of your lowered Subaru, raising the front roll-center and creating a substantial increase in front roll resistance and a significant reduction in suspension compression on the outside of the front wheels during cornering. The Whiteline ROCK kit will improve front end weight distribution, maintain a better camber angle and ultimately improve front end grip. You will also experience a reduction in understeer as well as improved steering feel, precision and overall vehicle stability. Another negative side effect of lowering your car can be the induction of bump-steer. Bump-steer is the concept of bumps or imperfections in the road causing a car to steer off-track on its own, without any driver input. This is described by many Subaru drivers as needing constant direction correction when steering over a bump. This annoying and sometimes even dangerous effect is the result of poor suspension geometry when a vehicle is lowered below factory specs. The Whiteline bump-steer correction kit extends the factory front end tie-rods to keep the axles at nearly the same distance from the frame at the steering box, eliminating axle tilt and subsequently curing bump-steer. Whiteline includes their bump-steer kit in every Subaru roll-center kit for the perfect total suspension solution. Your Subaru never felt this good!
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 11-16-2011, 02:19 PM   #14
Member#: 248291
2005 Your Dream Car
the middle of the week is here. Get those orders in before the weekend!
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 11-17-2011, 11:39 AM   #15
Member#: 248291
2005 Your Dream Car
Another set of AST's out the door! Thanks for the orders!!
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 11-18-2011, 10:36 AM   #16
Member#: 248291
2005 Your Dream Car
Last day before the weekend! Keep those PM's Coming and let me know what goodies i can get sent to you
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 11-22-2011, 04:20 PM   #17
Member#: 248291
2005 Your Dream Car
PM'd replied!
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 11-28-2011, 02:30 PM   #18
Member#: 248291
2005 Your Dream Car
Back from stuffing our faces! Hope everyone had a good Thanksgiving!
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 11-30-2011, 10:15 AM   #19
Member#: 248291
2005 Your Dream Car
PM's Replied. Thank you for your business!
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 12-05-2011, 11:45 AM   #20
Member#: 248291
2005 Your Dream Car
Weekend is over, back to the grind
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 12-08-2011, 11:44 AM   #21
Member#: 248291
2005 Your Dream Car
GTSPEC Rear Control Arms 08+ WRX/STi
The GTSPEC rear control arms are a must for your 08-10 Subaru Subaru that is lowered on performance springs or coilovers. When lowered, the rear suspension geometry of your Subaru is disturbed, causing the rear tires in ride on the inside edge with a condition commonly known as negative camber. Excessive negative camber can result in poor handling and tire wear on your Subaru. The GTSPEC rear control arm replace the stock control arms and allow you to dial in custom rear camber settings according your driving style. GTSPEC rear camber arms also incorporate a +30mm bend to compensate for the added stress that the control arms endure when lowering the body of your vehicle, a feature unmatched by any similar products on the market. The GTSPEC rear control arms are the first Subaru arms on the market that are built with forged 7075 aluminum end joints for unprecedented strength and durability.
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 12-15-2011, 10:35 AM   #22
Member#: 248291
2005 Your Dream Car
The weeks drawing to a close, so keep those PM's coming!
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 12-20-2011, 11:46 AM   #23
Member#: 248291
2005 Your Dream Car
Who's ready for the holidays?!?!
Let us know what holiday cheer we can bring you in the form of Gofast Parts
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 12-22-2011, 05:41 PM   #24
Member#: 248291
2005 Your Dream Car
Enjoy the Holidays! We will be back in action after the weekend
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Old 01-13-2012, 01:07 PM   #25
Member#: 248291
2005 Your Dream Car
Get your tax checks ready for some new suspension through PRS
__________________
[COLOR=Black]
[/COLOR]
[/COLOR]
Closed Thread
