Old 10-30-2011, 01:37 AM   #1
Strider327
Member#: 131280
2004 Impreza WRX
Default o2 Sensors for an 04 wrx?
Which part number is for which? I am looking at the Bosch website and they give two different part numbers. However when I look it up, it doesn't look like it will fit. I have a 2004 4eat wrx. I got a code for P1039 today.
13538 Oxygen Sensor OE Type - Downstream Automatic Transmission
15537 Oxygen Sensor OE Type - Upstream Automatic Transmission
I need the one for the downpipe. I would assume its the downstream one, however when I saw it on Amazon the head of the sensor doesn't seem correct.
Strider327 is offline   Reply With Quote
Old 10-30-2011, 12:49 PM   #2
Strider327
Member#: 131280
2004 Impreza WRX
bump! Anybody?
Old 10-30-2011, 01:55 PM   #3
Dat8687
Member#: 243261
2004 WRX
Java black pearl
Is that an 02 code? What does it say after the code is read..
Dat8687 is offline   Reply With Quote
Old 10-30-2011, 02:03 PM   #4
Pio
Member#: 298480
2004 Wrx Sti
Is the Bosch an oem replacement? I only ask because I have an 04 sti and mine was a Denzo. I replaced mine a couple months ago, and when I was looking for a replacement found a denzo for a lot cheaper.
Pio is offline   Reply With Quote
Old 10-30-2011, 02:06 PM   #5
Pio
Member#: 298480
2004 Wrx Sti
Your best bet is to just pop it out and look at it, (if you haven't already) then compare to the pictures online. But like I said you may want to look at the Denzo. Hope it helped.
Old 10-30-2011, 02:57 PM   #6
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
Spenk is offline   Reply With Quote
Old 10-30-2011, 03:23 PM   #7
aaron0815
Member#: 284922
2002 SC430
Red
Thanks that helped me too
aaron0815 is offline   Reply With Quote
Old 10-30-2011, 04:40 PM   #8
Strider327
Member#: 131280
2004 Impreza WRX
So this sensor is for the rear (downpipe) correct? Does anyone know the one for the manifold? The front one?
Old 10-30-2011, 06:02 PM   #9
Dat8687
Member#: 243261
2004 WRX
Java black pearl
Possible your cat is clogged my girls audi threw the rear 02 code when it was clogged
Old 10-30-2011, 06:56 PM   #10
Strider327
Member#: 131280
2004 Impreza WRX
I have no cats.
Old 10-31-2011, 09:06 AM   #11
Spenk
Member#: 7164
2000 Miata LS
Bookmark this for future reference when P/N hunting:
http://www.rockauto.com/catalog/raframecatalog.php
Amazon has the OE upstream sensor for $105:
Amazon.com: Denso 234-9011 Oxygen Sensor (Air and Fuel Ratio Sensor): AutomotiveAmazon.com: Denso 234-9011 Oxygen Sensor (Air and Fuel Ratio Sensor): Automotive
Old 10-31-2011, 10:05 AM   #12
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
As Spenk has said, skip the bosch. It will only give your ecu false readings under wot. (leaner)
Subian is offline   Reply With Quote
Old 10-31-2011, 11:00 AM   #13
Strider327
Member#: 131280
2004 Impreza WRX
I already ordered the Denso one. Just wanted to know which one I was buying (rear or front). I'll be replacing both of them, since I've never done so. Thanks guys.
WTB: o2 sensor for a 04 wrx Ntercooled Private 'Wanted' Classifieds 2 08-11-2008 09:51 AM
Help I need an o2 sensor for a 2004 wrx (the downpipe sensor) socomcaptain05 Private 'Wanted' Classifieds 0 05-10-2008 02:12 AM
O2 sensor for an 04 STI 2000GTB Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 09-23-2007 10:26 PM
WTB: Front o2 Sensor for a 04 STI slvr04sti Private 'Wanted' Classifieds 6 01-09-2007 12:32 PM
anyone have a rear o2 sensor for an 02 wrx? shu_chen4 South East Region Forum 0 09-16-2006 11:55 AM
