Old 10-30-2011, 09:42 AM   #1
aTriz
Member#: 95202
2011 WRX
PhatBotti e85 Tuned
Default 2011 WRX stage 2 Log check please
Here is a 3rd gear pull,
Mods: Invidia catless DP, walbro 255lph, stg 2 protuned.
https://docs.google.com/spreadsheet/...HdoSzlwdmIwU1E
I'm kinda worried about all that knock correction, but I don't know what I'm really looking at. Please help me out, Thanks everyone.
- Adam
aTriz is offline   Reply With Quote
Old 10-30-2011, 09:54 AM   #2
Cobb Tuning
Member#: 4803
- Adam
Hi Adam,
It appears your DAM has dropped (to 0.94). The positive fine knock learning you are seeing is not knock, but the ECU adding timing back in because the DAM is less than 1.0. The DAM dropping is an indication of knock.
What is concerning about this log is that you have some long-term fuel trims (A/F Learning 1) as extreme as -12%. You should get with your tuner. This could be a mechanical issue with the car or the tune may need to be tweaked if you are running an aftermarket intake. If you changed the intake after the tune was completed, that would be another reason.
Bill
Old 10-30-2011, 10:06 PM   #3
aTriz
Member#: 95202
2011 WRX
PhatBotti e85 Tuned
hmm, still running on the stock intake. I wonder if it has to do with the fuel pump? That is the only thing I added after the tune was done?
Old 10-31-2011, 10:11 AM   #4
Cobb Tuning
Member#: 4803
Generally, adding an aftermarket fuel pump isn't a problem unless your stock pump couldn't keep up and therefore the FPR couldn't maintain pressure (and you ended up tuning around this). But, I would get with your tuner.
Bill
Old 11-03-2011, 04:41 PM   #5
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
atriz, pm sent
2011 WRX Stage 2 HWG Cobb Map bkruelle Proven Power Bragging 21 01-02-2012 09:16 PM
Log Check Please 2004 WRX 93 Octane on Stage 1 91 Tune jmikeumo AccessPort 21 11-06-2011 08:12 AM
2011 WRX Stage 2 overboosting issues Jaker AccessPort 32 02-23-2011 03:01 PM
02 wrx stage 2 logs ENY169 AccessPort 2 09-30-2010 10:34 AM
First Stage 2 logs - opinions please erikm Engine Management & Tuning 0 09-01-2010 10:52 PM
